Drivetrain How to Downpipe install?
Old Mar 1, 2016 | 03:53 PM
tylewis's Avatar
tylewis
I am sure it exists but I am having trouble finding it. Can someone link me to or provide me with a "How-To" for a downpipe replacement? Can someone also shed some light on what the "service mode" is in reference to this job. I am looking to do a catless DP and exhaust manifold replacement and would just like to see how to do it. Thanks everyone.
Old Mar 1, 2016 | 06:59 PM
bcriverjunky's Avatar
bcriverjunky
I just installed my downpipe and the heatshield is a pain. One of these and a gearwrench will be your bestfriend.
Old Mar 1, 2016 | 07:17 PM
MarioKart's Avatar
MarioKart
Vendor
The DP it self, is easy and straight forward, only the lower heat shield is a pain, because of the limited space, for your hands. 13mm and 10mm are the bulk of the tools needed. I would spay the 3 studs and nuts that bolt on to the turbo with some kind of lubricant. The turbo gets up to 1600F and can cause those studs to be hard to extract, letting them soak will help you mQubed Motorsport, Manic Tuning Dealer
Old Mar 1, 2016 | 08:02 PM
kelvin@pws's Avatar
kelvin@pws
Instructions from Akra. Just skip to the downpipe part. http://az79640.vo.msecnd.net/akrapov...987b0971c8.pdf
Old Mar 2, 2016 | 11:35 AM
tylewis's Avatar
tylewis
Thank you, this is helpful
Old Mar 2, 2016 | 01:28 PM
thebombardier's Avatar
thebombardier
Also, rule of thumb before any work on your car but especially on this job, disconnect your battery. Shorting/grounding out the alternator on the heat shielding is not good.
There are (I think) 10 bolts total holding in the upper and lower heat shields. Get the heat shielding out, disconnect both O2 sensors, undo the two mounting bolts near the bottom of the DP, undo V band at the bottom of the DP and the 3 nuts holding it onto the turbo. If the studs come out with the bolts it's not a huge deal. You can replace them or in my case I put the studs in a bench vice (not the best method, but there is an area in the middle of the stud with no thread that is a bit wider than the rest of the stud so I didn't ruin the threads) and removed the nuts from the studs. Install is reverse of removal.
Old Mar 2, 2016 | 03:24 PM
bcriverjunky
How did you get the lower shield out? I didn't want to bend it all up so I managed to get the downpipe in without taking it out.
Old Mar 2, 2016 | 03:39 PM
thebombardier
There are two bolts I could see being very easy to miss towards the top of the heat shielding. Then I took it out the bottom of the car. May have even come out with the downpipe.
Old Mar 2, 2016 | 05:39 PM
bcriverjunky
I had all the bolts out and even with the downpipe out that shield wasn't coming out unless I wanted to bend it to ****.
Old Mar 3, 2016 | 03:32 PM
Systemlord's Avatar
Systemlord
Does anyone have any idea how to stop my Borla S-Type cat-back exhaust from hitting that center metal brace? It doesn't have that center mount that the Akra has, I have replace all engine mounts and exhaust hangers.
Thanks.
Old Mar 3, 2016 | 03:48 PM
MarioKart's Avatar
MarioKart
Vendor
Does anyone have any idea how to stop my Borla S-Type cat-back exhaust from hitting that center metal brace? It doesn't have that center mount that the Akra has, I have replace all engine mounts and exhaust hangers. Thanks.
You can use washers to lower the center brace
Old Mar 3, 2016 | 06:29 PM
thebombardier
Thanks.
I just took it out.
Old Mar 16, 2016 | 07:31 PM
BMC_Kid's Avatar
BMC_Kid
I just finished replacing my turbo oil feed line and the only heat shield I put back was the one right in front of the line. The other big curved one I left off. I ended up just wrapping my downpipe with exhaust heat wrap and called it a day. The heat wrap keeps the heat in the downpipe and virtually eliniminates the radiant heat emitted into the engine bay.
Old Mar 17, 2016 | 08:38 AM
tylewis's Avatar
tylewis
Is there a walk through to the removal of the lower heat shield anywhere? I understand it is challenging and would like to go over the process a few times before I start digging around underneath.
Also, BMC_Kid, I have heard of dangers of heat-wrapping exhaust components as they can increase the rate of deterioration and the piping can literally "fall apart" as a result being wrapped. I also heard this is only true when a lot of moisture is present. Do you know about this or experienced any problems?
Can anyone shed light on this rumor I have heard?
Old Mar 17, 2016 | 11:50 AM
BMC_Kid's Avatar
BMC_Kid
I only wrapped my downpipe and that was mainly to deal with any radiant heat produced since I had no intention of putting back the crappy OEM heatshielding.
https://www.heatshieldproducts.com/a...nd-header-wrap
Old Mar 21, 2016 | 07:07 PM
AFN704's Avatar
AFN704
Would swapping out the down pipe be easier without the front bumper on? I plan to swap the intercooler soon with the he boost tubes. Should I just wait and do them all at once while it's opened up? Maybe it would make getting to the heat shields easier? Someone should make a video tutorial. If not I will when I do mine. Or I'll show you how not to do it haha.
Old Mar 21, 2016 | 07:15 PM
MarioKart's Avatar
MarioKart
Vendor
Not really, removing the bumber doesn't help installing the DP. I lift or getting the front end as high as possible, helps more.
<_CFXNotificationTokenRegistration: 0x16883ac0>
Old Sep 22, 2024 | 05:13 PM
theSantorini's Avatar
theSantorini
When you did this, what was your experience with the studs? Did they make contact with the threads of the dp, or pass right through?
thebombardier
Sep 22, 2024 08:10 PM
E34M5
Nov 16, 2022 08:40 AM
my2nds4
Dec 12, 2013 04:25 PM
jtack
Dec 13, 2012 11:11 AM
goofyman
Oct 2, 2010 05:11 PM
