Drivetrain Ignition Projects coil or Okada plasma coil
Old Sep 1, 2014 | 04:18 PM
ridinDirty's Avatar
ridinDirty
Anyone have any input on which coil is best . I know we are talking half the price for the IP coils vs the Okada ...
both clain 100% more spark ....?????
Old Sep 1, 2014 | 04:24 PM
Agbullet25's Avatar
Agbullet25
They're the same coil. Wait for ra2fanatic to chime in as he has the IP coils. But the IP coils are the same as the Okada except for half the price.
Old Sep 1, 2014 | 08:34 PM
ridinDirty's Avatar
ridinDirty
yeah I'm sure he will bite here soon...lolol
I find it hard that they are the same but I'm all ears....
lolololol
Old Sep 1, 2014 | 09:59 PM
Agbullet25's Avatar
Agbullet25
This is what Battle Tuning said when he first got them in:
"Half the price of the "Okada" name, but the same performance under the Ignition Projects branding!"
Old Sep 2, 2014 | 06:38 AM
Grizld700's Avatar
Grizld700
Go to IP's website. It says they just changed their name from Okada USA to Ignition Projects. Same product, get the IP coils.
Old Sep 2, 2014 | 07:38 AM
Club77's Avatar
Club77
May I know the Wedsite or where to get this?
Old Sep 2, 2014 | 08:06 AM
Grizld700's Avatar
Grizld700
http://ignitionprojects.com/
Old Sep 2, 2014 | 08:07 AM
Club77's Avatar
Club77
Originally Posted by Grizld700
Old Sep 2, 2014 | 08:26 AM
ra2fanatic's Avatar
ra2fanatic
hah! Yeah, IP is the US name for Okada. It's the same product, just new branding. Nothing different about them. Okada is still the parent company I believe. Battle helped me order my latest set, so talk to him if you need to order it.
Old Sep 2, 2014 | 08:34 AM
BattleTuning's Avatar
BattleTuning
Old Sep 2, 2014 | 09:18 AM
ridinDirty's Avatar
ridinDirty
So did you pay the 400 bucks using battle or does he get a better price ?
Old Sep 2, 2014 | 10:39 AM
ra2fanatic's Avatar
ra2fanatic
Paid the $400. There are no discounts on something like this.
Old Sep 9, 2014 | 12:14 AM
MNIPWR's Avatar
MNIPWR
Why must they be red!
Old Sep 9, 2014 | 11:52 AM
R53Warrior's Avatar
R53Warrior
any reviews of the coils? Any known benefits to running these instead of OEM?
Old Sep 9, 2014 | 12:14 PM
ra2fanatic's Avatar
ra2fanatic
Better overall spark and much more consistent spark. I feel the difference for sure. One user claimed 11bhp when he dyno'd on the Okadas. I'm a believer of these and at $400 it's worth it, at least for me.
Old Jan 2, 2019 | 09:25 AM
bbm's Avatar
bbm
A must have on Mini Cooper's with upgraded performance parts.
I installed a bigger turbo and Stage 2 dyno tune. Right after that my Check Engine warning light went on as expected. Per an ODCII reader (DashCommand) it is caused by an Oxygen sensor error code, operating over threshold. A year later #1 ignition coil failed (miss fire on cylinder #1). Thus giving me an excuse to upgrade all my coils with Ignition Projects Performance coils. I was hesitant at first because they are expensive, and I was not too convinced with the hype yet. But what the heck. I love my Mini after all.
Ignition Project Coils resolved my cylinder miss firing issues as expected. Unexpectedly my oxygen sensors is no longer giving me error codes as well. Thus the annoying Check Engine light is no longer on. But I am not certain if I gained any horsepower with the coil upgrade, but a few things certain are:
1.) Eliminated Check Engine Light. Regardless of many aftermarket performance upgrades.
2.) Cold start and engine Idle are smoother.
3.) Performance between low to midrange aggressive driving is more refined with no loss of power.
This are my own opinion with no proven data. My conclusion are based on my personal observation. But I know my Mini very-very well, and I can sense if performance has changed negatively or positively. But I will declare that I have noticed positive results, and a self-assurance that money was well spent. This coils are costly and probably overkill for a stock Mini. But I highly recommend this coils if you have an upgraded Mini. But then again this are the best option either way if cost is no issue.
Old Jan 3, 2019 | 04:26 AM
ridinDirty's Avatar
ridinDirty
i feel the same, I didn't try to dyno due to the fact with 3 pulls on dyno my numbers will be within 5 hp of each other and at best they may pick up 1-3 hp.
The mid range seams happier , I never has CEl light due to Manic tune
I did open my plug gaps a bit wider due to the hotter spark and semi butt dyno likes the larger plug gaps
Old Jan 3, 2019 | 07:55 AM
bbm's Avatar
bbm
Before Ignition Projects (IP), I dyno at 280 HP with stock coils. I doubt I will re-dyno, since I couldn't tell the HP difference after IP install. I currently use NGK ILKR8E6 plugs. What plugs are you using, and how wide did you gap it?
Old Jan 3, 2019 | 09:16 AM
mbwicz's Avatar
mbwicz
Ugh, N18 coils are over $600 for the set...……..
Mike
Old Jan 3, 2019 | 11:17 AM
ridinDirty's Avatar
ridinDirty
Same plugs as you (NGK1422) , I will have to go back and see what I wrote down. I played with just a little bit to a good bit. Not sure if your wanting to talk USA or metric but I think I went to .003,.005,007 ths over stock. Seams like .004 or .005 was the final number.
I dyno 313,317,316 all with a 2 minute cool down between pulls. I attached the video, one of the kids in Phx put together, around 1:28 mins get ready to hit the pause and you can see the pulls some what. I also played with indexing the plugs but no butt dyno feel but the plugs come out a lot cleaner looking so possible better Ignition and burn off.
Stage 3 Manic tune, meth injection.
I think I got mine for 400 bucks , shop around. Vivid racing will sometimes knock off some bucks.
Old Jan 3, 2019 | 11:27 AM
mbwicz's Avatar
mbwicz
I've never tried indexing plugs on a 4 valve/cylinder job, where did you point the base of the electrode? I'd assume toward the exhaust side, but you know what happens when we assume.....
Mike
Old Jan 4, 2019 | 01:32 AM
ridinDirty's Avatar
ridinDirty
Just put the gap facing the intake valves, tried to get it in the middle of them . I had time to kill and beer to drink so why not right. Lol
Old Jan 4, 2019 | 03:54 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Mike
Question on this... OEM coils for N14 and N18 have the same part number... why are the IP coils different between the two engines?
Old Jan 4, 2019 | 10:45 AM
mbwicz's Avatar
mbwicz
I asked Ignition Projects about the difference between N14 and N18 coils, and this is the response I received:
Hi Mike,
Thank you for your interest in our products. Regarding your questions, IP-A132403 (cheaper one) is for R55, R56 and R57 models. And IP-A132409 is for R58, R59 and R60 models. Depends on which model you have, the factory coils are difference. The price difference are base on the cost of our material.
I looked up factory MINI coils at an online retailer, and confirmed that the same coil is used for a 2013 R56 and 2013 R60, as well as a 2009 R56 (all S models). So I don't trust the response that was received. The coils seem interesting to me, especially the comments about mid-range driveability. I'm at stage 1 manic, and sometimes have a stumble at around 3k and 50% throttle.
Oh well, more research/thinking to do!
Have fun,
Mike
Old Jan 6, 2019 | 06:48 AM
ridinDirty's Avatar
ridinDirty
Try spraying you MAF sensor off with MAF cleaner. That might clean up your stumble . If you run a pre oil type air filter it will build up on the MAF
