Drivetrain torque app questions
Old Feb 6, 2015 | 03:31 PM
larmini's Avatar
larmini
Hello, I have my torque app set with boost gauge. When the car starts it changes to vacuum gauge anybody know what's up. How to get it to at stay on boost.
I mean it's there but then when it connects it's vacuum ..don't know what to do
Old Feb 6, 2015 | 07:22 PM
MiniSkoon's Avatar
MiniSkoon
I've had the same problem... Just mess with the settings. Seems to default to that. Ive got it to work, but it's a lot of messing around. I've found no sure method other than just playing with it.
Old Feb 6, 2015 | 07:25 PM
larmini's Avatar
larmini
Not sure what else to do. It's there but when it's running it turns to vacuum..
Old Feb 6, 2015 | 07:34 PM
MiniSkoon's Avatar
MiniSkoon
I know, seems like a flaw in the app. Sucks its a important monitor. I've erased settings and started over and it worked. My 2 cents, if you're running the JB just keep the octane up and your good. Wish I had a more solid answer for you.
Old Feb 6, 2015 | 09:23 PM
cerenkov's Avatar
cerenkov
I've never used torque but DashCommand displays vacuum as negative boost.
Does the gauge switch back to boost when you making boost? In other words does the gauge flop back and forth from vacuum to boost as the pressure in the manifold changes?
Most of time when you are driving the manifold is in vacuum.
Old Feb 6, 2015 | 09:25 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Does the gauge type change? Or does the reading go negative? If you have an N14 engine you will see vacuum until you get on the gas and get the boost going.
Old Feb 7, 2015 | 12:16 AM
barnoun's Avatar
barnoun
Exactly. Go WOT and you'll see the gauge change over to boost instead of vacuum. I have the torque app for android and that's what it does.
Old Feb 7, 2015 | 05:29 AM
larmini's Avatar
larmini
Ok. Never did that yet really. Just installed it. .I will try that later.
I have n18
Old Feb 7, 2015 | 06:01 AM
cerenkov's Avatar
cerenkov
Originally Posted by larmini
Ok. Never did that yet really. Just installed it. .I will try that later. I have n18
The N18 only goes super negative during cold startup, after that they hover around -2 to 0 during idle and cruising.
Old Feb 11, 2015 | 01:54 PM
larmini's Avatar
larmini
So I can't get it to work for boost it is there but when it connects it turns to vacuum. I punch it and the vacuum just lowers itself. I never see boost. Is there something in the settings that sets it for turbo etc. Or does it just know. Sux.
Old Feb 11, 2015 | 05:25 PM
barnoun's Avatar
barnoun
Make sure the "Boost Adjustment" is set to 0psi in the profile. Also make sure you're using the "Turbo Boost and Vacuum Gauge."
Can't think of anything else besides a problem with your OBD adapter, but I wouldn't know what to do about that.
Old Feb 11, 2015 | 05:52 PM
larmini's Avatar
larmini
Ok. Thanks. It was set at 14.
I now set it to 0
Old Feb 12, 2015 | 05:00 PM
larmini's Avatar
larmini
That was it. Chasing to 0 psi. Now all set.
Old Feb 12, 2015 | 05:59 PM
barnoun's Avatar
barnoun
cool.
Old Mar 4, 2015 | 01:12 PM
Lead, No Follow's Avatar
Lead, No Follow
There's a setting in Torque to turn this off.
Go to the Torque Settings menu, click on "Units," and then check the box that says "Don't display psi as in/Hg."
Happy motoring!
Old Mar 19, 2015 | 06:50 PM
cpgifford's Avatar
cpgifford
just a question, does the torque app show oil pressure or temp on the n14?
Old Mar 23, 2015 | 07:57 PM
barnoun's Avatar
barnoun
No oil pressure or temp reading on the n14.
miniuy
Oct 7, 2016 12:09 PM
randeez
Sep 15, 2015 09:16 AM
Bruce/Fl
Aug 28, 2015 11:59 AM
PEterChoqu
Aug 26, 2015 08:33 AM
tag1260
Aug 24, 2015 05:52 PM
