Drivetrain Stock boost limit?
Old Dec 17, 2015 | 03:13 PM
Mini_Touge's Avatar
Mini_Touge
Stock boost limit?
So I had my car tuned by neuspeed and now when I do first through fourth gear pulls I get the drivetrain check engine light which cuts power I had a mechanic diagnose my car and he said that the ECU is reading too much boost? Is this a typical issue after getting a tune? I contacted the guy that tuned my car at neuspeed and he is going to retune my car and he said he will either have to lower the boost down or possibly raise the boost limit on the ECU? Have any of you guys heard of any issues like this after getting a tune? Thanks in advance!
Old Dec 17, 2015 | 04:27 PM
oldbrokenwind's Avatar
oldbrokenwind
While discussing a Manic tune with the rep, I was told that the ECU limit is raised to accommodate higher boost --- a big selling feature. I'm surprised your neuspeed tuner didn't take care of this for you when he tuned it. When I built my MCS 3 - 4 years ago, this "ECU boost limit" wasn't available to be changed --- or the tuner didn't want to mess with it. He suggested I find a "Fuel or Boost Cut Defender" which I'm currently using. Go with the ECU limit change --- big boost is great.
Old Dec 17, 2015 | 05:08 PM
tylewis's Avatar
tylewis
What kind of boost levels can the stock turbo handle? I am planning a stage two tune and want to get 250 to the crank (don't want any more so as to avoid swapping the internals). What is the stock boost limit? Whats the max the little turbo can handle?
Old Dec 17, 2015 | 06:35 PM
Mini_Touge's Avatar
Mini_Touge
I can't lie I am a bit disappointed with NEuspeed because it is a very big company it isnt even big it is flat out huge can't believe they missed that step but luckily I called them and they were very kind and very helpful about it all and are going to re-tune it for free on Monday I will give you guys an update after they do that. If I keep getting the check engine light I will send you a message to see where I can find myself a boost cut defender like you have that sounds like a great idea as a last case scenario.
Mini_Touge's Avatar
Mini_Touge
That is a good question I am going to read into that right now and see what I can find out I thought we boost around 13 pounds so I'm assuming I am around 15 to 16 pounds but I have no idea don't want to assume until I have a boost gauge which I will be purchasing within the next week .
Old Dec 18, 2015 | 12:42 PM
tylewis's Avatar
tylewis
I have a scangaugeII which reads consistent boost levels for me (R56 N14, 61,500 miles) of 11-12lbs. I believe I saw up to 16-17 lbs while winding out 5th on the highway. Those levels were brief and fleeting though.
Old Dec 21, 2015 | 11:41 AM
Mini_Touge's Avatar
Mini_Touge
Just wanted to give you guys an update they re-flashed my ECU and all is fine now no check engine lights and it pulls just as hard very happy and they have great customer service!!!
Old Dec 28, 2015 | 07:41 AM
cerenkov's Avatar
cerenkov
There are a lot of people, myself included, running the Manic tune with sustained boost in the 18-20 psi range. I haven't heard of issues when staying in this range. I'm not saying that there haven't been any, I just haven't heard of any.
I do have the JCW turbo and methanol injection.
Old Jun 29, 2018 | 08:09 AM
guka747's Avatar
guka747
Yes i have seen that too but they are out of order
Old Dec 28, 2018 | 07:08 PM
jetskier3's Avatar
jetskier3
boost
I have a 2018 countryman s 2.0 I put a nm power module on and with no other changes I am getting a solid 16.5 everytime I step on it
Old Jan 8, 2019 | 07:27 PM
JPark's Avatar
JPark
I’m wondering the same thing with all the bolt ons. I’ve been searching and can’t find anyone that’s pushed their stock turbo.
Old Jan 9, 2019 | 05:55 AM
KCLARK's Avatar
KCLARK
What made you choose neuspeed tune instead of RPM?
aviaator
Cooper (non S)
Dec 11, 2016 10:58 AM
alanz
40
Jun 14, 2016 04:38 PM
Cngizbleevng
Nov 10, 2015 09:50 AM
mdaz75
Oct 29, 2015 04:21 PM
Bryan Thomas Snapp
Oct 28, 2015 09:52 AM
