Drivetrain Tunes for 2013 R56 S
Old Oct 23, 2013 | 02:15 PM
dcgolfdr's Avatar
dcgolfdr
What companies are making tunes for the r56? I have used Cobb in the past on my Nissan but having a difficult time finding a company for the Mini.
Thanks in advance.
Old Oct 23, 2013 | 03:20 PM
6000pounds's Avatar
6000pounds
You have several threads right below this one about this exact topic
Old Oct 23, 2013 | 09:22 PM
MINI4LYF's Avatar
MINI4LYF
Lenny@Renntech or PAW motorsports or Group4autosports/evolve-automotive/burger-tuning/NM-engineering.
Renntech/PAW/GP4A are all dyno tunes by the talented Lenny. He has programmed ecu's for all these companies. All the same gains, I believe.
Evolve & NM are canned tunes but evolve can tweak some things if you want. Requires ecu to be removed and sent to them.
Burger tuning us a piggyback style tune that is a cost effective solution at $300.
Look them up, figure out what you want from your MINI.
Old Oct 23, 2013 | 09:45 PM
Fast Eddie 76's Avatar
Fast Eddie 76
I too have a 2013 Cooper S. Won't a tune essentially void the warranty?
Old Oct 23, 2013 | 11:47 PM
MINI4LYF's Avatar
MINI4LYF
Yup, pretty much if they find out. But I dont think they would unless they believe the tune caused something to malfunction.
Old Oct 25, 2013 | 12:11 PM
countryboyshane's Avatar
countryboyshane
Search for N18 ECU tune. So many people are crying about this with good reason. Your options are EXTREMELY limited. Focus your buying power on good tires and good suspension. Otherwise, you are going to be extremely dissapointed.
Old Oct 28, 2013 | 09:11 AM
Terry @ BMS's Avatar
Terry @ BMS
Old Oct 28, 2013 | 11:48 AM
countryboyshane
Ha, i'm referring to those the most thirsty for maximum gains. Custom tuning solutions.
Old Oct 28, 2013 | 12:12 PM
RobMuntean's Avatar
RobMuntean
Forget those custom tunes, if I wanted something powerful I would have bought a V8. These engines can't take too much power unless you start upgrading internals. I wouldn't waste thousands of dollars for that kind of issue just so I can beat other cars. A canned tune would be the best thing for these cars and I'm sure you'll agree Shane.
Old Oct 28, 2013 | 12:37 PM
countryboyshane
Yes I do. But there are foolish people that seek to push the envelope because they are greedy for power. I don't think the N18 is even close to the point of people looking to upgrade bottom-ends, trick cylinder heads, cams, hybrid turbos. Those people are the vast minority in the MINI community.
Old Oct 28, 2013 | 02:33 PM
jomama's Avatar
jomama
then just buy the JB+ and crank the pot as far clockwise as possible - that'll get you maximum gains! =)
with all the vendors out there and all their different tunes, the JB+ is easily the best bang for your buck. easy to install, easy to remove, and smoothly delivered gains. couldn't ask for more for $300.
Old Oct 29, 2013 | 06:25 AM
6000pounds's Avatar
6000pounds
Got a 2013 cooper S here with a renntech tune. Will put money against a straight line run against a JCW.
Old Oct 29, 2013 | 07:44 AM
MiniWii's Avatar
MiniWii
Lol the stock JCW doesn't even have much more power than a stock S. I'll bet you a stock cooper S can keep up with a JCW. Your talking about RCH's now
Old Oct 29, 2013 | 08:00 AM
6000pounds's Avatar
6000pounds
Let me get excited I've had it for only a week now
Old Oct 29, 2013 | 02:23 PM
countryboyshane
I don't know if you're being sarcastic or serious but that's a canned tuned. The few people that want to seriously push the envolope with this car will not accept that as a tuning solution since it is not custom tailored to their application. Think big. Cams, head, porting, big turbos. That's at least the advantage that the N14 engine ECU has and Evolve was at the point of being able to do that via remote tuning solutions. It certainly made a lot of people with N14 engine MINIs very happy including me. When somebody finally gets it done for the N18 that will be a blessing.
Old Oct 29, 2013 | 02:32 PM
jomama's Avatar
jomama
totally being sarcastic...partly b/c people repeatedly ask how high they can turn the pot up.
Old Oct 30, 2013 | 11:03 AM
countryboyshane
Oh sorry! Anyways, yes a basic tune is what will sell the best in this market. BMS is going to be making some cash quick
Old Oct 31, 2013 | 09:22 AM
Terry @ BMS
Yes for larger turbos, max gains, etc, they will need to wait for at home flashing or perhaps a JB4 style solution. We've used those to control aftermarket turbos nicely on the N54.
Old Oct 31, 2013 | 09:32 AM
Coop-a-Loop's Avatar
Coop-a-Loop
We want the Mini JB4........when Terry?
Old Oct 31, 2013 | 01:24 PM
Terry @ BMS
No idea on that. I'm looking at few things but the main issue I can foresee at this point is the horrendous install. You'd have to take half the engine bay apart to attach connectors to the appropriate sensors.
Old Oct 31, 2013 | 05:11 PM
Coop-a-Loop
Dang, I'll just have to be happy w/ the JB+!
Old Nov 1, 2013 | 08:46 AM
evilc66's Avatar
evilc66
Does it have to be connected right at the sensor? Why not just make an intermediary harness that plugs between the DME and the harness?
Old Nov 1, 2013 | 09:13 AM
Terry @ BMS
We do that for other applications but for this one it's not practical due to the DME connector system used. We could have people cut wires on the DME but that isn't going to fly. So at this point I think it would need to be direct sensor connections plus a couple removable wire taps for CAN+/-. All theoretical right now. We're looking in to the options to see what is the most practical for the end user. And then we'll weigh the possible success of such a solution to determine whether it's "good business".
Shane Wendel
Aug 17, 2015 05:49 PM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:19 PM
Aug 11, 2015 12:18 PM
