Drivetrain Helix Wildebeest TurboKompressor Update
Old Oct 9, 2012 | 08:40 AM
Ambient Thermal Management's Avatar
It has been a while since I posted any updates on the Helix Wildebeest however a lot has happened. I have found that the electric oil scavenge pump for the rear mounted turbo is unreliable. During a high speed run, the pump failed. As a result the excess oil being pumped to the turbo pushed past the turbo seals and exited out the exhaust. Engine Oil + Hot Exhaust = FIREBALL. Another unfortunate side effect is engine oil starvation. My cyl1 rod bearing had spun.
Since then I removed the engine and took it to my engine machine shop called Mardinly located in Broomall PA. Paul from Mardinly did a great job with regular updates, pictures during the process, informing me of any issues, and offering corrections for them. To top it off, the whole process took only 1 week. Below are some pictures of the machining and assembly process.
The head was decked, given a new valve job, new seals, and new guides. Name:  LS1ENGINE017.jpg
The crank was ground and polished to remove any blemishes.Name:  MINISC003.jpg
I chose to go with Weisco .020 oversized pistons, Pauter forged rods, and ARP studs. (Side Note: The Pauter rods had to be machined a few thousandths to clear the Weisco pistons).Name:  MINISC005.jpg
I had chosen to relocate the turbo to a conventional location next to head. I also replaced the failed 60-1 turbo with a new GT2871R.Name:  Readytogo.jpg
The Beest is hungry to get going NOM NOM NOM.Name:  NomNomengine.jpg
I wish I could say that everything was perfect after all of this, but it was not the case. Name:  TurboNewHome.jpg
The turbo wastegate was not flowing enough and causing over-boosting of 28psi peak. I had to port the wastegate.Name:  WastegatePort1.jpg
In this picture you can see the bell mouth porting I did on the wastegate port.Name:  WastegatePort2.jpg
I also removed the divider on the downpipe. This will allow the wastegate air to exit through its own port as well as the primary tube.Name:  DownpipePort.jpg
I bell mouthed the sections of the downpipe tubes that did not mate with the turbo flange for good measure. I also belt sanded the flange flat.Name:  DownpipePort1.jpg
As a result I now build and hold a solid 21psi of boost @ WOT and the car goes like a Raped Ape. I’ll be hitting the dyno soon to dial in the air/fuel ratios. For now they are around 10.9:1. I’ll update with the final numbers. Soon after that I will be doing an E85 tune with 28-30psi of boost.Name:  BattleHardened.jpg
Size:  76.0 KB[/SIZE]
Old Oct 9, 2012 | 10:37 AM
FrenchyR53's Avatar
FrenchyR53
Insane! Love it! Had the privilege to briefly meet you and the beest this past saturday at Helix. Seeing the Wildebeest is believing I say! That thing is a monster!
submitaweasel's Avatar
submitaweasel
Subscribed. Ive been loving this project since I first saw it. Cang wait to see the dyno numbers. Good work.
Old Oct 9, 2012 | 02:42 PM
ColinGreene's Avatar
ColinGreene
Sorry to hear of the failure nice to see you back on the road though, let us know how the new pistons and rods work out!
Old Oct 9, 2012 | 04:39 PM
paul_'s Avatar
paul_
This car is nuts. I see it every now and then, and I'm not at liberty to say how many of those sightings led to me popping a stiffy.
Wait what?
Old Oct 12, 2012 | 03:05 PM
NEWS FLASH 300whp 245wtq
Old Oct 12, 2012 | 03:34 PM
Bytetronik's Avatar
Bytetronik
That's good power. 93 octane and stock ecu?
Old Oct 12, 2012 | 07:48 PM
As promised. The lower curve is the first pull. The car didn't make as much boost as it did on the street so we bumped it up (from 19psi to 21psi). We also leaned it out from very rich 10:1 to the now 12:1 AFR.
Old Oct 15, 2012 | 06:59 AM
FrenchyR53's Avatar
FrenchyR53
Nooooiiiiiiiiiiice!!!!
Old Oct 15, 2012 | 11:32 AM
fishbulb's Avatar
fishbulb
That thing looks killer before you even find out it also has a turbo!
Old Oct 15, 2012 | 11:39 AM
The car has a stock ECU that was previously tuned by Jan for pulley setup. I am tuning with a piggyback ontop of Jan's flash tune. I am seeing a peak of 22 degrees advance @ WOT. I am running 650cc injectors. I am running 93 octane but I am also injecting denatured alcohol when I hit 9psi+. I need up upgrade the fuel pump so I can supply enough fuel for E85.
Old Oct 15, 2012 | 11:43 AM
Well the torque has some toll. My driver's side inner CV joint is spewing grease and the lower control arm front inner balljoint is shot. I ordered a new axle and ball joint for $100. Hopefully that will take care of that new vibration I've been having.
Old Oct 15, 2012 | 11:45 AM
Bytetronik's Avatar
Bytetronik
That thing would be a monster on E85
What clutch are you running on that beast?
Old Oct 15, 2012 | 12:04 PM
Stock style dual mass.
Old Oct 15, 2012 | 09:15 PM
Trickle X's Avatar
Trickle X
What is this turbo thingy you speak of??
Helix13mini
Jul 27, 2016 06:29 PM
02miniSguy
Nov 17, 2015 10:29 PM
matt12mcs
Sep 21, 2015 05:35 AM
Helix13mini
Sep 18, 2015 12:52 PM
OutMotoring
Sep 8, 2015 06:27 AM
