Drivetrain Will anyone code out a CEL from a DP?
Old Sep 23, 2012 | 09:24 AM
  #51
ra2fanatic's Avatar
ra2fanatic
Originally Posted by MiniBOL
They replaced the whole engine with a refurb.
Hm....doesn't hurt to have the manifold removed to inspect the quality of the refurbed unit. You can always give my friend a call at his shop to have it checked out.
Originally Posted by jkapinos
The good thing is the R delete that Akrapovic makes, works even on a 2013.
I don't even know anyone that actually bought the module. Did you actually get it!?
Old Sep 23, 2012 | 10:54 AM
  #52
jkapinos's Avatar
jkapinos
Yes, working fine after a few hundred miles so far.
Old Sep 23, 2012 | 11:03 AM
  #53
automan21's Avatar
automan21
Does that Delete-R remove the cel and prevent the code from coming up? I've seen a pic of it and it seems to plug into the obd2 port. Am I correct?
Old Sep 23, 2012 | 11:54 AM
  #54
jkapinos's Avatar
jkapinos
Yes it plugs into the odb2 port. I had a brief P0420 but it went away in a few minutes. Not sure how it works as I've only had it one week. I purchased a scangauge II as well. I installed the scangauge today and it has a pending DTC but no light.
Old Sep 23, 2012 | 02:14 PM
  #55
calforhelp's Avatar
calforhelp
So the Delete-R actually works? That's good to know. So according to the instructions it looks like you still retain the OBD2 functionality and nobody would really know the module is installed unless they take apart the dash.
jkapinos, it looks like you have a 2013 R59 S is that right?
Old Sep 23, 2012 | 03:59 PM
  #56
jkapinos's Avatar
jkapinos
Yes. I'll post up what it does in the future, as it's only one week old. I have a Scangauge II installed, so yes the odb2 still works as normal.
Old Sep 23, 2012 | 04:09 PM
  #57
calforhelp's Avatar
calforhelp
My car was not listed in their AutoLogic OBDII coding unit so talking to Rene at the shop he said that, for any SoCal peeps, you can bring in your ride and get it checked, if you fit either MF1 or 2, then they can clear it.
Unfortunately at this time, MF3 vehicles cannot be removed at this time. He did show me that in the AutoLogic, that had MF3 been in the system, there was a screen that shows the code could be deactivated.
Cool! I didn't even see your response above until just now. Where is this shop where you've been working?
Old Sep 23, 2012 | 09:14 PM
  #58
ra2fanatic's Avatar
ra2fanatic
Nah, I don't work there. Remember, I work in the film industry. I just go to his shop all the time when I'm not working. He's in El Monte, CA (San Gabriel Valley). Glendale isn't too far. 210, exit Myrtle and just head south.
Old Sep 23, 2012 | 09:25 PM
  #59
calforhelp's Avatar
calforhelp
Oh no, I knew that I meant to say where's this shop where you've been working on this? Don't worry, I didn't forget lol.
That isn't too far. Do you have the name or exact address?
Old Sep 23, 2012 | 11:24 PM
  #60
ra2fanatic's Avatar
ra2fanatic
LTBMW now LTMW. My friend Long has been referred to in 3 separate issues of European Car Magazine and is participating in European Car Tuner GP shoot out with a custom wide body, single turbo, 600+hp E90 335i.
Reviews on the shop courtesy of yelp.
http://www.yelp.com/biz/ltbmw-el-monte
5442 N. Peck Rd.
El Monte, CA
Old Sep 23, 2012 | 11:42 PM
  #61
calforhelp's Avatar
calforhelp
Awesome, thanks for all the help! He's only 18 miles from me, I'll have to call him and get a time soon to stop by and see if my light can be turned off!
Thanks again!
Old Sep 23, 2012 | 11:45 PM
  #62
ra2fanatic's Avatar
ra2fanatic
If you do go in hit me up. I can stop by the shop since I literally live 10 mins away. My friend Long always tells me about MINI people that stop by whom I refer.
I'm sure they'll dig the matte white wrap too. They love my MINI and they are considering a MINI for the shop ever since I started to mod mine. They can see the potential from them. They're looking for a LSD equipped MINI though =P
Old Sep 23, 2012 | 11:46 PM
  #63
calforhelp's Avatar
calforhelp
Will do for sure.
Old Oct 1, 2012 | 02:19 PM
  #64
NewCooperFanatic's Avatar
NewCooperFanatic
Wow so that Delete-R works? Sorta pricey though. Need my catless ED DP asap! Wonder if RMW can delete the CEL?? hmmm
Old Oct 24, 2012 | 07:20 PM
  #65
calforhelp's Avatar
calforhelp
So I went down to LTBMW to try to get my oil pressure adapter for my gauges installed and to check on the CEL situation.
Firstly Rene ended up giving up on the gauge adapter since it is so unnecessarily difficult to get to.
And my car is too new to have the CEL disabled, it wasn't compatible with the autologic tool like your '10 was. It kinda looks like the Akrapovic Delete-R may be the only option.
I'm going to try this little do-dad out and see if it helps at all. NM said most of their VW customers use one of these and it works for them.
http://www.etektuning.com/42-draft-o2-sensor-spacer/
Old Oct 31, 2012 | 05:21 PM
  #66
Hujan's Avatar
Hujan
Any updates on this? I am interested in getting the Delete-R. Just want to be sure it doesn't suppress all CELs, and only prevents the CEL from coming on for the P0420 code.
Also, jkapinos, what car do you have? You said it is a 2013. Is it a JCW or an "S"?
I have an UltraGauge, but it won't read the codes on my car (an R60 built on 4/2012). I wonder if the changes to post-February 2012 ECUs may be affecting the UltraGauge's ability to read codes? If so, I fear it might affect the ScanGauge as well. That's why I'm interested in knowing what year/model you have.
Old Aug 26, 2013 | 01:06 AM
  #67
RanMini's Avatar
RanMini
Hi,
so did you try the 42-draft spacer? Is it working good?
Old Aug 26, 2013 | 01:09 AM
  #68
RanMini's Avatar
RanMini
Hi jkapinos,
please report how the R-delete work for you up to now?
Old Oct 2, 2013 | 12:14 PM
  #69
6000pounds's Avatar
6000pounds
I have a stupid question I don't want to make a new thread for and is somewhat related. The akroprovic delete r module and the 400 price tag. I was looking at the akrpprovic exhaust and the benefits of a cat'ed DP. It seems to throw a code and no one wants to see that on a newer mini especially.
I was reading some testimonials of a CEL never coming on related to the O2 sensors and some people saying it came on several times even with the delete r module. Does that mean the delete r module isn't blocking the code sometimes or just lets it through whenever?
Why not buy a 20-40 dollar OBD2 cable and clear it yourself with a smart phone vs a 400 module that only clears one thing?
Old Apr 28, 2014 | 09:43 PM
  #70
wzabrouski's Avatar
wzabrouski
So I went down to LTBMW to try to get my oil pressure adapter for my gauges installed and to check on the CEL situation. Firstly Rene ended up giving up on the gauge adapter since it is so unnecessarily difficult to get to. And my car is too new to have the CEL disabled, it wasn't compatible with the autologic tool like your '10 was. It kinda looks like the Akrapovic Delete-R may be the only option. I'm going to try this little do-dad out and see if it helps at all. NM said most of their VW customers use one of these and it works for them. http://www.etektuning.com/42-draft-o2-sensor-spacer/
Did the etek piece work for you?
Old Apr 29, 2014 | 08:26 AM
  #71
calforhelp's Avatar
calforhelp
I actually never got around to trying it out. I've just been living with the CEL.
Old Apr 29, 2014 | 08:37 AM
  #72
wzabrouski's Avatar
wzabrouski
How are you passing your inspection?
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
rob&JCW
Oct 9, 2015 11:12 AM
Enjoytheride
Sep 17, 2015 12:10 PM
Nick Royer
Sep 16, 2015 08:17 AM
