Drivetrain Let's talk short shifter...
Old Jun 21, 2012 | 07:42 PM
richardsperry's Avatar
richardsperry
I installed a NM engineering SS adapter. The throws are shorter, but is it my imagination or does it seem that the shift pattern has moved towards the front of the car? Is that a function of the revised pivot point?
I like the effort and the length of the throw, but maybe a slight bend of the shift lever is called for.
Old Jun 21, 2012 | 08:43 PM
llewellyn's Avatar
llewellyn
I installed the Tyrolsport short shifter, I love the feel of it - I don't think it moved it forward any, but It crossed my mind that it would be nice if the shift **** was further aft. I know the Alta short shifter has a slight bend in it - I'm not sure, maybe it would be possible to bend the factory shift lever?
Old Jun 22, 2012 | 08:09 AM
Bigcoyote's Avatar
Bigcoyote
I have the NM in my Clubman and I didn't notice that the pattern moved forward. In my car it actually made room for big cups in the drink holders ( keeps the shifter from hitting them ).
Old Jun 22, 2012 | 08:13 AM
Porthos's Avatar
Porthos
Don't know I have the Alta SSK.
Old Jun 24, 2012 | 09:10 AM
automan21's Avatar
automan21
To the op, yes it does seem that it has moved it a bit forward. I thought it was just me. Does your shifting feel more notchy as well?
Old Jun 25, 2012 | 04:06 AM
richardsperry
Not notchy per se, I'd call it more defined. My E36 M3 is notchy, but more like a rifle bolt. THe Mini isn't like that. You have to understand that any % you shorten the throw, it will take that much more effort to shift. It's a direct relationship, because it's all about leverage....
Old Jun 25, 2012 | 06:33 AM
Creeve's Avatar
Creeve
Put a bend in mine, huge improvement. I have short arms and I couldn't really shift into 3rd and 5th without leaning forward in my seat before. I have a helix short shift adapter, and a shortened upper arm.
Pictures suck, but here they are -
Old Jun 25, 2012 | 09:56 AM
richardsperry
I bet that gets hot...
Old Jun 25, 2012 | 11:08 AM
Creeve's Avatar
Creeve
In Rochester cold is more of a problem them hot. But honestly its not too bad.
Old Jun 25, 2012 | 02:58 PM
timwu13's Avatar
timwu13
is that a bend in the stock shifter? If so, how'd you do that?
Old Jun 26, 2012 | 05:55 AM
tominizer's Avatar
tominizer
I have the Tyrolport SSK and it's a really nice kit. Installation is fairly easy as its all under the hood. Shifts do feel slightly notchier though.
Old Jun 26, 2012 | 01:45 PM
automan21's Avatar
automan21
Last time I checked the 2011+ are out of luck on those.
Old Jun 26, 2012 | 04:30 PM
Creeve's Avatar
Creeve
It was a couple years ago but I'm pretty sure I just heated it with a torch and bent it.
minimofo
Sep 30, 2015 12:26 AM
Sep 22, 2015 02:05 PM
rikaro
Sep 21, 2015 06:57 AM
Quixotic1
Sep 11, 2015 11:15 AM
