Drivetrain Question for those with a Valeo clutch kit
Old Dec 14, 2016 | 05:36 PM
davisflyer's Avatar
davisflyer
I just got my car back from installing the Valeo single mass conversion clutch kit and I have a couple of questions.
1. My clutch has a dead spot for the first 1/3 travel until I feel any pressure. Is this normal? It doesn't seem right. I know it's supposed to be lighter and have a narrower engagement point, but this feels weird, like it needs adjusting or something.
2. I noticed as soon as I started the car that the engine sounded louder, almost like there was a hole in the firewall. Very weird. Would the single mass flywheel make the engine louder? (I expected a smidgen more vibration but again, this sounds strange).
Old Dec 15, 2016 | 11:32 AM
Saltysalt's Avatar
Saltysalt
my car made less noise and was smoother, I think the valeo had a better balance spec than the dual mass. I did have a dead spot, but I think that was more due to the slave cylinder being bled wrong, but it went away after a few days of driving
Old Dec 15, 2016 | 06:23 PM
soccerbummer1104's Avatar
soccerbummer1104
feeling a draft down by your feet by chance?
I've seen a few r53's that pull the large 'grommet / sealing boot' for the steering column off of the chasis when someone lowers the front subframe.
BTW.. its a PITA to get back in place. (fought me tooth and nail last time I had to do it)
But if that comes of it will definitely be louder in the cabin than before.
Good thing is you can check that with a flash light and some contortions to get into your drivers footwell. look at the boot and poke the bit that connects to the chassis. it should be attached to the chassis all the way around (through a lip seal) if it's not.. well thar she blows.
Old Dec 24, 2016 | 05:36 AM
davisflyer's Avatar
davisflyer
Seems to have been the culprit!
Old Dec 24, 2016 | 05:37 AM
davisflyer's Avatar
davisflyer
That's what I thought. Having the system re-bled.
Old Jan 27, 2017 | 07:30 AM
andyroo's Avatar
andyroo
Bump. Just got my car back after having the Valeo put in. Man is it light compared to my OEM clutch. That's fine, and the engagment is smooth and easy.
But that first 1/3 of travel that does nothing is annoying. Did re-bleeding it fix that or will it get better on it's own?
Old Feb 3, 2017 | 12:22 PM
nkfry's Avatar
nkfry
If the pedal has a soft spot at the top of travel the system is bled wrong and can cause problems.
You need to get the car in the air, pull the boot back on the slave and see if its leaking. If so, replace it it's failed.
Bleeding the slave is an art form on these cars and requires a special compression tool to do it right, without it you'll either damage the slave when you **** e plunger in the bore or you'll play hell trying to bleed it.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Feb 3, 2017 | 12:35 PM
andyroo's Avatar
andyroo
Mine got massively better since my last post. Much firmer and the first 1/3 of travel has decent resistance.
Old Apr 8, 2017 | 08:53 PM
davisflyer's Avatar
davisflyer
Yep, same here!
Old Apr 10, 2017 | 07:50 AM
tummi_gummi's Avatar
tummi_gummi
The reason a lot of you are having this dead spot is because there is air in the system. The clutch is the same thickness therefore the bearing travels the same amount before engaging the pressure plate. From what I have read the only real proper way to bleed our clutch if it is removed is to rig up a plate over the pinion and tighten it all the way to where it's full pushed into the cylinder. And then you bleed it. But after all of that you'll still have air so it is highly recommended to wedge the clutch pedal as tight as possible with the pinion pushed in still and to leave it over night with the brake reservoir cap off. This allows air to escape. I still haven't got my motor back but I have already done this as I don't need my transmission to bleed it.
Old Apr 11, 2017 | 07:30 AM
andyroo's Avatar
andyroo
So why did mine get so much better over a few weeks time? Honest question.
Old Apr 11, 2017 | 08:26 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
gravity, air will work it's way up and out
Old Dec 5, 2017 | 07:01 AM
gsfent's Avatar
gsfent
Bringing back a recent thread.
New Valeo, very gentle, like driving a Honda. I don't really have a "dead spot", but engagement seems like the last 25% of pedal travel, near the top. That is generally a sign of a worn clutch, but i know it is the same size.
Is this just a bleed issue? If so, I may drive it for a bit and see if the air works its way out. Brake pedal also just a little spongy, but good stopping power (EBC Red).
Thanks.
Regards,
Jerry
Old Dec 5, 2017 | 09:55 AM
andyroo's Avatar
andyroo
Thanks.
Regards,
Jerry
Mine changed dramatically in the weeks following install (for the better).
- Andrew
Old Dec 8, 2017 | 07:19 AM
megaDan's Avatar
megaDan
- Andrew
I too installed the Valeo single mass conversion and thought I didn't bleed properly at first, but within a week all is A-OK. The first few days every once in a while I had to double pump the clutch to get it to shift without grinding, by day 3 that was gone, and by day 7 or so it felt totally normal.
