Drivetrain Supercharger delete and n/a wp? 03 MCS
Old Sep 29, 2013 | 11:01 PM
Turbohwagon's Avatar
Turbohwagon
Is it possible to install the water pump and hoses for a naturally aspirated cooper on a MCS that has the supercharger removed?
Old Sep 30, 2013 | 01:02 AM
minsanity's Avatar
minsanity
Why do that? Your charger/pump gears failed? You'll have to do more than just delete your SC to make it run properly. Do the EWP swap & retain your SC like what Raven Mocker did here instead:
https://www.northamericanmotoring.co...-balancer.html
Old Sep 30, 2013 | 07:16 AM
ZippyNH's Avatar
ZippyNH
One it bit of info....
The SC mini (r53) and the non-sc one (r50) has different compression pistions....by lots.
So you would be making a VERY SLOW r50....after you get a custom ecu tune to make it run right...
My suggestion....just fix it. A used sc can be. Had for $500......
Old Sep 30, 2013 | 07:37 AM
Turbohwagon
I'm planning on converting over to a turbo. Supercharger sounds fairly quiet and i don't think there is anything wrong with it at this point.
It seemed like it would be easier to just use an N/A mini waterpump setup instead of wiring an electric water pump.
Old Sep 30, 2013 | 07:51 AM
minsanity's Avatar
minsanity
Chase could give you 1st hand inputs, ask him here:
http://www.motoringunderground.com/f...=1885&page=226
Old Sep 30, 2013 | 07:52 AM
ZippyNH's Avatar
ZippyNH
If I recall right, the connections on the block are in a different spot...so you might need to punch out a plug, and make a blocking plate....
Old Sep 30, 2013 | 07:56 AM
minsanity's Avatar
minsanity
EWP would be simpler.
Old Sep 30, 2013 | 01:45 PM
Turbohwagon
Is the EWP a kit?
Old Sep 30, 2013 | 03:34 PM
minsanity's Avatar
minsanity
Yup, read Raven Mocker's thread. He used the same Davies Craig EWP as the Sprintex SC kit.
06BLKchrgd
GP Talk (2006)
Feb 14, 2016 12:07 AM
gmonde
Sep 8, 2015 06:37 AM
PhoenixR61
Electrical
Aug 22, 2015 05:33 PM
The_Kid
Aug 18, 2015 06:50 PM
