Drivetrain PA inspection manic stage 2
Old Nov 7, 2017 | 04:44 AM
Isyvibes's Avatar
Isyvibes
What do i need to do to have my manic stage 2 tune pass Pa inspection?
Old Nov 13, 2017 | 08:57 AM
Pramuk's Avatar
Pramuk
just pray. I am going to take my car in this month in MA
Old Nov 13, 2017 | 09:49 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Curious how it turns out for you. Do you have a catless downpipe?
Old Nov 13, 2017 | 10:18 AM
Pramuk's Avatar
Pramuk
I don’t know yet. I will bring it to inspection place soon within this month. I have CNT catless DP + Manic II No cat No resonator.
Old Nov 13, 2017 | 10:41 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Thanks. Please post back after your inspection. Mass is more stringent than Connecticut, so if you can pass, I should be good
Old Nov 13, 2017 | 10:46 AM
Pramuk's Avatar
Pramuk
Sure! Will do. One of my friend has 500 Abarth, He couldn’t pass the inspection for three time. Right now he got R on his inspection sticker for over month.
Old Nov 13, 2017 | 03:04 PM
randeez's Avatar
randeez
if they do under hood and no check engine light you should be fine
but if they put sniffer in tail pipe theyll catch that you dont have any cats.. probably have to throw on stock dp and/or exhaust to pass. stock exhaust would be a lot easy to throw back on but i dont know if it would qualify.
No more inspections here, but can you go to an independent shop to have them sign off? may be a little more lenient
Old Nov 13, 2017 | 03:12 PM
Pramuk's Avatar
Pramuk
Even no check engine light still in trouble. My friend’s car got tune to eliminate check engine light but inspection place hook up and could find (Decat downpipe) from OBD2. It showed (CAT,O2s) so my friend’s car couldn’t pass the inspection. Mine as well got tuin from Manic2 no check engine light on dash anymore but let see .... !!
Old Nov 13, 2017 | 06:20 PM
thebombardier's Avatar
thebombardier
I looked up regulations in PA for another user. Pretty sure they allow one monitor not ready as long as it doesn't throw a CEL and you can still pass.
Old Nov 14, 2017 | 04:18 AM
Isyvibes's Avatar
Isyvibes
Does that mean i can leave it in map B and not do anything?
Old Nov 14, 2017 | 04:37 AM
thebombardier
I can't guarantee anything but it's worth a shot. I live in NY and that's exactly what I do. Passed twice now and two different shops I have no connections to.
I found this: http://www.drivecleanpa.state.pa.us/docs/readiness.pdf
Under "Readiness Monitors": "
For model year vehicles 1996-2000, a vehicle with
two monitors that are “not ready” will be accepted for the OBD test and the test can continue; for
model year vehicles 2001 and newer, only one “not ready” monitor will be accepted for testing and
the test can continue. "
Old Nov 14, 2017 | 04:39 AM
Rich Rodichok's Avatar
Rich Rodichok
Isyvibes, I don't know if the info below from the PA DEP will help you or not.
http://www.ahs.dep.pa.gov/aq_apps/emissions/test.aspx
Emission Test Results
Note: Vehicle emission tests are currently required in Philadelphia county.
County: Philadelphia
Year: 2011
Vehicle: Car
Tests: Onboard Diagnostics and Gas Cap Check
Note: Brand-new vehicles and vehicles driven under 5000 miles annually may qualify for an exemption sticker. Ask your service provider for more details.
Disclaimer: Gasoline-powered motor vehicles with a model year of 1975 and newer with a GVWR of 9,000 pounds or less and registered in an I/M county or region are subject to an emission inspection. Actual test requirements based on make and model, drive system, vehicle weight, etc. The regulations in Title 67 Pa. Code, Chapter 177 shall determine the test type for any individual vehicle
Old Nov 14, 2017 | 04:53 AM
Isyvibes's Avatar
Isyvibes
Year: 2011
Vehicle: Car
Thanks for the info. I did around 15k last year so i wont qualify for the 5k exemption.
Old Nov 15, 2017 | 03:20 PM
Isyvibes's Avatar
Isyvibes
Car passed inspection. Left it in map b and didn't have any trouble.
Thanks TheBombardier.
Old Nov 15, 2017 | 03:51 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
