Drivetrain GIACs available
Old Sep 23, 2004 | 09:26 AM
  #101
SteveS's Avatar
SteveS
Andy, how would you compare the 15% and Giac to the 19% w/o the Giac?
Old Sep 23, 2004 | 09:41 AM
  #102
andy@ross-tech.com's Avatar
andy@ross-tech.com
The 19% with stock definitely makes more low-end torque (considerably more boost) but top end is a toss up. I'd have to see dyno tests to know for sure, but the 15%/GIAC feels happier at high RPM than the 19%/stock.
Old Sep 23, 2004 | 07:02 PM
  #103
Helix13mini's Avatar
Helix13mini
Originally Posted by dgszweda1
What was wrong with M7's injectors? I heard they were the same as stock, but rebuilt. Those were $400. Add that to the $399 for the GIAC, and you are still ahead of the Unichip.
One thing to remember with the injectors. Your mileage calculations on the Mini computer will be off. Not sure if the GIAC can reprogram this, but I heard aftermarket chips didn't have access to this functionality.
M7 reports that they have had success with their re-valved 400cc injectors. That is a good setup because they use the stock sized injectors with the right connectors, etc. One of the M7 cars runs the 400s without any software adjustment, and they report that there is no problems whatsoever. If one of you Socal boys with a 19% wants to get those injectors from Peter, I could probably arrange for a tuning session at GIAC in Irvine.
There is a slight risk of spray pattern problems with re-valved injectors which makes me want to find a factory OEM injector which fits, and is affordable. I've got the perfect ones in the shop, the only problem is that they are $150 apiece. Yesterday I got a line on some less expensive ones, so I will be investigating them over the next week.
Old Sep 23, 2004 | 07:16 PM
  #104
05JCWS's Avatar
05JCWS
Eric,
I wonder which injectors the new JCW kit uses. What size are the new JCW injectors.
Old Sep 24, 2004 | 06:21 AM
  #105
Helix13mini
Our local dealer doesn't have a part number for them yet, but that's definitely another option.
Old Sep 27, 2004 | 08:56 AM
  #106
Herby74's Avatar
Herby74
Hey, Eric.......thanks again for the chip! My Mini has alot more 'get up and go' and the transmission is smooooooth.......like all it wants is to go faster. The response that I'm feeling is at least as nice as adding a 15% pulley. Also, the middle position on the sway bar works great. The way this car rides now
is beyond any expectations I may have had when I got it and with some help from Helix it only took two years to get it this way.......far out! Just don't go anywhere without letting me know.
Herb
Old Sep 27, 2004 | 05:17 PM
  #107
MINIAC's Avatar
MINIAC
According to the reply I got to my email to John Cooper Garages ... "delivery has gone from 265cc per minute to 282cc per minute".
Old Sep 27, 2004 | 05:33 PM
  #108
greatgro's Avatar
greatgro
So that's basically window dressing, no? The aftermarket ones are 400cc+. That's a 50% increase. The JCW is increasing the size of the injectors by 6%???? I guess the JCW ones won't cut it for the GIAC.
Old Sep 27, 2004 | 06:12 PM
  #109
SteveS's Avatar
SteveS
Andy, what prompted you to leave the 19@ crowd?
In changing it, do you raise the engine to change it out? What is the secret for quick and easy?
Old Nov 3, 2004 | 06:17 PM
  #110
felix's Avatar
felix
What happened to this option!!
Did the progress stop on the 19+injectors?
Old Nov 3, 2004 | 06:49 PM
  #111
Helix13mini
Nope. I'm headed to California in two weeks to install it in a car and dyno test, so it better be done.
Old Nov 4, 2004 | 12:08 PM
  #112
friedduck's Avatar
friedduck
If you get a chance when you return, also give us an update on the plug-in module (versus shipping the ECU) if this is still in the plans.
TIA, Jeff
Old Nov 4, 2004 | 01:25 PM
  #113
Helix13mini
I'll see Garrett today, and will ask.
Old Jan 9, 2005 | 10:19 PM
  #114
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Update needed.
Any official update on the state of the-
GIAC for 19%: How much more HP and torque will it add if one already has the 19% pulley?
How much is the current price on the new factory Siemens 380cc injectors?
Any deals out there?
Any update for the GIAC USB version with cables? Cost and availability?
Given larger fuel injectors, does this overtax the fuel pump capability?
Is there any concern about the MINI's cooling system keeping up with added heat from the 19% pulley/GIAC and larger fuel injectors?
If one upgrades to the 17% pulley then can one add only the GIAC for 17% or are larger fuel injectors needed like the 19% for satisfactory/optimal power gains from GIAC?
Thanks for any info,
Old Jan 10, 2005 | 07:39 AM
  #115
greatgro's Avatar
greatgro
I'll give these my best shot until Helix responds...
Originally Posted by minihune
Any official update on the state of the GIAC for 19%
It IS available.
6-9 torque and hp although I didn't dyno my MINI. Unfortunately, I needed some other things done while I was there and I didn't have a lot of time.
$110 bucks a cylinder. Not cheap. But the combo (19%, GIAC & injectors) blows away ANY other mod combos out there (exceptions: Twincharged and nitrous).
No. Not yet. Hopefully he'll be able to find some low-cost, high quality injectors soon. I tried but I couldn't wait any longer.
I don't think the cable is ready yet but it should be soon. Right now you can have it installed by shipping your ECU (I believe) or making a trip to Helix.
I don't know the answer to this but I'd imagine the answer is no. The twincharged kit uses 500cc injectors. I think the GIAC uses 380cc. I think that is only 15-20% larger than stock.
No! This is the best part! With the GIAC and larger injectors, the MINI actually runs RICHER at the top end. Sick power with LOWER cylinder temps! What a combo! I'm told the difference in the summer will be even greater!
Don't know. I don't know a whole lot about the 17%.
Old Jan 10, 2005 | 09:05 AM
  #116
greatgro's Avatar
greatgro
19% GIAC with injectors
I have finally posted my review! Check it out...
https://www.northamericanmotoring.co...ad.php?t=35752
Old Jan 10, 2005 | 10:59 PM
  #117
minihune's Avatar
minihune
I talked to Eric at Helix13 and here's what I found.
$115 per injector for now and maybe a lower price in the future- Helix is trying to secure a cheaper source for the same new factory injectors.
Fuel pump capability is ample for the larger fuel injectors- no problem.
With the upgrades the MINI engine runs cooler so no problem with the cooling system. Hey, just get an M7 thermostat- keep that engine cool.
For MCS owners, you can add the 17% pulley/smaller belt alone and that's OK. But like the 19% pulley if you add GIAC you'll need the larger fuel injectors to make the upgrade worth it.
Old Jan 11, 2005 | 09:14 PM
  #118
discodan's Avatar
discodan
what can be expected by adding the bigger injectors or the JCW injectors to a 15%/GIAC equipped car? not much, if anything at all or will results be along the lines with the '05 JCW kit? also if i got the GIAC to go along with my 15% and i did decide to do JCW or other injectors would the GIAC need to be retuned at Helix on the dyno to be optimized?
Old Jan 12, 2005 | 06:15 AM
  #119
greatgro's Avatar
greatgro
You should only use larger injectors if you have ECU programming specifically tuned for those injectors. So I would highly recommend AGAINST adding larger injectors to a 15%/GIAC unless GIAC made a specially tuned ECU for that.
Old Jan 12, 2005 | 07:26 AM
  #120
AlexN's Avatar
AlexN
At 100 to 115$ per injector makes the JCW upgrade package a bargain.
You get the airbox for about 100-130$ :D
Thank god for connections.
Alex
Old Jul 3, 2005 | 05:01 AM
  #121
minigolf's Avatar
minigolf
Any word???
http://www.helix13.com/html/products...ew.php?p=6&h=m
"Soon GIAC will release their proprietary smart cable: putting file switching capabilities in the drivers' hands. This will allow the user to switch from various files that GIAC will provide, including stock, chipped, race gas, and valet mode (for those irresponsible drivers in your life). Those who buy the flash at an authorized GIAC dealer will, as always, get free updates (some dealers charge a nominal installation fee)."
Old Jul 3, 2005 | 10:08 PM
  #122
BFG9000's Avatar
BFG9000
Minihune,
I can't believe the number of posts you have. You have almost 250 times the number of posts than the average user on this site (not 250%, but 250 times). That means you spend the same amount of time posting on this site as 250 people normally do.
My vote is for an honorary 7th gear.
Originally Posted by minigolf
Any word???
See here: https://www.northamericanmotoring.co...9&postcount=28
Originally Posted by Itsdchz
Also Garrett himself told me that they will not be offering end user flashloading, as their software is the only one on the market that does what his does, and he doesnt want the coding to leak out there, as he worked long and hard on it.
I certainly hope the flashloader will be available and after seeing how the Grand National crowd shares maps online I can see how piracy can be an issue. But Franz seems to use a method of "activation" in MTH, and I am sure Garrett could do the same. Otherwise we will start seeing people upload their GIAC to Franz just so they can reflash it themselves!
(Or to add extra features like traction control/DSC desensitization while keeping the maps unchanged)
Old Jul 3, 2005 | 10:15 PM
  #123
minigolf's Avatar
minigolf
I certainly hope the flashloader will be available and after seeing how the Grand National crowd shares maps online I can see how piracy can be an issue. But Franz seems to use a method of "activation" in MTH, and I am sure Garrett could do the same. Otherwise we will start seeing people upload their GIAC to Franz just so they can reflash it themselves! (Or to add extra features like traction control/DSC desensitization while keeping the maps unchanged)
Thanks. In that case shouldn't helix update their site?
It must be possible to allow for end users to flash their own ECU, haven't APR been doing this for a while on VAG cars now?
Old Jul 5, 2005 | 07:54 AM
  #124
Helix13mini
Just did. Thanks and sorry.
BTW: JCW injectors are $105 apiece.
greatgro
Jun 23, 2007 08:16 AM
Pat_Cooper
Jun 20, 2005 08:09 AM
BriNYU
May 31, 2005 06:44 AM
