Drivetrain Burger Motorsports (BMS) Tune(s)
#1526
Starting tomorrow il have a means of measuring and data logging things for my cooper S. My obd reader will be in and il be using dash command on my iPad.
So here's my question in particular about timing which I know absolutely nothing about.....
I have a few mods on my car, Alta CAI, hot side tube, and Magnaflow catback, I filled up with 10 gal of 91 and 2ish of E85 last time which will allow me to turn up the JB+ slowly to 100%. (Correct) I keep hearing to keep a eye on timing so I just need to know what exactly to look for?
Thanks in advance guys!
#1527
I was driving past Mojave yesterday morning on 58 and was behind a big rig for a few miles until a passing lane came and I dropped two gears and tried passing the rig and then suddenly I had no power. I pulled over, turned the car off and back in and everything was fine. I data logged from then on and I was peaking at 21.6psi. I believe I hit the 22psi limit. The outside temp was 5 degrees Celsius.
Or did the yellow half engine light come on?
Felt like you deployed a massive parachute?
#1528
Yes the light blinked and felt like someone hit the brakes for me.
#1530
[QUOTE="HorizonBLueN18;3870601"] That's only a 16% mixture. I wouldn't turn up the jb+ at all with that mix. Since it's made for 92 and BMS recommends turning it down to 40% for 91, I would just keep it at 50% and watch it from there.I'm running 27ish% with the jb+ at 80%. No drops in timing and car runs great. Knock code hasn't gone off once. But when temperatures get warm I can see me turning it down to 70%.[/QUOTE
What mix are you using to get 27%ish? I have been doing 3 gal of e85 and the balance 93.
#1531
So pretty much no codes will be stored if boost is cut, what you most likely experienced.
He also told me that JCW's can see up to 30psi(which is obviously not advised) so a GP/JCW won't cut when it hiccups over 22 unlike is "S" folks.
Possibly try 1 hash mark back from max. That might give you the head room to over boost without a cut.
But Terry advised 18psi all day.
#1533
I messaged a member who use to be on here a lot, not so much anymore, lots of respect for him. Knows a lot. So pretty much no codes will be stored if boost is cut, what you most likely experienced. He also told me that JCW's can see up to 30psi(which is obviously not advised) so a GP/JCW won't cut when it hiccups over 22 unlike is "S" folks. Possibly try 1 hash mark back from max. That might give you the head room to over boost without a cut. But Terry advised 18psi all day.
I read somewhere that someone was able to defeat the boost lit cut but haven't seen what that solution was.
#1534
#1535
True. I'll data log it and play it safe incase it reaches too high of a boost. It'll be interesting to see what happens when it gets warmer.
#1536
I won't be planning an early retirement based on N18 tune sales but it has covered it's costs and pays for our MINI which myself and other BMS employees get to race around. So I'd say it's been a worthwhile endeavor.
We continue to play with possible higher stage tunes but so far have not hit upon the right mix of power gains over the JB+, cost, & ease of install to justify a higher Stage. But we'll continue to keep the gears turning there.
A version for the N14 would add a lot more potential buyers! I actually like items like this that make small tweaks rather than reflash the factory software. It somewhat retains the factory safeguards instead of removing them entirely.
With my luck, if I bought a tune, I would get the copy where they fat fingered a number and missed the decimal. First run out, I would light up the 'get the shovel light' ( to scoop up my pistons and rods from off the road).
Sent from my XT926 using NAMotoring
#1537
oh you aren't the first :-). The N18 'exploit' doesn't work on the N14. Never seen Terry mention they're working on a N14 JB+ but you never know. You could search for a used accessport, not as easy to find but at least you'd have multiple maps to choose from presumably since it's been out for a while.
#1538
#1540
#1541
I'm tempted to try a few things on my own. I used a rheostat in the past to adjust a barometric pressure (on a totally different platform) to adjust AFR. I've also made boost controllers from scratch for other systems. I'm still fairly new to my MINI though.
#1542
#1543
#1544
#1546
#1547
if you didn't let the car go to "sleep" before you plugged the JB+ in, you can expect a CEL...just wanted to throw that out there.
#1550
Installed the JB+ about a week ago on my 13 JCW. The car has DOS intake and 2nd CAT delete. Been running Torco with 91 and getting about 98 octane. So far i have turned the pot up to 80% and the car pulls like a beast. Timing looks good. At full boost is about 6 to 7 degrees and increases to 9 degrees by redline. Planning on getting a bigger intercooler and running 100% on the JB+ in the future. As soon as I install the intercooler I am going to get a few dyno pulls in so we can have a good comparason of the JCW vs the GP2 (mariokart)
