Drivetrain clutch/brake bleeding
Old Apr 17, 2013 | 03:41 PM
kadaj's Avatar
kadaj
hello
I plan on bleeding my brakes this weekend and also do the clutch while im at it... can someone please help me with the clutch, is it the same process as the brakes? where is the valve located? is the master cylinder the same as the brake fluid?
Thank you
Old Apr 17, 2013 | 06:47 PM
kadaj's Avatar
kadaj
any links to DIY? anything?
Old Apr 17, 2013 | 06:57 PM
Braminator's Avatar
Braminator
Maybe this will help
http://www.pelicanparts.com/techarti...ing_Brakes.htm
As far as the clutch. Don't do it unless you are 100% sure you are prepared.
https://www.northamericanmotoring.co...he-clutch.html
Old Apr 17, 2013 | 06:59 PM
Braminator's Avatar
Braminator
Here is a video if you attempt it.
http://videos.doityourself.com/video...Tips-208498217
Old Apr 17, 2013 | 07:36 PM
kadaj's Avatar
kadaj
well i wanted to do it cuz it feels smushy... bvut you scared me... idt ill do it
Old Apr 18, 2013 | 04:22 AM
countryboyshane's Avatar
countryboyshane
If you want to bleed the clutch slave correctly, you'll need something to hold the plunger in while you use a power bleeder and then open the bleeder screw.
Old Apr 18, 2013 | 05:25 AM
Swimbaxter's Avatar
Swimbaxter
This part is critical. I unbolted the slave and used two long bolts, two wing nuts and a metal strip with holes drilled for the bolts and a larger hole drilled for the slave piston to seat in. Make sure to angle the bleed screw upward when bleeding so any trapped air has an easy exit route. All the nuts bolts etc were less than 5.00 at my local hardware store. The wing nuts made it pretty easy to compress the piston. Good luck. It's pretty easy and can really make a difference in feel. I trust you will be flushing all the brake fluid at the same time, right?
Sent from my iPad using NAMotoring
Old Apr 18, 2013 | 07:29 AM
Helix13mini's Avatar
Helix13mini
The clutch bleed is not what I would consider a good candidate for a DIY job. If it goes wrong, you've got a huge headache. Read the various threads on it before attempting.
Old Apr 18, 2013 | 02:34 PM
kadaj's Avatar
kadaj
sent you a pm!
Old Apr 26, 2013 | 08:43 AM
minilovr's Avatar
minilovr
screwed up clutch bleeding
I screw up the clutch bleed by first not removing the slave and second by not having fluid in the bleed hose before opening the valve. Result was a pedal that went right to the floor without any resistance. I then removed the slave and compressed as described in another post. I tried pressing and very slowly releasing the pedal alternating with the valve open/closed. No matter how slowly I released the pedal air was being drawn into the system which I later figured out was coming in through the seal in the slave cylinder. I finally reverse bleed the system by forcing fluid in through the slave cylinder - with the slave compressed and the pedal in the up position. That worked. Lesson learned.
Old Apr 26, 2013 | 10:01 AM
Swimbaxter's Avatar
Swimbaxter
You learn more from our mistakes than you do from your success's. I had the benefit of a power bleeding tool when I did it. does it feel better than it did when you started?
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
Rohdeandschwarz
Nov 5, 2015 07:58 AM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
Indimanic
Aug 19, 2015 11:08 AM
Gipper
Aug 8, 2015 05:39 AM
