Drivetrain Gauge readings
Old Mar 24, 2004 | 09:24 PM
Arly's Avatar
Arly
I just installed two gauges that read oil and boost. What readings are any of you out there getting at idle? I am checking to see if there is any leaks. For the boost gauge at idle, the gauge is reading -15 or so. Oil pressure is around 23 psi.
Thanks all in advanced.
Carl
Old Mar 24, 2004 | 09:30 PM
d6-mcs's Avatar
d6-mcs
what gauge pod did you use. the promini??
Old Mar 24, 2004 | 10:02 PM
TonyB's Avatar
TonyB
Assuming you mean 15 vac, those two readings are pretty much right what I get at idle....
Old Mar 25, 2004 | 06:15 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Oil pressure varies considerably with oil temp.
Vacuum runs about 15 in. at startup (fast idle) drops to around 20 in. at normal idle. On the overrun (engine braking) it may drop to 25 in.
Old Mar 25, 2004 | 10:01 AM
Arly's Avatar
Arly
I bought the pod set and gauges from a guy in Cleveland, OH. His name is Dennis Ruvolo. I was in town and we used his heated garage to intall the mechanical gauges. Real good guy. He is selling his kits on ebay. His work number is 216-676-2589. Tell him that Carl referred him to you. His kit is selling for $285 with everything you need including brass fittings.
Andy,
What will I see in boost with a 15% pulley?
Thanks,
Carl
Here are the gauges:
Old Mar 25, 2004 | 10:31 AM
andy@ross-tech.com
Filmy
15
Jun 6, 2023 06:27 AM
rob&JCW
Feb 21, 2018 02:41 PM
Oct 19, 2015 08:07 PM
RocketUSA
Sep 15, 2015 07:45 AM
Gen1Parts
Sep 7, 2015 01:37 PM
