Drivetrain Belt tensioner tool
Old Jun 30, 2004 | 11:17 PM
juzmackjr's Avatar
juzmackjr
Belt tensioner tool
Anyone in this group needing a tensioner tool is welcome to use mine for the price of postage.The only thing i ask is that you send the money first and if you break the tool you replace it.My email is juzmackjr@msn.com.
Old Jul 1, 2004 | 12:07 AM
Tomslick's Avatar
Tomslick
How do you not break the BMW tool?
First the weld broke. Got that welded.
Then one of the pins broke. Mine worked okay with only one pin.
Great offer juzmackjr. I'm just being a _____.
Old Jul 1, 2004 | 12:27 AM
JCampos's Avatar
JCampos
That tool is a ripoff anywho.... I used a clever concoction of 3 well placed bolts and a huge flathead screwdriver.
Old Jul 1, 2004 | 08:27 AM
norm03s's Avatar
norm03s
Built my own, anyone in my area (local) that needs to use it contact me.
Old Jul 1, 2004 | 09:12 AM
Bisch's Avatar
Bisch
If anyone wants, I'll send you a big stick.
Old Jul 1, 2004 | 11:01 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
It is highly recommened that if you get an oem tensioner tool, get it rewelded into THE TENSIONATOR:
... or else it will do this:
Old Jul 1, 2004 | 11:03 AM
CoryB
Can anybody post dimensions of the tool for the diy-ers out here? I think I could build one easily enough if I knew some measurements for it.
Thanks!
Old Jul 1, 2004 | 11:06 AM
andy@ross-tech.com
The pins appear to be 5mm diameter, and they protrude 10mm from the tool. Their centers are 35 mm apart.
Old Jul 1, 2004 | 11:53 AM
norm03s's Avatar
norm03s
Andy's dimensions are correct. I used them to make mine.
Thanks again Andy
Old Jul 1, 2004 | 11:55 AM
norm03s's Avatar
norm03s
Kendorf, Bisch
Old Jul 1, 2004 | 12:22 PM
Bisch's Avatar
Bisch
Originally Posted by norm03s
Kendorf, Bisch
Old Jul 21, 2004 | 12:27 AM
johnD's Avatar
johnD
Coordinator :: ClubMINI.ph
Andy,
What's the distance between the 1st pin and the corner of the bend? Thanks!:smile:
Old Jul 21, 2004 | 05:02 AM
andy@ross-tech.com
I'm not sure what you mean. Can you draw a diagram?
Old Jul 21, 2004 | 08:42 AM
johnD's Avatar
johnD
For my 1st question, what the distance of X? And since I'm already drawing, what's the distance of Y? And why don't they just weld the two pins straight along the flat bar? Thanks!:smile:
Old Jul 22, 2004 | 06:59 PM
BlueMCS's Avatar
BlueMCS
I don't know why you really need one of these unless you are changing belts/pulleys regularly? A large screwdriver or crowbar works just fine.
Andy, what did you do to that thing and what kind of metal is it?
The TENSIONATEHER?
Old Jul 22, 2004 | 07:30 PM
andy@ross-tech.com
All dimensions are in mm.
Last edited by andy@ross-tech.com; Jul 23, 2004 at 08:19 AM. Reason: Added pin dimensions
Old Jul 22, 2004 | 07:48 PM
OutMotoring's Avatar
OutMotoring
Vendor - 15 Years
Yes, they totally suck so bad. We get about 1/2 of them back after our very light use from our customers so we have started welding them here before sending them out...but we are in the process of having some made for us, because they are totally expensive...
Old Jul 23, 2004 | 08:24 AM
andy@ross-tech.com
I do both
The TENSIONATEHER?
I used it twice, the second time it had the consistency of warm taffy. It appears to be made of "steel". It is ferrous, attracts a magnet, and rusts easily, yet it appears to have the strength of pot metal.
Old Jul 23, 2004 | 08:32 AM
BlueMCS's Avatar
BlueMCS
Yea, it looks like pot metal.
Cool, someone invented a weldable pot metal so you can buy cheap tools and easily modifiy them to work well.
Is that really easier and cheaper than doing it right the first time?
Old Jul 23, 2004 | 09:15 AM
andy@ross-tech.com
Originally Posted by Homer
Kids, there's three ways to do things. The right way, the wrong way, and the Max Power way!
Originally Posted by Bart
Isn't that the wrong way?
Yeah, but faster!
Old Jul 25, 2004 | 04:06 AM
johnD's Avatar
johnD
Thanks for the diagram Andy!!!
Old Nov 15, 2008 | 08:18 AM
norm03s's Avatar
norm03s
Bump
Old Nov 15, 2008 | 06:15 PM
The_R1_Kid's Avatar
The_R1_Kid
+1
Old Dec 23, 2009 | 12:33 PM
jbkone's Avatar
jbkone
what is that 3/4 circle for? You know, the ring looking thingy.
Old Dec 23, 2009 | 01:23 PM
ZippyNH's Avatar
ZippyNH
Talk about bringing an old thread back too life!!
It is the pivot point of sort, where it sits and rocks while you pull back, till you can lock it in postion. Most of the tools are better now....out motoring, etc sells then for about $100.
