Drivetrain Can't pass smog!!
Old May 8, 2013 | 12:55 AM
  #26
mikemc's Avatar
mikemc
Originally Posted by Deluded
I can give you guys more details about what's needed to complete a full system readiness status, if you guys want it.
Hello to you, local LB guy!
Please and thank you!
It puts a to see so many in SoCal on NAM.. San Diego
Old May 8, 2013 | 01:12 AM
  #27
Deluded's Avatar
Deluded
I forgot how many items are there in the mini cooper, probably around 7.
When you reset all DTC from the cooper, you also wipe the readiness status as well... so everytime you wipe the check engine light, you have to drive the car for about 100 miles or so (actually, 20-25 miles will do the trick, but I've had to drive cars for well over 300 miles to complete the readiness check, so 100 is a good middle ground).
http://www.europeantransmissions.com...0Procedure.pdf
This is a good start. Normally, after 100 miles of mixed driving (by mixed, I mean half street, half freeway. If driving on freeway, keep it at 65 or below. Drive too fast, and the computer will suspend the monitoring until speed drops below 65), you'd have everything done except for the Evaporative vapor recovery.
The evap is the most finicky system monitor to pass. For that, you need to fill up the gas tank anywhere between 50-75% -- and ONLY between that.
Secondly, you'd need to do a cold start -- ie, coolant and engine temps at ambient temp, with gas tank between 50-75%. Then drive for 20-ish miles. Even then, double check.
I can't tell you how many times I've had my smog guy tell me he can't smog my car unless the evap test was completed.
Old May 8, 2013 | 01:31 AM
  #28
mikemc's Avatar
mikemc
the tester told me to drive it around also on both street and freeway for a while.. but he still charged me for both fails so im loking for a more sure thing result... anyone ever heard of or used that "Guarantee to Pass" additive from the auto parts store? I guess you mix it with a full tank and it supposed to clean out the shmegma and get your borderline results passed through? I was also recommended that. I read up on it.. It had some say it was helpful. other said it was helpful after they changed spark plugs and oil, ect ect.. basically helpful after a tune up
Old May 8, 2013 | 02:29 PM
  #29
Deluded's Avatar
Deluded
No, they don't really help. What you really need is a catalyst. Those addictives are helpful only if you have a gross polluter car, already have a catalyst and retuned your engine and you STILL fail smog... then yes. Use that.
Basically, those kind of addictives are best used on old cars have difficulty passing smog regardless of their condition. 1988 190E 2.3-16v comes to mind.
Old May 10, 2013 | 11:00 PM
  #30
mikemc's Avatar
mikemc
actually got it to pass! after losing more hair took it to my buddy who is a mechanic and also does smog checks..first i reset the maps back to stock, then disconnected the battery for a few minutes (there was no real method for this I just thought I would try it), reconnected everything and with the stock map drove it there to his shop. he cleaned the spark plugs up a bit, opened up the gas door and took the cap off so it didnt pressurize (not sure if that what it does), and rev'd for a few minutes to warm it up more. while on the smog machine he ran it in a higher gear so the boost would fire out (thanks Mike@Tech Division cause I read him your post reply) and then started the smog check. all my levels were at there limit with absolutely no wiggle room but ...it still passed... so i was at the max allowed but it was still a drop from the first 2 smog checks.
THANKYOU TO EVERYONE FOR THERE SUGGESTIONS, I LOVE THIS SITE! LETS MOTOR!
Old May 11, 2013 | 04:42 PM
  #31
Richieb0y28's Avatar
Richieb0y28
I'm glad you finally passed. Not sure how it works in CA, but we have inspection every 2 years here in NJ, it's typically just swap your downpipe and pass emissions. Hopefully I don't have to go through what you did.
Old May 11, 2013 | 11:37 PM
  #32
mikemc's Avatar
mikemc
I hope not either... And I hope this was just a fluke.. Debating if I should still look for a used one or not. Sucks to have the part just sitting around but it may be worth it...
Old May 12, 2013 | 12:41 AM
  #33
Deluded's Avatar
Deluded
You passed smog with no cats?
I'll bet it was borderline. You're lucky.
Also, definitely source a used cat or DP -- you never know when you'll need it. I see way too many mobile smog stations (the ones that cops pull you over for a mandatory testing) around here to be too comfortable running catless.
Old May 12, 2013 | 09:26 AM
  #34
ZippyNH's Avatar
ZippyNH
Buying a used cat is iffy....make sure the owner NEVER used high octane racing fuel...it is leaded...if they have, the cat is useless....and buying a used cat is technically illegal...
But if it is included cause you are buying a part bolted to it..gives it a,veil of legality.
Old May 14, 2013 | 08:12 PM
  #35
rs53's Avatar
rs53
Not ALL high octane racing fuel is leaded
Old May 14, 2013 | 08:36 PM
  #36
mikemc's Avatar
mikemc
Yup, here are the stats with the after market DP
Old May 15, 2013 | 04:43 PM
  #37
NewCooperFanatic's Avatar
NewCooperFanatic
The beauty of ULEV vehicles.
Suck on that to all you tree hugging hipsters...catless car legitimately passed smog in the toughest state in the country!
Congrats mikemc lol
Old May 15, 2013 | 05:08 PM
  #38
Richieb0y28
Haha thats awesome
Sent from my DROID BIONIC using NAMotoring
Old May 15, 2013 | 05:32 PM
  #39
mikemc's Avatar
mikemc
Congrats mikemc lol
IrishMCS
Dec 1, 2015 04:21 PM
Rycase
Oct 14, 2015 02:11 PM
brads2002
Oct 14, 2015 06:53 AM
randeez
Oct 5, 2015 09:23 AM
cjny
Sep 21, 2015 01:28 PM
