Drivetrain Boost drop from stage II tuned 07 MCS??
Old Feb 21, 2012 | 02:42 PM
Dek766's Avatar
Dek766
I'm asking for someone's help on helping me fix this issue. I have an 07 mcs and i'm running stage 2 on my mini.
The mods are as follows:
Invidia Q300 exhaust with Riss racing catless downpipe
Alta accessport stage 2 (duh)
K&N cold air intake
What are some of the causes of this? It happened before I installed the downpipe, so I don't think that's it. I'm running no cats at the moment.
The drop in boost occurs when I'm running at low rpms mostly in 4th and 6th gears, but sometimes happens in others as well.
Thanks!
Old Feb 21, 2012 | 08:31 PM
Mike@Tech Division's Avatar
Mike@Tech Division
At what point does it drop boost in these gears? I see you say low RPM in 4th - 6th, but how are you driving the car when you see a loss in boost?
Are you just cruising at low RMP?
Are you cruising at low RPM then going to WoT?
Also if it's something you can easily replicate then you could run a data log and send it in to Alta.
Old Feb 22, 2012 | 07:23 AM
Porthos's Avatar
Porthos
That is because the Alta tunes are a little aggressive and the ECU does not like that much boost espescially under heavy load. I normally don't have a problem when I am around 3500rpm to redline but under that I almost always have a problem.
Old Feb 22, 2012 | 02:34 PM
Dek766's Avatar
Dek766
It usually drops boost in those gears when I'm around 3000 rpm and then i stomp it. If i'm between 3500-4000 it doesn't drop the boost. Usually I cruise at low rpms, but it usually only happens when i floor it. I'm not familiar with data logging, alta told me to do that and send it to them, but i'm not certain on how to do it.
Old Feb 22, 2012 | 02:35 PM
Dek766's Avatar
Dek766
Is there a possible fix to this? I'm just throwing out ideas such as a new diverter valve or boost tubes?
Old Feb 22, 2012 | 02:54 PM
Porthos's Avatar
Porthos
Yeah data log it for a couple of days and send the files to Alta. I need to do the same but I am lazy and have not got around to it.
Old Feb 24, 2012 | 09:52 AM
ALTA_Chris's Avatar
ALTA_Chris
Hey guys, here's a page that we made a little while ago to help describe exactly how to do a datalog.
http://blog.perrinperformance.com/ho...ur-accessport/
It would help to get a log of the exact problem happening, rather than a log of just driving around.
If you guys have any questions, let me know.
Old Feb 25, 2012 | 01:58 AM
mini4tide's Avatar
mini4tide
Mine did this with a DDM race intake. Went back to stock intake, no more issue. No issue now with my AEM either. Strange.
Old Feb 25, 2012 | 11:15 AM
Dek766's Avatar
Dek766
Thanks Chris! I data logged it today, I sent you all an email. Hopefully this will fix the problem, the guide really helped out a lot.
Old Feb 25, 2012 | 11:16 AM
Dek766's Avatar
Dek766
Yeah, I'm running stage 2 with a k&n CAI, riss racing DP, invidia cat-back. I also run my car with 93 octane, so there's a few possibilities. I'm almost certain it's because of the aftermarket intake.
atlas8000
Aug 14, 2015 07:45 AM
minipopkart
Aug 13, 2015 05:22 AM
flredmini
Aug 12, 2015 06:35 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
