Drivetrain Problem Swapping Trannys
Old Sep 30, 2015 | 07:33 AM
bahman's Avatar
bahman
Can a 2004 Getrag 6-speed manual with Quaife LSD be fitted into a 2005 MCS without causing any shifting problems?
I have done this conversion on my 2005 MCS Turbo (a variant of the Fireballed! Widowmaker) based on research, but cannot shift into reverse. All froward gears work fine.
While in the '04, the LSD tranny shifted fine in all gears.
Any suggestions, advice, insight, etc. would be much welcomed.
Old Sep 30, 2015 | 11:24 AM
Alan's Avatar
Alan
I just installed an '06 getrag into my '03 MCS without any shifting problems.
Since I changed final drive ratios it did require updating the ECU.
Old Sep 30, 2015 | 11:55 AM
Saltysalt's Avatar
Saltysalt
I cant see any other reason than the tranny it self that it wouldn't shift. same units, different gearing, unless theres a binding in the cables
Old Sep 30, 2015 | 01:59 PM
bahman's Avatar
bahman
TO Alan and Saltysalt,
Thank you both for your inputs and suggestions. I got it working.
The short shifter has an adjustment ball on the stem which had come loose, and interfered with movement of shift lever. Hard to diagnose, but easy fix.
iggi
18
Feb 9, 2026 01:00 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
bigserb3
Aug 31, 2015 09:54 AM
ki7hy
Aug 12, 2015 07:07 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
