Drivetrain Cooper s r56 exhaust smoke problem
Old Aug 12, 2013 | 01:01 AM
Gtcihad's Avatar
Gtcihad
Dear All ,
I have year 2010 R56 Cooper S (not LCI) ... Now my car is 63K Kilometers ... After some modifications unfortunately i have seen blue-white smoke out of exhaust. First i want to give details what is done to my car ;
-First of all i take my car to service and check everything and changed all fuilds. We have added MOTUL 5-30 Oil ...
-I have custom made catless downpipe
-Forge Dump Valve
-KN Air Filter (in box)
-Ecu Remap
After this modifications i have seen exhaust smoke . But not on the way . When motor is hot , i am waiting a few seconds and when i make full throtle with gear N , a smoke is puffing out. While waiting now smoke also .
I thougt that this is happened because of Ecu Remap and i directly load factory ecu map but nothing changed. I have used my car after ecu remap maximum 100 km and turn back to original . Still i have DP , DV and other parts.
I have also watch videos from youtube 'Cooper s Catless Downpipe' and most of them has a smoke. Is it normal ?
I have take my car to different services and most of them said your 'Valve Steam Seals' damaged. Bu i cant belive that 63K km is possible and you know it is a high cost around 1.500 USD in Turkey . So they can do this for a money maybe.
Do you have any idea about this ? What can be the reason ? Is it normal ?
Reason is downpipe or is it possible to damage some parts after ECU REMAP ? But i drive very very less (100 km )
Thanks for your support in advance ...
Old Aug 12, 2013 | 12:53 PM
Gtcihad's Avatar
Gtcihad
Sorry for 2 threat by mistake k we can continue from here
Old Aug 12, 2013 | 02:54 PM
countryboyshane's Avatar
countryboyshane
Who did the ECU remap?
Did you modify the PCV system?
A bad PCV valve, which is located in the valve cover, could cause this issue too.
Old Aug 12, 2013 | 10:30 PM
Gtcihad's Avatar
Gtcihad
ECU Remap done by a Turkish Guy who is very famous in İstanbul and nearly %80 of Coopers remapped by him and i didnt heart any problem , also it is not very hard tune as i informed boost pressure is max. 1.4 bar.
Actually i also read some articles about PCV valve problem but is there any valve on R56 cooper S ? There is a pipe making a vacuum from motor and as i know connected to manifold directly ? Is there any part to replace on PCV system of R56 ?
Old Aug 12, 2013 | 11:21 PM
Gtcihad's Avatar
Gtcihad
This is a pic. of my motor ...
Old Aug 13, 2013 | 12:50 PM
HorizonBLueN18's Avatar
HorizonBLueN18
1.4 bars is something like a hair over 20psi. That's dangerous territory. Especially with a stock intake and stock intercooler. The k&n drop in intake is good but it will still create a vacuum and be starved for air. I can't imagine how much timing your car pulls. Is it an automatic as well? Have you pulled your plugs to see if they are fouled or extremely dirty? Do you have a boost gauge and if so are you still making full boost on the stock tune?
Old Aug 13, 2013 | 01:45 PM
Gtcihad's Avatar
Gtcihad
My car is automatic , i have used my car maximum 100 km after remap but when i see smoke again load factory map but nothing change. My car is automatic also . İ have fouled out pcv pipes and some of oils inside. This week i am thinking to assemble oil catch can ...
Weather is very hot in turkey nowadays around 40 celcius, maybe this can also effect?
My pRoblem is as below videos , on this videos everything looks normal for that car owners because videos are only to show sound.
İs that smoke normal on that videos. İs it possible to happens because of pcv system and because of catless dp happens a smoke ?
Old Aug 27, 2013 | 12:34 PM
Gtcihad's Avatar
Gtcihad
Can you see the videos if possible ? İs it normal to have this kind of smoke after catless dp . İ have assembled original catalysator and my smoke completely went .
Old Jul 23, 2016 | 05:53 PM
Mfsaleh's Avatar
Mfsaleh
Mini cooper s r56 2010
Hi,
Please can you help !
I have a Mini cooper s r56 2010 with a catless Downpipe .. Before installing the DP there was a white smoke going out of exhaust pipe when i do some revs while car is on neutral mode .. With a smell nearly to gas smell .. This happened to me after i changed oil and oil filter i put Castrol professional edge synthatic oil (Gold) and factory oil filter .. Next day it starts smoking white smoke .. And after installing DP the smoke didn't disappear .. Until now the car still smoking .. Can you help me .. Cause i read your post and i felt that it is similar to my problem .. Please if you can help me .. I'm really mad from my car .
Jan 4, 2019 12:51 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
