Drivetrain Tensioner stop recommendations
Old Feb 22, 2016 | 06:14 PM
ti22fjc's Avatar
ti22fjc
Can't find the one I ordered before, WMW has on backorder.
Any recommendations for one?
Looks like the Alta one is available, the more expensive one.
Old Feb 23, 2016 | 09:01 AM
X757XVeritas's Avatar
X757XVeritas
I got the cheaper alta one on Amazon, let me see if I can find a link.
Here ya go, only 4 left.
ALTA AMP-ENG-190 Tensioner Stop https://www.amazon.com/dp/B00IGWVOEU..._DcjZwbT8JQB12
Old Feb 23, 2016 | 09:06 AM
X757XVeritas
And contrary to what the instructions say, with flexible arms and a wrench you can get the stop on while the tensioner is on the motor without lifting the motor partially in the engine bay. I got it on during a belt change without lifting the engine or removing the tensioner.
Old Feb 23, 2016 | 09:32 AM
ti22fjc's Avatar
ti22fjc
Thank you!!!
Old Feb 23, 2016 | 11:28 AM
X757XVeritas
It's worth mentioning that it prolly helps to have the tensioner with the tension off the belt. So grab the belt tool of you don't have one already
Old Feb 23, 2016 | 02:37 PM
ti22fjc's Avatar
ti22fjc
I have the belt removal tool, and spare belt, which I carry in vehicle at all times.
Accumulated quite a few tools with this vehicle; oxygen sensor tool, oil filter removal tool, brake caliper kit, Bentley manual, just about every torx size bit,....
Old Feb 23, 2016 | 02:44 PM
Helix13mini's Avatar
Helix13mini
At the risk of being a wet blanket, we've removed more tensioner stops than we've installed, because they cause more problems than they solve (limited tensioner movement, rattling and bending). The intention is to protect belt train components from damage if the belt breaks which is good, but belts rarely break. Instead get yourself a new, properly sized belt every 20-30k miles and you'll be good.
Old Feb 23, 2016 | 03:31 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
We have a tech article that can help you with the install on our site HERE. Click the "tech info" tab at top and then scroll down to Engine > Belt Tensioner Stop. We also have the tensioner stop HERE.
888.280.7799 | 6am - 5pm PST
Old Feb 23, 2016 | 03:39 PM
sevin's Avatar
sevin
+1. Save your money for something more useful.
Old Feb 24, 2016 | 06:01 PM
jamez's Avatar
jamez
+3
Been there, lost that - the design I had actually slid off and shredded my belt.
Old Feb 24, 2016 | 06:26 PM
bavmotors's Avatar
bavmotors
Don't bother I took my Alta off it just rattled.
Old Feb 25, 2016 | 03:35 AM
X757XVeritas
The newest tensioner comes with a rubber coating so it doesn't rattle. If installed correctly there shouldn't have been a chance to slip off. You have to take the bolt that holds it down almost all the way out in order for it to be high enough to slide it on. Unless your bolt comes loose it should be fine.
Old Feb 25, 2016 | 05:13 AM
Shawnnn's Avatar
Shawnnn
Originally Posted by jamez
+3
Sorry jamez but this one gave me a good laugh.
+4
Put a new belt on every few years and don't worry about it
Old Feb 25, 2016 | 11:24 PM
RogueMini's Avatar
RogueMini
Agreed. I have an Alta on my car because at one time, i thought it was important, but i am OCD about the belt, so the tensioner stop is kinda pointless.
Unless my vibration damper disintigrates.....
Old Feb 26, 2016 | 05:37 AM
Yep , just replace the belt. Contitech or gates is good.
Stock one is 11287520199, JCW Tuning kit belt 11287545120
Old Feb 26, 2016 | 06:24 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Tensioner stops, as well as several other mods I've seen, are a solution in search of a problem...
Old Feb 26, 2016 | 06:39 AM
Helix13mini
I love that expression. One of my mentors would say it like this: If a tensioner stop is the answer, what is the question?
D_Nyholm
Oct 19, 2017 09:04 AM
marshallpre1
South East - Florida
Jan 26, 2017 05:08 PM
egan311
Mar 16, 2016 08:42 PM
Tuesdayclub
Feb 22, 2016 04:50 PM
wearlaz
PhillyMINI Club
Feb 22, 2016 05:45 AM
