Drivetrain Thermostate Question...
Old Feb 16, 2006 | 05:46 PM
  #51
onasled's Avatar
onasled
Originally Posted by Johan
I'm confused...comparatively speaking, bartenders sell items that are knowingly bad for your health but people choose to buy it any way...soooo, what your saying is that tuners sell items that are bad for your vehicle, knowing that people will buy it anyway??? hmm....doesn't make sence to me!
YES !
THAT'S IT !
I think that's exactly what sid was tring to say. Thanks for making it so much clearer...
Old Feb 16, 2006 | 05:48 PM
  #52
holdenontoit's Avatar
holdenontoit
Originally Posted by MSFITOY
Can't blame the bar tender for your headache
I don't find this analogy particularly relavent unless the bartender had slipped me a mickey.
I just wish he had been more up front about what the application for this product was ie hot climates . all I had to go on was his statement about retaining that "just started up feeling in you MINI all day long". Johan, there has been much discussion about the syntec needing to get up to temp to do its job properly .I would suggest that 140 deg is not enough to get the job done.
Old Feb 16, 2006 | 05:58 PM
  #53
MSFITOY's Avatar
MSFITOY
Does anyone know why MiniUSA does not condone modifying their product? Who decided to modify their product? Does MiniUSA endorse any aftermarket vendors products? Do you know why?
Old Feb 16, 2006 | 06:32 PM
  #54
RED FURY's Avatar
RED FURY
FYI: This is NOT an isolated incident with this mod:
M7 never said the thermostat was for "warm weather climate only" or for "race conditions"
I spent more than a few days, 3 visits to the dealer, after SES lights were a blaring ... All due to a fault code from the Thermostat and cooling system
Amazingly, all is better now, after replacing it with a stock thermstat
I informed Peter-Randy, they said yep, that happens in cold weather
Are there ANY notes or warnings of this on their web-site? NO
http://m7tuning.com/main.m7/store/10009
Old Feb 16, 2006 | 06:59 PM
  #55
scobib's Avatar
scobib
In my experience the only good to come from a t-stat with a lower temp was either for:
A. Continued high speed operation (e.g. racing)
B. Rockcrawling (VERY low speed operation, heavy loads, 4WD)
Both in hot climates... Otherwise, the t-stat is meant to open at a temp specified by the manufacturer for a specific reason.
Just my $.02.
Old Feb 16, 2006 | 07:39 PM
  #56
Johan's Avatar
Johan
Originally Posted by onasled
YES !
THAT'S IT !
Relax!! It's all in good fun
Old Feb 17, 2006 | 02:07 AM
  #57
holdenontoit
YES !
THAT'S IT !
this from the racing coordinator ? this was a really helpfull comment, thanks Greg.
Old Feb 17, 2006 | 04:14 AM
  #58
onasled's Avatar
onasled
OK, OK, I take it back. Geeezzzzz....
Old Feb 17, 2006 | 05:40 AM
  #59
MSFITOY's Avatar
MSFITOY
When I first installed my M7 thermostat, I experienced a couple of tripped error code..."temp below threshold". This was due to my impatience and going WOT before temperature were stablized. Since then, I've been careful to wait until temperature reached it's peak before getting aggressive with the pedal and have not experienced any further error codes
Old Feb 17, 2006 | 05:49 AM
  #60
holdenontoit
sid, what part of the country are you located in? Jock
Old Feb 17, 2006 | 05:57 AM
  #61
MSFITOY's Avatar
MSFITOY
Crappiest part Detroit area...and it's cold
Old Feb 17, 2006 | 08:20 AM
  #62
ingsoc's Avatar
ingsoc
YIPES....so I guess the thermostat is just fine below zero! lol.
Old Feb 17, 2006 | 08:50 AM
  #63
meb's Avatar
meb
Any time you ask an engine to run cooler, you must consider geographic consequences. Oil coolers can do the same thing; they get all guey, the oil turns white and so on and so forth.
At one point in my life I removed and reinstalled these every fall and spring. I was nuts back then
Old Feb 17, 2006 | 10:55 AM
  #64
Wagnbat's Avatar
Wagnbat
I'm having the same problem with my thermostat.
My biggest issue was that there weren't any warnings or disclaimers from the reputable mini tuner.
I don't enjoy driving around with my SES light on, because I won't know if something is really wrong. And the light has been on since install in December... Twice I've got it reset, and twice it's come back on within a day.
Also, it was recommended to have the dealer install it, because a gasket is not provided, and the only way to get a gasket is to buy a stock thermostat. $40 part, dealer charged $160 to install it. If I'd have known they were going to charge that much, I'd prolly have just bought the stock thermostat... About $30.
Old Feb 18, 2006 | 02:36 PM
  #65
002's Avatar
002
I have just found out that some bmw's use electronically controlled t-stats to increase power under load and performance driving. They'er performance temp is also 180*. I was told that the concern for lower oil temp is lower gas mileage as hotter oil has less friction so better mpg.
The goal of the colder t-stat is lower cylinder head temps (less detonation so more timing) and better fuel control (leaner mixture). Both mean more power. After learning more about this subject I am goin to give it a try.
Old Feb 18, 2006 | 02:37 PM
  #66
002's Avatar
002
What codes did you get? There is a mini bulletin about air in the cooling system causing codes.
Old Feb 18, 2006 | 02:54 PM
  #67
trackster's Avatar
trackster
"Also, it was recommended to have the dealer install it, because a gasket is not provided, and the only way to get a gasket is to buy a stock thermostat. $40 part, dealer charged $160 to install it. If I'd have known they were going to charge that much, I'd prolly have just bought the stock thermostat... About $30. "
Let me guess the dealer recommended switching the gasket? When I purchased my unit I asked M7 about installation procedures. I was assured that it was a job that the average enthusiast with minimal tools could accomplish at home. I also asked about the gasket and was assured that the original could be re used and has in 100's of cases. You just have to take care when removing the stock thermostat. The install took 40 min and i had to replace less that a cup of antifreeze. Did you call M7 and perhaps inquire as to any of these points or did you just blindly let a dealer take you to the cleaners?
John
Old Mar 8, 2006 | 01:35 AM
  #68
MINIotaple's Avatar
MINIotaple
The M7 thermostat just caught my eye and after reading a couple of the threads. I have a couple of questions.
1) At what temps does the car start having error codes? I'm in Houston and we rarely see below 0 Celsius, but if it happens even then, I'm not too sure I'd want to mess with it.
2) Is it worth it?
Mb460
35
Sep 18, 2015 06:46 AM
user 7082082
Sep 29, 2007 01:43 PM
xsmini
Classic Mini Talk
17
Aug 15, 2007 06:48 AM
glnr13
Jun 22, 2006 09:34 AM
thefuturequeenofnebraska
NorCal MINIs
Mar 30, 2005 02:23 PM
