Drivetrain Best Cat to use with OBX header?
Old Dec 15, 2014 | 07:07 PM
Tslatt's Avatar
Tslatt
Just ordered an OBX header for my 2006 MCS. I am debating if I should have my OEM cat cut off and bolted on or if I should purchase an aftermarket high flow cat like Random Technology. Not sure which is the best way to go, also not sure which aftermarket cat I should buy if I decide to go that way. Does anyone know what model I should be looking for?
Old Dec 15, 2014 | 08:15 PM
ZippyNH's Avatar
ZippyNH
I would reuse the OEM...that is if it it still OK...heck have know of folks doing that with NICE RMW shorty headers with great numbers...
Not a lot to be gained vs the $$ and the issues some folks have with high flow units...
A few of the "aftermarket" units have melted, or cracked and failed pretty fast...or sets a check engine light randomly for low efficiency.... (Most only last about 2 years unless you get a $$$ CA approved version from talking to a few folks).
Sure some folks will disagree, but I always err on the trouble free side, especially if it is cheaper...and if you bought an OBX header...you are a penny pincher (not a slam, but obx is at the very low end, but still OK for some on a tight budget)...you can make a obx header work...usually..depends on how lucky you are with the particular unit they send you...some fit OK with a few minutes of work...some are MUCH worse.
Old Dec 15, 2014 | 08:39 PM
Tslatt's Avatar
Tslatt
Thanks for the reply. I think that's the way that I'm leaning. I"m pretty dubious about the OBX but I had several people push me that way so for $175 bucks I figure its worth a shot. Ive got a Supersprint catback and like the idea of having a header designed after the supersprint header. Hopefully I don't regret my decision.
Old Dec 15, 2014 | 08:43 PM
miniblucabrio's Avatar
miniblucabrio
I've had good luck with my obx header so far. Had the factory cat put in and it's been trouble free.
Old Dec 16, 2014 | 06:18 AM
Tslatt's Avatar
Tslatt
Miniblue, were you able to feel a difference in performance with the obx? Is it super loud? Do you think it would perform better with a high flow cat?
Old Dec 16, 2014 | 10:03 AM
ThumperMCS's Avatar
ThumperMCS
Random Tech is quality. Have one on my RMW header and I had one on my first MINI which had an OBX header
Old Dec 16, 2014 | 10:40 AM
Swimbaxter's Avatar
Swimbaxter
+1 for me too, I run the OBX with the Random Tech Cat no CEL's. I did melt a MagnaFlow on the OBX initially before making the switch to Random Tech.
Old Dec 16, 2014 | 10:51 AM
Tslatt's Avatar
Tslatt
Are you running the 8100 series 2.5 inch?
Old Dec 16, 2014 | 12:11 PM
Swimbaxter's Avatar
Swimbaxter
I am not sure, wasn't aware of more than one option.
Old Dec 16, 2014 | 01:23 PM
checkers's Avatar
checkers
I'm running a stock cat with RMW race header with no problem. I live in Calif. and with the high flow cat I couldn't pass smog so I replaced it with the stock cat and no problems.
Old Dec 16, 2014 | 01:44 PM
ThumperMCS's Avatar
ThumperMCS
Provided you have no check engine lights, it will pass now with the new OBD-only tests that CA has switched to
Old Jan 13, 2015 | 09:23 AM
GreekDrifter91's Avatar
GreekDrifter91
I have a OBX header and i use a generic Magnaflow 2.5 in/out hiflow was $70 on amazon. i had the obx flange welded to the cat and bought a 2.5inch 2bolt flange and had the welded to the other side. i Passed CT emissions with no CEL, so others should be good. CT is a tough emissions state but not as bad as cali. sry
so from the collector of the header out to the tail pipe is 2.5"s
from front to back i have,
OBX header
Maganflow Cat,
ALTA catback.
yea its a bit loud but sounds pretty darn good.
Old Jan 13, 2015 | 02:27 PM
db130's Avatar
db130
Tslatt,
Which vendor did you buy the OBX header from?
vulkandino
Oct 31, 2015 08:29 PM
WhinyR53
Sep 30, 2015 07:36 AM
PhoR53
Sep 30, 2015 06:54 AM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:11 PM
