Drivetrain Cnt highflow downpipe
Old Feb 17, 2014 | 05:55 PM
micromini234's Avatar
micromini234
I was looking at the cnt down pipe and I can't seem to find anything about it on the forums.
Does anyone have any experience with the CNT highflow catted downpipe? I've noticed it has a cat but it doesn't actually say how many cells it has.
Sent from phone
Old Mar 4, 2014 | 03:24 PM
micromini234
I went ahead with the purchase and here are my thoughts.
Its really high quality with TIG welding.
It is in fact a 200 cel cat and will mate up with the stock exhaust and sounds great. At first it will appear the Diameter of the downpipe is smaller then the first cat and the actual turbo, its actually an exact fit when you mate it. As of 200 miles I have not gotten a cel by using one defouler on the top. It is possible that my prior evolve tune somehow got rid of the cel.
I will say in order to get the o2 sensor on the top the welds inside will need to be dremel'd (if you dont use the defoulers supplied) . As well as a portion of the mount brackets to truly get it to fit.
I want to stress be sure to remove all the nuts and bolts from the turbo housing; before matting the the downpipe to the housing. I stripped one of the threads and gave myself an exhaust leak, no fix to that.
Old Mar 4, 2014 | 04:44 PM
scubbysnacks's Avatar
scubbysnacks
I encountered exactly the same problem but as you say easily remedied.
When fitting mine I lightly bolted up the turbo bolts, lower bracket and the clamp to the cat back, that way everything is lined up. Then tightened up the bolts on the turbo all the way first, a small amount at a time on each bolt so it sat flush. The holes on the bracket are slotted and obviously the cat back has a flexible connector so do up the bracket first then the connector to the catback. I used new gaskets and have no leaks.
I got a CEL which I cleared using torque until I got my tune.
Old Mar 4, 2014 | 04:49 PM
micromini234
Ahh that's good to know, now I don't have to buy another update tune haha,
Old Mar 4, 2014 | 05:56 PM
scubbysnacks
Ha micromini234 completely off topic, but did you ever get that second map from Evolve
Old Mar 4, 2014 | 05:59 PM
micromini234
What second map? Lol
Old Mar 4, 2014 | 06:21 PM
scubbysnacks
Sorry, I must have you confused with another member involved in a group buy, he was looking for a more aggressive tune running higher boost. I'll have to go back to the thread to check their user name
Old Mar 7, 2014 | 10:10 AM
micromini234
Update* although no cel is registering, while
Monitoring my scangauge and talking to evolve - and new map is still require to take complete advantage of this downpipe
Old Mar 7, 2014 | 01:10 PM
scubbysnacks
I'm surprised by that because a level 3 Evolve tune requires an intercooler and hi-flow downpipe. So I'm guessing you have a level 2 but when they emailed it to you it came with the title stage 3.
Also to answer your original question the CNT catted downpipes come with a 200 cel cat.
Old Mar 7, 2014 | 01:17 PM
micromini234
I'm surprised by that because a level 3 Evolve tune requires an intercooler and hi-flow downpipe. So I'm guessing you have a level 2 but when they emailed it to you it came with the title stage 3. Also to answer your original question the CNT catted downpipes come with a 200 cel cat.
Honestly; I have no idea at this point. When I had it tuned, it was before the down pipe and fmic. I had the forge and nm parts on, so they said they sent me a stage 3. My phone call suggests that it's not a can tune and they actual remap the whole dme according to those present parts listed. So in theory my car was tuned for diverted valve and nm pipes at the time and I guess that qualified a stage 3 tune. except i was told it's an actual remap based on parts. With that said I'm just confused
Old Mar 7, 2014 | 03:54 PM
scubbysnacks
Ok this what I found on their UK site
Stage 1. 210hp / 30hp & 45lb.ft torque, stock car.
Stage 2. 215hp / 35hp & 50lb.ft torque, intercooler.
Stage 3. 230hp / 40-50hp & 70-80lb.ft torque, intercooler & sports downpipe.
Stage 4. 240hp / 50-60hp & 80-90lb.ft torque, intercooler & decat downpipe.
Stage 5. 250hp / 60-70hp & 90-100lb.ft torque, intercooler, decat downpipe & cat back exhaust.
Stage 6. 260hp/ 80hp & 115lb.ft torque, upgraded intercooler, decat & cat back.
Also in their build thread they added a JCW turbo to the stage 6 modes and map it to approx 290hp. This upgrade and remap is not advertised on their site.
Hope this helps and can be used for future reference
Old Mar 8, 2014 | 05:25 PM
d454brisson's Avatar
d454brisson
I have a stage 3 evolve tune but with the catless dp I am still getting efficiency cels. I just upgraded the intercooler and rest of the exhaust again amd emailed them to see what the cost is to update to a higher stage.
2010 Camden Edition S
Old Mar 8, 2014 | 05:30 PM
micromini234
Originally Posted by d454brisson
I have a stage 3 evolve tune but with the catless dp I am still getting efficiency cels. I just upgraded the intercooler and rest of the exhaust again amd emailed them to see what the cost is to update to a higher stage. 2010 Camden Edition S
That's very odd - in my case I was given a stage 3 tune- then when I stuck my downpipe in I didn't get any sort of cel
Ovrclck
Oct 5, 2015 09:45 AM
GAT
Oct 4, 2015 07:27 PM
potterstein
Oct 2, 2015 09:30 AM
potterstein
Oct 1, 2015 07:10 AM
Nick Royer
Sep 29, 2015 03:01 PM
