Drivetrain Replacement filter for Alta Intake.. Follow up
Old Mar 24, 2004 | 05:25 AM
cfoley's Avatar
cfoley
I have just recieved my K&N filter (RU 1520) That Andy Recommended To me tho fit on my Alta Intake. IT is GREAT!!! the fit is perfect, the sound is much better (less whooshing, like a 1967 olds 442 w/o an air cleaner) and the performance and S/C whine is as strong as ever. I would definitely recommend the change from the Alta foam to the K&N gauze.
Andy @ Ross tech, thank you again and Minifletch I also appreciate your input. You may want to take a look @ andy's setup. https://www.northamericanmotoring.co...ic=23873&7
Craig
Old Mar 24, 2004 | 06:57 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
One of these days, I'll do some logging to see if there is any flow difference between the UNI (Alta) and K&N filters.
Old Mar 24, 2004 | 07:02 AM
samawil's Avatar
samawil
I have the new alta intake (no gauze around the filter) will this replacement filter also fit on that?
L
Old Mar 24, 2004 | 07:03 AM
andy@ross-tech.com
No clue, measure the pipe diameter and the amount of space for the filter.
Old Mar 24, 2004 | 01:17 PM
MrWhoa's Avatar
MrWhoa
Ill see if I can dig it up, but I read this article where a big time japanese tuner did a comparison on filter elements. The results were, atleast for the initial clean filters, that the foam flowed better but let more crap in. So based on that I try to not use foam intake elements.
Old Mar 24, 2004 | 08:14 PM
friedduck's Avatar
friedduck
MrWhoa,
I think that's backwards--or at least contrary to the last independent test I could find. I'll see if I can dig it up, but it was essentially that gauze flowed better initially, but loaded up more quickly and passed more material.
I'll post back when I find the reference that I had. It's tough to find independent #'s for these things. If you can find the test please do the same.
Jeff
Old Mar 24, 2004 | 08:32 PM
friedduck's Avatar
friedduck
Well, that's embarrasing. I posted on the subject last year. See this for the last time we discussed.
If someone wants to pop for testing some mini-specific filters I'll chip in. It'd be good to get non-sponsored data.
Jeff
Old Mar 25, 2004 | 07:10 AM
ABTsportsline's Avatar
ABTsportsline
i am confused...
is this more of a sound/appearance thing, or are there performance gains to be realized from this?
cheers
-ABT-
Old Mar 25, 2004 | 07:32 AM
samawil's Avatar
samawil
I thought this was more of a "is it better to replace the filter each time or clean it?"
L
AWOL
Mar 28, 2016 10:51 AM
tr3y003
Oct 22, 2015 10:48 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
stierzy34
Sep 15, 2015 04:40 PM
minipopkart
Aug 13, 2015 05:22 AM
