Drivetrain Downpipe and Heatshield ?
Old Dec 5, 2012 | 01:49 PM
jtack's Avatar
jtack
I just purchased a riss racing downpipe. Should the heat shields bolt up easily to the new pipe or am I going to have to cut, drill, etc? Thanks!
Old Dec 5, 2012 | 02:11 PM
countryboyshane's Avatar
countryboyshane
I have one. Heat shield bolts in place without modification.
Old Dec 5, 2012 | 03:38 PM
jtack's Avatar
jtack
Thanks. What would you say the difficulty level is on a scale between 1-10? I just put on the exhaust system and that was not a problem. Downpipe easier or harder? Thanks again!
Old Dec 5, 2012 | 06:49 PM
mastermason11's Avatar
mastermason11
When I installed my akra DP, the heatshield remove and reinstall took the longest of all.
Old Dec 6, 2012 | 03:30 AM
p8ntbollr's Avatar
p8ntbollr
what he said^^ plus I ended up leaving out a bolt or so because some of them are just a PITA. lol
Old Dec 6, 2012 | 05:03 AM
countryboyshane
Yup, the heat shield is the real pain. It's definitely possible to remove the lower heat shield without putting the bumper into service mode, but get ready for some skinned knuckles. It's a true test of patience. I want to take my downpipe off to inspect it for any cracks and heat wrap for a little winter project, but I'm putting my bumper into service mode this time. An extra hour spent putting the car into service mode is worth it to me for how frustrating this part of the car is.
Here's a vid showing how to do it.
https://www.youtube.com/watch?v=T_BKvnEPJNQ
Old Dec 6, 2012 | 09:04 AM
jtack's Avatar
jtack
Thank you all again!
Old Dec 6, 2012 | 09:17 AM
Mindspin311's Avatar
Mindspin311
Can someone elaborate on this "service mode"
Old Dec 6, 2012 | 10:08 AM
countryboyshane
Watch the video I posted here.
It pushed the bumper assembly out about two inches so you have extra room to work.
Old Dec 9, 2012 | 07:31 AM
e30r56's Avatar
e30r56
I would recommend replacing the turbo oil feed and return lines at the same time you are replacing the downpipe. They are parts garanteed to fail, and you just have to pull one more heat sheild off to replace them.
Old Dec 9, 2012 | 08:32 AM
Mindspin311
Are the clips on the wheel arches built into the wheel arch itself?
Old Dec 9, 2012 | 10:58 AM
llewellyn's Avatar
llewellyn
The heatshield is definitely the most frustrating part. A helpful tip for aligning the downpipe on the turbos studs, the two lower attachment studs are on brackets, you can loosen these brackets to give you a bit more wiggle room to get on the studs. I would loosen these first, then the v-band clamp, then you can take it off the Turbo easily.
Old Dec 10, 2012 | 06:54 AM
countryboyshane
No. The plastic fasteners slide into grooves on the inside of the wheel arch liner. The tang on the fastener slides into a hole in the metal of the body and stays put. I would recommend prying them loose. Also, buy some spare fasteners. They are cheap and often break when removing them.
Old Dec 13, 2012 | 11:11 AM
mikeyb74's Avatar
mikeyb74
I reinstalled my original cat this past weekend. I didn't put the bumper into service mode this time and I have plenty of scratches and skinned knuckles.
Ovrclck
Oct 5, 2015 09:45 AM
GAT
Oct 4, 2015 07:27 PM
potterstein
Oct 2, 2015 09:30 AM
potterstein
Oct 1, 2015 07:10 AM
Nick Royer
Sep 29, 2015 03:01 PM
