Drivetrain From the “Baddest” to the “Deadest”
#26
Update --- cams arrived this AM, Cat # 1302603. Gotta stay in the box 'til the head gets here.
Interesting side note --- found an error in the Real OEM parts list. They show one "RectangRing" for the intake cam --- there's actually two on my OEM cam. Small stuff, but I expect better from them.
In an earlier post, I said the pistons were already ordered. Turns out, CP didn't accept the order, they want the head CC and the valve "free drop" #'s. Thumper provided the free drop while educating me on what this meant. Can't get the CC's 'til he's finished --- CP wants actual #'s, not calculated from OEM, so they can provide the requested 9.0:1CR. So, maybe I can expect the head in another couple weeks. Looks like pistons will be up to a month away, then 4 - 6 weeks more for engine block work.
Reminds me a lot of my old military basic training days --- hurry up and wait!
#28
#31
After adding a Cylinder Support System, decking the block is a "MUST" as the process leaves a slight "bump", and needs to be flattened. So, it's already in the plans, but thanx for thinking about it.
#32
I like the sound of the Darton sleeves due to the stronger strength in the metal used to make them (130,000) but not being one complete support system it seams like you "could" get shifting.
Mine will be the werx as well !!
OBW, tell thumper to respond to my email, I'm ready to send him my head. Lol
Keep up the build, I will hold the title in Nv till you get back up and running. Lol
#33
There's one other "enthusiast" I know of in the Reno area --- he's building an R56, but slowly. He's not taking my advice, and listening to the wrong vendors, so I don't consider him a threat to the title --- "Baddest Mini in Northern NV". Nowhere near our 300+ numbers. So, for the time being, the title is yours.
Just picked up my refurbished Carrillo rods --- looking pretty good.
Put the block, bottom half, in UPS this AM. On its way to NH for a CSS, re-bore to 77.5mm, decking, and "o-ring" install (soft metal on top of cylinder wall, for better seal with head gasket). They won't finish it 'til they get the pistons and that's gonna be another 3 - 4 weeks, but they can at least get a start with the CSS.
Ordered a bunch of stuff from my local Mini dealer --- bearings, gaskets, pins, dowels, seals, stuff I broke during dis-assembly, etc. Still more to order, just haven't decided on a source.
#34
Another update --- rods arrived a couple weeks ago --- lookin' pretty good.
Thumper's TPR1 arrived last week. Now to install lifters and rockers. Almost a pleasure to work on clean engine parts.
Picked up the dealer stuff a couple days ago. Decided to change timing chain stuff again --- dealer kit for chain, guides, bolts, tensioner, sprocket all came to under $100. Couldn't believe it!
So now I have about another week or so before pistons arrive. Pretty quick I'm gonna get busy.
#35
on
What rods are you using?
#36
Same ones I took out --- Carrillo. They were sent out for new bushings and minor repair on one of them (remove melted piston material). All balanced, cleaned up, and ready for install.
I should also mention that CNCWerx has completed the block CSS (Cylinder Support System) install. Just waiting for me to send the pistons.
#38
The pistons I ordered arrived this week and have been sent to CNCWerx for them to measure then rebore the replacement block. They've already installed the CSS, just waiting for the pistons. Maybe in another couple weeks I'll have the block in hand to start reassembly. I'll post pics of the pistons and block before starting assembly. I've already noticed a significant "dish" in the piston top --- just the opposite of a "dome". For those interested, here's the piston spec sheet. The spec sheet pics are small but pretty accurate.
#39
on
Everyday you learn something new
I wonder if that shape has same effect with idle than with WOT. I was also looking at lowering CR, but the only Pistons I found with lower CR are the supertechs. I know there is the custom option, but want to know the basics and if the shape makes sense for a track only car..
#40
Took the crankshaft and lower half of the block to a local machine shop. Crank was balanced and block was "hot tanked". Balancing was done to an order of magnitude better than OEM --- there's a new small drill hole in one of the counter-balance weights. I don't expect Manic to let me turn over 7200RPM, but I'm hoping to be ready if I can talk him into it.
And, before I forget again, the OEM cylinder head volume came in at 37cc's. After being worked by Thumper, it was "smoothed" to a finished volume of 36cc's.
CNCWerx shipped the finished block, pistons and ARP studs. Delivery scheduled for Nov 18. When it arrives, I'll take some pics and start a new build thread --- something positive, instead of dwelling on a dead toy. I'll post a link to finish this thread.
#41
OK, just started a new thread --- "OldBrokenWind's "Phoenix"" --- https://www.northamericanmotoring.co...ml#post4258911 It picks up the assembly process, with pics, at least at first. Might not be too many pics during assembly.
wainair
06-05-2002 09:14 AM
