Drivetrain intercooler fan
Old Jul 9, 2004 | 07:40 AM
tlamano's Avatar
tlamano
intercooler fan
I have a front mounted intercooler on my turbo miata and have no problems keeping the charge cool. As we know however, the MCS ic location is not the best due to engine heat and the small hood scoop. I wonder if mounting an electric pancake fan above the ic would help? This seems like a low cost experiment, I'll let you know how it works out.
Tom Lamano
04 MCS JCW, MaxVelocity CAI
Old Jul 9, 2004 | 07:50 AM
jlm's Avatar
jlm
you have about 1" thickness to play with between the cooler and the hood surface with the infill removed; and the fan still has to draw air.
Old Jul 9, 2004 | 07:51 AM
05JCWS's Avatar
05JCWS
Tom,
I think that would only help when you are sitting still, in which case there is not a lot of need for power. Once the car gets moving with the air to air intercooler, the temperature drops quite quickly.
Old Jul 9, 2004 | 07:58 AM
tlamano's Avatar
tlamano
I'm thinking it might help with a quicker recovery from heat soak.
Old Jul 9, 2004 | 09:12 AM
kenchan's Avatar
kenchan
I use a nitrous intercooler spray ring on my wrx with a top mount intercooler.
Works wonders in 90F+ weather when I need to launch the car.
I believe Pilo has as a similar kit for the MCS.
Old Jul 10, 2004 | 07:13 AM
Bisch's Avatar
Bisch
It is a good idea, but fitment will be a serious challenge. Launch temps are a real challenge, especially at the strip. If you do a burnout, you jack the intercooler temps way up, as you are not moving. External water sprayers are not an option at the strip either.
Qik420
Oct 4, 2015 08:19 PM
Adam Bradbury
Sep 28, 2015 04:15 PM
kevinlhr310
Sep 27, 2015 02:31 PM
rt808
Sep 25, 2015 01:59 PM
