Drivetrain Flames
Old Sep 17, 2015 | 04:15 AM
R56austin's Avatar
R56austin
Flames
I have a 2009 Mini Cooper s turbo charged. I have a Alta cold air intake, Alta hot side boost tube, and a Alta turbo inlet tube stock exhaust and was wondering how can I shoot flames with my mini. Want a nice exhaust, loud, and shoots flames. And wondering how I would go about doing this. What exhaust and how to set up everything. Thanks
Old Sep 17, 2015 | 04:22 AM
thebombardier's Avatar
thebombardier
A straight pipe would be the easy solution. You definitely need to get rid of at least 2 of the catalytic converters in the exhaust, especially the one in the downpipe. And a straight through muffler would help as well.
You'll also need to considerably up the power of the car with a tune. Probably stage 2 considering stage 2 needs a turbo-back exhaust.
Old Sep 17, 2015 | 05:06 AM
R56austin's Avatar
R56austin
So just go to my local shop and get a straight pipe made and have them take 2 cats out? And what else could I do?
Old Sep 17, 2015 | 05:25 AM
R56austin's Avatar
R56austin
Also would an after market downpipe help at all? If so which one would be best?
Old Sep 17, 2015 | 05:40 AM
thebombardier
The R56 has 3 cats. 1 in the downpipe and 2 in the rest of the exhaust. If you're going custom it might just be easier to have them make the whole exhaust. Keep in mind though a straightpipe will be: 1) Very loud and maybe not very good sounding and 2) Illegal due to emissions and noise depending where you live. You'll also need to do something with the O2 sensor to keep it from giving you a check engine light.
Is this your daily driver or a track day car? If you're going to strightpipe the thing just to shoot flames and it's your daily you may find the noise annoying after a good while.
EDIT: It only has 2 cats. The third I was thinking of is a resonator in the midpipe.
Old Sep 17, 2015 | 05:47 AM
R56austin's Avatar
R56austin
It is my daily but I also have another car for work and drive around when I don't wanna drive the mini. I don't find them annoying either. Have a bike that is straight piped
Old Sep 17, 2015 | 09:43 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I'd contact a local MINI performance shop near you and see if they are able to do this for you. They'd know the best honestly and give you a good idea at what all will need to be done.
888.280.7799 | 6am - 5pm PST
Old Sep 17, 2015 | 09:57 AM
R56austin's Avatar
R56austin
I know if I go straight piped and take two cats out and get a cat less downpipe I'll be good then just gotta get it tuned and see from there. If I'm correct that is
Old Sep 17, 2015 | 04:41 PM
Porthos's Avatar
Porthos
Wow this thread is all kinds of ****ed up. Its not as easy as strap on a straight pipe an you shoot flames. To correct the Bombardier the R56 only has 2 catalytic convertors, one in the downpipe and another about 1' 1/2 past where the downpipe connects with the midpipe. The reason you see most performance cars shoot flames is that they are having unburnt fuel ignite in the exhaust. It looks cool as hell but, can be damaging to your turbo and your exhaust. Another way to do it is to have a misfire system but, that in itself tears more things up like the turbo, intercooler, and exhaust. Another way is to just go buy a flame kit if that is all you are looking for is to shoot flames. Oh you can have it tuned to shoot flames like what Manic is offering through Lowen at the moment.
Old Sep 17, 2015 | 04:44 PM
R56austin's Avatar
R56austin
Thank you for the help!
Old Sep 21, 2015 | 04:48 PM
isamin's Avatar
isamin
Go to someone like JC WHITNEY and order a hot rod flame thrower kit. It's done with fuel vapors and a spark plug type igniter. I did things like this 50 years ago and thought it was KOOL but I learned my lesson.
ISAMIN
Old Sep 24, 2015 | 05:59 PM
nwing84's Avatar
nwing84
any manic dealer can get you the tune, its only avaiable on stage 2 and up, for a stage two you need a fmic, intake, turbo back exhaust and they highly suggest a decat downpipe, I have the tune and love it. here is a link to see the flames that come out
Old Oct 4, 2017 | 10:08 AM
csllover's Avatar
csllover
R56 flames - YouTube
Sorry to bring up this old thread but I'm wondering what exhaust you have with this setup? I have a decat, a straight through (but muffled) mid-section and standard muffler. Would I get flames with my set up if I tune it stage 2 with Manic?
Old Oct 4, 2017 | 10:26 AM
Bnourai's Avatar
Bnourai
R56 has 2 cats and a resonator
Old Oct 4, 2017 | 11:49 AM
csllover's Avatar
csllover
To my understanding european cars only have one (in the downpipe). There is no secondary cat.
Old Oct 4, 2017 | 02:25 PM
Bnourai's Avatar
Bnourai
my car had 1 in DP and one on exhaust+ res. since i have removed both cats and res.
ben
Old Oct 4, 2017 | 03:12 PM
cornjuice's Avatar
cornjuice
hot exhaust gases help.. so does a catless DP. I would post a vid of my JCW but no GoPro to get nice tailpipe shots ;(
Stock JCW exhaust will pop off a lot more vs. Cooper S.. but it all depends on your end goal.
If you just want loud + flame pop; drop the factory exhaust for a straight pipe 2.5" from the DP back. If you do decide to get a catless DP.. wrap it.
Old Oct 4, 2017 | 11:49 PM
csllover's Avatar
csllover
Many thanks. Why do you suggest wrapping the catless DP? For heat protection or to lessen the noise slightly?
Old Oct 5, 2017 | 01:14 PM
cornjuice's Avatar
cornjuice
Heat control under the hood sure helps..other than that, wrapping let's the DP stay hotter which in turn helps with the flame pop quite a bit.
If I'm casually driving for 5min or so, things cool down enough on my exhaust to where I don't get regular pop/backfire. As soon as you wind up a bit and things get warm again, it pops off on demand with throttle lift or shift at ~3500rpm.
Old Nov 3, 2017 | 06:26 PM
Pramuk's Avatar
Pramuk
Mine has splited flame sometime. Manic II, Catless, Decat
Old Nov 3, 2017 | 08:49 PM
NeonLed's Avatar
NeonLed
Here's a video I took. I just asked for extra pops and bangs, and flames came with it I guess. I'm fully catless as well.
Old Nov 3, 2017 | 10:05 PM
Pramuk's Avatar
Pramuk
Originally Posted by NeonLed
Here's a video I took. I just asked for extra pops and bangs, and flames came with it I guess. I'm fully catless as well. https://www.youtube.com/watch?v=UYpy_SnOQc0
BBQ mode?? I really want to get BBQ mode... I have only regular stage 2. And these day Manic doesn’t do a small tune. I was told that I need to pay the full price of tuning + BBQ again to add BBQ mode
Old Nov 6, 2017 | 02:17 AM
NeonLed's Avatar
NeonLed
I asked for bespoke version of the tune which is another $100 on top of the price. You can choose extra pops and bangs or BBQ mode.
cmanlu
R58 :: Coupé Talk (2012+)
Aug 25, 2015 07:35 AM
BuckDodgers
Apr 23, 2004 09:27 PM
MG-BGT
Sep 30, 2003 03:03 PM
consumer
Sep 17, 2003 07:03 AM
dpilgrim
Apr 25, 2003 07:18 AM
