Drivetrain Cylinderhead parts
Old Nov 16, 2011 | 03:14 AM
daveke's Avatar
daveke
Cylinderhead parts
Hi guys,
A friend of mine wants to build his own head from the bottom down and asked me to search for valves, springs, locks and everything he needs for the build.
Does one of you know a shop/ebay/something like it that sells a kit or maybe one of you has got some advice on what to buy (brands, location etc). He is looking into exhaust + 0,5 mm and intake + 1 mm and all of the other parts needed to build the head into a performance head. He is doing all the porting and skimming himself
Thanks heaps!
Davy
Old Nov 16, 2011 | 08:52 AM
ThatMiNiGuy's Avatar
ThatMiNiGuy
Good luck. on your search.
Old Nov 17, 2011 | 12:39 PM
daveke's Avatar
daveke
Well, you should think one could get valves, springs and locks from Crower or other brands?
I only need to know part-numbers etc. to order all of it..
Old Nov 17, 2011 | 01:18 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Dave and PA, contact Thumper performance, Mike will set you in the right direction, or even get the parts for you. He uses a lot of the NitroStick components because of the quality and engeneering that went into them, and they are backed by CROWER. They have everything, "Behive" valve springs, Ti retainers, cams. He also knows where to scource bronze valve guides, custom valves (even Inconell) and all the related hardware to build a head capible of 8000+ RPM and handle cam's with 0.50" of lift.
NitroStick parts can also be ordered through Detroit Tuned, FES auto, and a few others.
Old Nov 17, 2011 | 03:43 PM
firenewt's Avatar
firenewt
+1 Mike at Thumper is a great guy. He will help you out.
Kevin
Old Nov 17, 2011 | 06:51 PM
putttn's Avatar
putttn
+2+3...i've had two cars with Thumper Heads and he's a great guy to do busineess with, even though he's older thn dirt!!
Old Nov 17, 2011 | 10:57 PM
ThatMiNiGuy
The OP already has a TPR2R, his friend is the one who wants to build his own head.
Old Nov 18, 2011 | 12:50 PM
GordonP66's Avatar
GordonP66
In addition to Crower/Nitrostick, Supertech, Ferrea & Cosworth may have what you need.
The DIY route is admirable but guys like Thumper have hundreds of R & D hours on these heads & know what parts to get & what parts to forget. They'll know how much to safely remove around the exhaust ports without hitting a water jacket, what spring pressures & keepers work best. Whatever route you take, good luck with the project!
Old Nov 18, 2011 | 04:39 PM
putttn's Avatar
putttn
Yes, Thumper and perhaps many other guys who build heads probably have a number of stories about guys building their own heads. I'd at least converse with a couple of these guys before spending the money and time.
Old Nov 21, 2011 | 07:11 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We sell all the parts for heads and engines, just don't have them all listed on the site as there is so many different combos. Let us know what you want.
bobbiemartin
Jan 20, 2016 05:28 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
Ryephile
Aug 25, 2015 06:51 AM
nomar116
Aug 21, 2015 04:36 PM
