Drivetrain Just installed my ALTA intake
Old Jun 7, 2004 | 05:21 PM
bigpmj's Avatar
bigpmj
I love the sound. Its kick ***. I purchased the tube, and it seems to be resting slightly against the side of the intercooler...I cant figure out how to post pix, or I would put a pic up. Does everyones do this, or should i figure out a way to make sure it isnt rubbing?
Old Jun 7, 2004 | 05:32 PM
bigpmj's Avatar
bigpmj
did this work?
Old Jun 7, 2004 | 05:36 PM
Ryephile's Avatar
Ryephile
Yes, the ALTA CAI is awesome sounding
btw, FYI, you can't host pic's from your PC, must upload to the internet. The NAM gallery is currently in transition.
Cheers,
Ryan
Old Jun 7, 2004 | 05:37 PM
bigpmj's Avatar
bigpmj
I tried to...but the pix wont work. Oh well. But point being, should I be worried about the ALTA tube rubbing, or no?
Old Jun 7, 2004 | 05:58 PM
Nobull60's Avatar
Nobull60
You looked at mine the other day and it does not rub. Twist it some and see if that will work. I know getting the tube on the throttle body is a *****,maybe you need to adjust it there and make sure it flush on the bottom.
Old Jun 7, 2004 | 06:46 PM
bigpmj's Avatar
bigpmj
True NoBull...but I couldnt remember if yours rubbed or not. Ill go out in the garage and play with it a little.
Old Jun 8, 2004 | 05:29 PM
sfjames2's Avatar
sfjames2
Whats up guys, I have the Alta and the tube I have rubs too. I remembered having to cut a bunch of material off to get it to fit right, called Randy @ Webb as well and he assured me that the piece was good and that some of them do rub the side of manifold. I've had mine on there for about 15,000 miles and the rubbing is starting to wear away some of the tube, very little though. If it ends up getting a soft spot in the area that rubs, I'll know then that we have a problem and will see how I get taken care of. take care all! I like the look of this guy.
Old Jun 8, 2004 | 06:26 PM
mtrspt5's Avatar
mtrspt5
Must be lucky...install went smoothly and no rubbbing!
Old Jun 8, 2004 | 09:33 PM
bigpmj's Avatar
bigpmj
I tried to fix the rubbing today...no luck. Oh well. Maybe Ill try shaving some off like you said James.
Old Jun 10, 2004 | 08:59 AM
sfjames2's Avatar
sfjames2
YO , you mean shave the bottom part that fits around the throttle body right. I did not shave the sides to try and prevent rubbing. I was told the rubbing is not an issue.......at least not yet. motor motor.
Old Jun 10, 2004 | 11:00 AM
kenchan's Avatar
kenchan
Someone care to explain why the Alta makes more tone than my Pilo?
Is it the filter?
Old Jun 10, 2004 | 11:41 AM
sfjames2's Avatar
sfjames2
Is it the filter?
not sure EXACTLY why yet, I think its the larger intake pipe and the fact that its smooth inside. I think the stock one's inner ribs coould be quieting the intake a bit. I do plan on trying the K&N filter with the Alta box and tube as I wondered the same thing in the past. I put the Alta mainly because it looked more trick and because except for tube, was free...won in raffle.
We'll see what happens. take care.
Old Jun 10, 2004 | 11:48 AM
dave's Avatar
dave
pug poo picker-upper
Two days ago I enabled attachments, so users can upload pics straight from their PC without needing to go to the gallery.
You can access this function by looking in the "Additional Options" area when you are typing your post. Click on Manage Attachments to select the file from your hard drive and then upload them.
Dave
Old Jun 10, 2004 | 11:49 AM
MrWhoa's Avatar
MrWhoa
The alta makes more noise due to the back bulkhead of the stock airbox being removed with the alta. If you want more sound out of your alta, do the Webb Swiss Cheese airbox mod. Worked like a charm on mine.
Old Jun 10, 2004 | 02:43 PM
kenchan's Avatar
kenchan
MrWhoa - I see. That makes sense. :smile:
AWOL
Mar 28, 2016 10:51 AM
Mib4840
Oct 13, 2015 10:10 AM
stierzy34
Sep 15, 2015 04:40 PM
jrezzo
Aug 9, 2015 10:32 PM
