Drivetrain *the sprintex owners thread*
Old Jun 20, 2017 | 05:20 AM
  #551
CSP's Avatar
CSP
I doubt you'll find a gen 1 kit. AFAIK, just check the oil fill bolt to verify as the 2nd gen has a dipstick, 1st gen doesn't.
For those who do have a gen1 - bytetronik has the vented filler plugs again. Well worth $20 for peace of mind.
Old Jun 20, 2017 | 03:10 PM
  #552
Bytetronik's Avatar
Bytetronik
Originally Posted by massmini03
ALSO LOOKING INTO PURCHASING SPRINTEX
At 128k, I'm getting nervous about the current life of my stock Eaton.
Any specific dealers? Are there any possibilities of getting an older version w/o fixed oil seals, etc?
We are also a Sprintex dealer and can provide you a quote. We also sell a couple of improved parts for the Sprintex. One is the GPR Tensioner; the other is the vented filler plug to address the "oil seal issue".
Thanks for your support @CSP. We just got all the technical specs with all Gens of the Sprintex units (MINI, Jeep, Honda, FRS/BRZ, etc) and will be able to provide the vented filler plug to all models starting on July 8th
Old Jun 26, 2017 | 08:44 AM
  #553
CSP's Avatar
CSP
How is everyone's fuel economy with the sprintex? Has anybody been tracking?
Old Jun 26, 2017 | 12:17 PM
  #554
BlwnAway's Avatar
BlwnAway
Your millage will depend on your tune, me personally, I avg. 27.0 everyday and avg'd 29.7 hwy on my trip to MOTD.
Old Jun 27, 2017 | 05:35 AM
  #555
CSP's Avatar
CSP
I'm untuned AFAIK. Swapped heads and still not getting the economy I was hoping for. So I came here hoping that someone else was getting as low as me. Guess I need to figure out what the issue is still.
Old Jun 27, 2017 | 09:22 AM
  #556
checkers's Avatar
checkers
Why would you even worry about your gas mileage when you are trying to increase your HP. It doesn't make much since to me. Unless you are down below say 25 mpg I sure would not worry about it.
Old Jun 27, 2017 | 09:49 AM
  #557
CSP's Avatar
CSP
That's exactly the issue. I'm not worried about a couple mpg, but I'm worried about something being wrong.
Old Jun 27, 2017 | 02:57 PM
  #558
sevin's Avatar
sevin
I get 21 MPG with just a 17% pulley, intake and tune. No Sprintex. I don't get all this nonsense of people with 250HP cars getting almost 30 MPG. That's just insane to me. Unless they're just reading the OBC and not actually calculating it themselves.
Old Jun 27, 2017 | 03:08 PM
  #559
CSP's Avatar
CSP
Great tunes? At 21mpg I'd be looking into some stuff... That seems like something is wrong. Anything below 25mpg I'd be investigating unless you're beating the hell out of it everywhere you go.
Old Jun 27, 2017 | 05:12 PM
  #560
BlwnAway's Avatar
BlwnAway
Exactly, now or before, I've never gotten below 24 mpg, and that was with my worn out motor, and thrashing it heavily. From past experience, if I would have stayed under 70 on the way down to MOTD, I would have gotten close to 32 mpg Hwy.
But again, it's all about the tune, let's not forget, most of tuning is getting your performance parts to work as efficiently as possible, and efficiency = mpg.
Old Jun 29, 2017 | 03:31 PM
  #561
CSP's Avatar
CSP
I still need to drive and monitor mileage, but I think I'm going to get my injectors flow tested. Send one out and get it done for $7 or whatever it is. Just make sure that the PO didn't put 380's or more in there.
Old Aug 28, 2017 | 11:09 AM
  #562
rksnow1's Avatar
rksnow1
HI, new to the forum here. I have a 05 R53 JCW. my SC needed a rebuild and decided to go Sprintex.. just installed the Sprintex SC a month ago...
She was much faster then before for a week or two then started having issues with throttle response I'm still working out bugs since..
Pretty much stock besides doing the VGS and K&N filter, and airbox flap mods.
Old Aug 28, 2017 | 01:54 PM
  #563
CSP's Avatar
CSP
Hey rksnow. Welcome to the fam.
Elaborate on the throttle response issues?
Old Aug 28, 2017 | 02:38 PM
  #564
rksnow1's Avatar
rksnow1
HI CSP, great to be back here. I started another thread (under 1st gen problems(I think)asking for help. didn't want to hijack this one, but basically I don't have throttle/power in the higher RPM range 3k+. car ran great for a few weeks after SC install, then started getting various codes and DSC light, going into limp mode, changed Map/TMap sensors, Bypass valve, checked for vacuum leaks, No codes currently but just seems like the pedal becomes unresponsive, builds boost and engine revs but nothing or wait then power kicks in and goes out again. Changed the harmonic balancer today thinking it separated but still the same symptoms and no codes
Old Sep 13, 2017 | 03:33 AM
  #565
stevecars60's Avatar
stevecars60
What do the plugs look like? And are the stock plugs....
I have a mild Mini, JFE - Just fast enough.
The Sprintex was a big improvement. And the fuel mileage did go up. The stock plugs don't last more than a couple K. They don't look terrible but if you compare them with an iridium plug, same mileage, the color is different. The 2002 - 2004, cars, many have a flat spot at 3000rpms - JCW 380s with colder plugs took the flat spot out of my car - I also have a Cosworth head. The flat spot could have been exaggerated with the new SC - The duty cycle of the stock injectors could be at their limit - this would happen after and during some hard driving... You could get an SEL.
Old Dec 30, 2017 | 12:40 PM
  #566
downshift1's Avatar
downshift1
Do the second gen units need the vented plug too?
Old Dec 30, 2017 | 05:44 PM
  #567
BlwnAway's Avatar
BlwnAway
No, the dipstick replaces the filler bolt, vented or not.
Old Jan 20, 2018 | 08:32 PM
  #568
BlwnAway's Avatar
BlwnAway
I've posted a Sprintex GPR tensioner for sale in the 1st gen classified section, wanted to mention it here since it is a Sprintex only item.
Old Jan 21, 2018 | 12:56 AM
  #569
ChiggerPepi's Avatar
ChiggerPepi
Just completed the Sprintex install on my '03 R53.
I was bone stock with 8.3 lbs boost. After Sprintex I'm seeing 13.5+ lbs boost, and the death rattle noise from my water pump gears is GONE... ohhh it sounds so sweet, and much quicker.
Old Jan 27, 2018 | 10:40 PM
  #570
downshift1's Avatar
downshift1
Welcome to the club?
A word to the wise, grab the tensioner listed above you'll need it.
Old Jan 29, 2018 | 12:12 PM
  #571
ybnormal70's Avatar
ybnormal70
If anyone with a Sprintex needs a tensioner, I am the one who purchased this one without doing all my research first and found that it was not an upgrade for the stock charger and the company says it does NOT WORK with the stock supercharger.
I'm looking to sell it for the same price I paid if anyone is interested.
https://www.northamericanmotoring.co...tensioner.html
Thanks,
Kevin
Old Jan 29, 2018 | 12:22 PM
  #572
CSP's Avatar
CSP
Wait by stock you mean the eaton SC? You don't have a Sprintex?
Old Jan 29, 2018 | 12:38 PM
  #573
ybnormal70's Avatar
ybnormal70
That is correct. Stock supercharger on my 2005 R52.
Kevin
Old Nov 10, 2018 | 01:26 PM
  #574
Stoker's Avatar
Stoker
Dipstick for sprintex?
there’s a dipstick for the sprintex now? Does it deal with the venting issue?
Old Nov 10, 2018 | 08:54 PM
  #575
blacklistedmini's Avatar
blacklistedmini
New to this thread, just put the Sprintex on my 2005 MINI and now have put 230 miles on it. So far so good, only issue is the belt tensioner is noisy, clacky until it gets warmed up, I'm guessing the piston needs to get set in after sitting over night, so I purchased the one from Byte Tronik since it has the OE style that works, just replacing the dampener bushings to power flex because I go through those like crazy... So many pages on this thread so its hard to read all of it but is anyone else having tensioner issues with the one from Sprintex being noisy? Not a belt slip noise but clacky. My belts are fine, haven't slipped once and I'm chirping into 2nd gear, on a stock clutch with 119,000 miles even... That car rips now. I don't whomp on her all the time, I take it pretty easy but every once in awhile I'll let her eat Oh and I'm throwing a Lean Bank 1 code, is that an issue that can be fixed with a tuning? I'm running new 550 injectors from RMW, new fuel filter and new fuel pump. It's always thrown that code off and on but now I figure this thing is sucking in WAY more air and I need to fix this before I cook something. Any input would be great, thanks! Oh also it was tuned about 8 years ago by Mynes Tune and that's when the code started coming up so I don't know if it was tune issue or just a coincidence.
