Drivetrain DuelL AG intake mod
Old Jun 9, 2013 | 08:54 AM
KilmerPT's Avatar
KilmerPT
I was browsing through DuelL AG's pics posted on FB and came across this pic of what looks like a NM intake (well the filter sort of looks like it's a NM intake lol), but they placed it where the coolant reservoir is usually at and vice versa. Does this make it more effective by placing it here like the pic? And if that is the case, why don't the rest of these companies that make aftermarket intakes do the same?
Old Jun 9, 2013 | 09:29 AM
jkapinos's Avatar
jkapinos
That is part of a Garrett turbo kit.
Old Jun 9, 2013 | 12:49 PM
MinMin2010's Avatar
MinMin2010
The intake that DuelL AG uses with the factory turbo, as does a lot of R56 owners in Japan, is the NM Intake system.
https://www.facebook.com/photo.php?f...type=3&theater
This is Cosque's R59. You can see the NM intake and NM Titanium heat shield.
Old Jun 9, 2013 | 01:13 PM
KilmerPT's Avatar
KilmerPT
So is it in fact more effective when they place it more towards the front of the engine compartment where the coolant reservoir is?
Old Jun 9, 2013 | 01:20 PM
yetti96's Avatar
yetti96
Disadvantages include still bringing in hot engine bay air, short pipe means more turbulent air flow, and have to relocate reservoir.
Old Jun 9, 2013 | 01:22 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Is getting to oil filter housing for changes any easier ?
Old Jun 9, 2013 | 01:36 PM
MinMin2010's Avatar
MinMin2010
Here is the skinny on the short intake system.
Direct Air System - Intake (For R55-R57 S/JCW pre 2010.5)
​The DuelL AG DAS intake utilizes an aluminum trumpet shaped intake pipe and hybrid-steel air filter to maximize turbo performance. By significantly reducing the length of the intake pipe the DAS increases air-flow potential while drastically reducing turbo lag. For MINI's with upgraded turbos or DME tuning, the DAS will ensure optimized air flow under all conditions.
To find out more, you may want to contact Vince at DuelL AG North America.
Old Jun 10, 2013 | 04:07 PM
borderwave2's Avatar
borderwave2
Does this system eliminate/relocate the AMM?
Old Jun 10, 2013 | 04:32 PM
MinMin2010's Avatar
MinMin2010
This system does not allow for the AMM sensor as you can see.
This system is primarily for European and Asian spec cars. There is even talk that DuelL AG may be doing away with this product since the NM Engineering system has become the standard over there. The only cars they seem to be using the DAS on are those with the Garrett Turbo Upgrade and DME Tuning Upgrade.
Old Jun 10, 2013 | 06:12 PM
borderwave2
Thanks for the reply. Do Asia/EU cars not have an AMM at all?
patsum
26
May 29, 2021 06:29 PM
rtk90
Aug 29, 2019 09:08 AM
COOPT UP
Sep 11, 2015 04:59 AM
larryd96
11
Sep 8, 2015 05:01 AM
