Drivetrain Cars runs like crap after FMIC installation
Old Aug 14, 2012 | 11:09 AM
RedAndBlackMiniS's Avatar
RedAndBlackMiniS
What's up with this? I just installed my intercooler and now my car runs like crap! At around 2-3000 RPM it will shake the entire car and then under heavy acceleration, the car is extremely sluggish! Do I have a leak somewhere? Something wrong with the intercooler? What's going on?
Old Aug 14, 2012 | 11:13 AM
texasmontego's Avatar
texasmontego
Obviously something is wrong. I would go back and check everything. There has to be something no hooked up. Perhaps some hose/piping wasn't tightened enough and blew off under pressure. It has happened to be.
Any CEL's?
Old Aug 14, 2012 | 11:15 AM
RedAndBlackMiniS
No CEL's, the hose clamps were tight around the pipes. It ran like this as soon as I pulled out of my garage. It almost feels like I'm stalling the car (the rocking).
Old Aug 14, 2012 | 11:22 AM
RedAndBlackMiniS
Actually, I AM getting a check engine light.
Old Aug 14, 2012 | 11:26 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You def have something loose or disconnected. I've installed somewhere around 40 intercoolers on R56 and never had one run bad after install. There is no reason for it to as it is just a bigger cooler no moving parts to it.
Old Aug 14, 2012 | 11:57 AM
JPMM's Avatar
JPMM
you forgot to take the plug(s) out of the IC ends
Old Aug 14, 2012 | 12:03 PM
IQRaceworks's Avatar
IQRaceworks
Sounds like possibly a vacuum line is not connected??
Old Aug 14, 2012 | 12:15 PM
RedAndBlackMiniS
I checked it all over again. I repositioned the hoses connecting to the intercooler and tightened as tight as it will go. That solved the boost problem and car is running normal now. One thing is the CEL is still on. P115D- anyone?
Old Aug 14, 2012 | 01:20 PM
RedAndBlackMiniS
Fixed it! No more CEL. Checked it again and part of the hose that connects to the intercooler was caught up in another plastic bit that was attached to the car. Took a screwdriver and tucked it in and pulled it in really firmly and it slid another .5" onto the intercooler. Problem solved. Thanks for the help!
P.S. Get an intercooler if you don't have one.
Old Dec 19, 2012 | 02:26 PM
MyYellow 07's Avatar
MyYellow 07
OK, another off the wall question:
I installed my FMIC, and the minute I backed it out, now I have a sticky shifting issue? Seems perfectly fine from 1-3 then gets tighter from 4-6 shifts, with 6 the worse? The FMIC seems to be operating perfectly fine. I have driven it like this a 100 miles or so?
Any ideas? Totally unrelated?
Old Dec 20, 2012 | 04:26 PM
JPMM's Avatar
JPMM
thats wierd, but as far as the OP is conserned, good job!
Old Dec 21, 2012 | 11:00 AM
Samysonary's Avatar
Samysonary
Possible you have a tube or something hitting the shift linkage after you replaced the FMIC? There is a long 'bar' that extends towards the front of the car, located under the snorkel just behind the coolant reservoir. That 'bar' moves while making shifts.
AWOL
Mar 28, 2016 10:51 AM
maestro39
Oct 27, 2015 02:38 PM
oldkid6
Aug 11, 2015 08:13 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
