Drivetrain Vipec engine management - A new way to blow your engine!
Old Jun 28, 2013 | 08:10 AM
  #126
soccerbummer1104's Avatar
soccerbummer1104
just so everyone knows,
The bosch 950's I got came in and idle perfectly. Scaled them and the car started right up like nothing had changed. (except the pulse width is only 1.98 ms!)
These are so small they were actually "cute" only ~ 1.5" long and 1/2" in diameter (for the fellow engineers and other Europeans, 33.6mm o-ring to o-ring (w/o extensions), and 14mm diameter)
Obtained from Bosch Motorsport Distributor "Mech-Tronic" out of NJ, USA.
PN: B 289 S36 371-18
Rating: 950cc @ 3 Bar
Old Jun 29, 2013 | 04:28 AM
  #127
stevecars60's Avatar
stevecars60
I'm glad the scaling worked well. Can you adjust the injecting timing? If so, it could be helpful later on. Cam?
Old Jun 29, 2013 | 05:48 AM
  #128
ODannyBoy's Avatar
ODannyBoy
Just an FYI those injectors were produced in Charleston "927"
Old Jun 29, 2013 | 12:17 PM
  #129
soccerbummer1104
thanks odanny boy I was assuming germany as they were made in the sample shop. But as long as they were made by a bosch engineer in-house its all the same to me! (Charleston, SC?)
Old Jun 29, 2013 | 12:21 PM
  #130
soccerbummer1104
and stevescar60, yes you can adjust the injector timing!
You can set it up for single zone (same injector timing no matter the RPM)
or you can set it up on a table (change timing with changing rpm)
you can also specify if you want the value to be targeted as the injection pulse ends at that timing or begins at that timing value.
Old Jun 29, 2013 | 01:22 PM
  #131
ODannyBoy's Avatar
ODannyBoy
I work in Diesel so I'm not sure the extent to which Gasoline do any modifications in house versus with the actual motorsports division in Germany or the motorsports guys in detroit but I know that the base injector is definitely made in Charleston SC.
Old Jul 1, 2013 | 05:09 AM
  #132
stevecars60
Love that software. EGT w/Vipec?
Old Jul 1, 2013 | 01:02 PM
  #133
soccerbummer1104
still waiting to hook it up. (work the normal 9-5 engineer job and then I come home to a condo that I am building. (interrior wall frames, plumbing and electrical done. Working on floors and walls now). So the mini gets some work, but it is slow going.
Once I get the expansion cable in I will hook up the EGT and wire in the AFR as well.
Old Jul 2, 2013 | 06:17 AM
  #134
stevecars60
Wish I lived closer. I have a love hate with remod. At least with a condo, with any luck, there's no Rambo. Keep us posted
Old Mar 28, 2014 | 07:36 AM
  #135
russian2's Avatar
russian2
So, what's the current status - has you actually installed the Vipec on the Mini?
Old Mar 28, 2014 | 10:36 PM
  #136
soccerbummer1104
I hooked mine up. Worked awesomely! the self tuning feature works quite well as well for dialing in AFR's
Old Oct 20, 2017 | 09:15 PM
  #137
MonzMini's Avatar
MonzMini
Originally Posted by LASRGUY
The thread title is a lawsuit waiting to happen. I suggest you or one of the moderators do something about it.
It's going to be okay sunshine. I'm pretty sure Vipec won't be upset about this post. Did you even read it?
Old Oct 20, 2017 | 09:28 PM
  #138
MonzMini's Avatar
MonzMini
Originally Posted by llabmik2
The Vipec...Where to start. Its going to be pretty awesome.
Should you be using it if you have zero idea of what you are doing? NO. Will it blow your motor? NO! Who ever is tuning it can though. Is it better then the Tronic? By far, Tronic is a ECU hack its why you have to install it onto the ECU among other reasons.
On ECU No Lift To Shift (NLTS), boost control, LC(launch Control) with ability to build boost, AFR tracking, Real Time Programing (RTP), datalogging, HUGE MAPS, map switching. I mean its a pretty awesome set up.
The sad part about all this, is that people are excited to see this owe a HUGE thanks to ONE company that can't be said on here...retarded but whatever. With out that company and the owner this would not be anywhere near where its at.
VIPEC>bytetronic
Why can't we say RMW? I wasn't aware that Jan has dealings with Voldemort... Horcruxes must be why my car is doing so well... Huh.
W0TM8
Dec 19, 2019 07:50 AM
devicemanager
Jun 17, 2016 06:18 PM
Aug 21, 2015 11:25 AM
minipopkart
Aug 13, 2015 05:22 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
