Drivetrain turbo failure!
Old Jun 18, 2011 | 03:15 PM
leomulhollandiii's Avatar
leomulhollandiii
turbo failure!
Well smurf is going to be in the shop because the turbo no shaft broke after 56,000 miles. My SA said he has not seen this in many cars! it will be there for over a week due to them ordering a new turbo. I love extended warranty's! I would just love to know what caused the problem. Wife was driving home when the car lost power and died. She restarted it and limped it home. I have no major Mods as you can see from my sig. Any ideas ppl?
Old Jun 18, 2011 | 03:17 PM
MotorMouth's Avatar
MotorMouth
yep, not very common, guess you got "lucky"
Old Jun 18, 2011 | 04:49 PM
DneprDave's Avatar
DneprDave
Have 'em put a JCW turbo on it and pay the difference in price from the S turbo!
Dave
Old Jun 18, 2011 | 06:23 PM
leomulhollandiii
yup i'm real "lucky" This poor car never even knew what hit her!
Old Jun 18, 2011 | 07:23 PM
Verithas's Avatar
Verithas
Dave
nice idea!
Old Jun 18, 2011 | 08:08 PM
leomulhollandiii
Dave
Not a good idea with the compression of the non-jcw. I wish i could though!
Old Jun 18, 2011 | 08:48 PM
DneprDave's Avatar
DneprDave
People put the JCW and the Alta billet turbo on S cars all the time, the small differnce in compression ratio could be compensated for, with the proper custom tune.
Dave
Old Jun 18, 2011 | 09:14 PM
ThumperMCS's Avatar
ThumperMCS
The compression isn't the issue....
Dave
They are the same price
Old Jun 19, 2011 | 01:04 AM
leomulhollandiii
you are right compression ratio is not the problem..its the internals. and if i can take out a turbo with no tune and very little mods... what do you think will be the next thing in this engine to go....pistons! think i'm done modding a car that should not be modded. I should have bought a JCW if i wanted more power and the chance to mod the engine. I just want to know what caused my turbo to fail!
Old Jun 19, 2011 | 05:02 AM
MCS Fever's Avatar
MCS Fever
Spoken like Papa Smurf........
Old Jun 20, 2011 | 07:07 PM
leomulhollandiii
got a call from my SA today. I asked him for the photos of the Turbo.
He said he will shoot them over to me. The mechanic said it smelled like "death" Funny part is i noticed an oil smeel 3 days earlier but thought it was the OCC. Can't wait to see the photos. I will post them when he send them!
Old Jun 21, 2011 | 09:55 AM
mrrjm's Avatar
mrrjm
There's a TSB about this. The supply line gets plugged up. There's a shield they will also install on the supply line. May I also suggest 5k oil changes instead of the 15-20k.
Old Jun 24, 2011 | 01:26 PM
jlevy's Avatar
jlevy
Pic of insulation on the oil line
I've never really liked the way heat can freely radiate from the turbine housing to the turbo oil line. Very soon after I got the car back in 07, I wrapped this line with thermo-tec radiant heat barrier. This stuff is rated for 2000 deg F. Check out what the insulation looks like after 4 years on the car and just under 30k miles.
JL
Old Jun 24, 2011 | 01:54 PM
ZeR0 EVOlution's Avatar
ZeR0 EVOlution
I think I'm going to hop on some of that thermal tape for the R56.
Old Jun 24, 2011 | 02:02 PM
MP1.6T's Avatar
MP1.6T
How about the new Mini part instead...
Per the last several posts, Mini now has a head shield cover for the oil line fitted to current cars. Got one for mine and it took <10 seconds to install. Simple and secure clip on, and of course factory look and w/out warranty questions for a newer car.
See part #20: http://www.realoem.com/bmw/showparts...44&hg=11&fg=50
JL
Old Jun 24, 2011 | 06:26 PM
leomulhollandiii
Well got Smurf back today! Clogged oil port causing no oil flow to the turbo hence bearings no longer rotate and the shaft snapped! good times! didn't see a heat shield on the line. might have to ask my SA why it is not on there. I read the TBS and everything that is on it has happened to my car! guess i am "lucky". Bad luck is still luck!
Old Jun 24, 2011 | 06:34 PM
Jaque_Mate's Avatar
Jaque_Mate
Glad to hear a "good" ending to a "bad" luck scenario. Did your SA give you any advice on how to prevent the clogging or is it more the dealer just checking it over on a regular basis?
Old Jun 24, 2011 | 08:19 PM
mrrjm's Avatar
mrrjm
IMHO the problem here is the high mileage interval oil change. At 5k on a mini turbo the oil is the blackest black. Looks like the oil on a diesel. I suggest changing the oil every 5k max. I doubt the turbo oil supply line will ever plug up if this is done. Heat shield or not.
Ray
Old Jun 25, 2011 | 05:18 AM
richardsperry's Avatar
richardsperry
Looks has nothing to do with oil performance. Oil analysis says 7500 miles with approved synthetic oil is fine, and very conservative. But I agrree, 17-18K miles is just way way too much.
Old Jun 25, 2011 | 10:19 AM
yetti96's Avatar
yetti96
Did they change the oil lines too?
IMO the heat shield doesn't look too helpful as it is thin metal just clipped onto the oil line.
Old Jun 25, 2011 | 10:58 AM
leomulhollandiii
yup oil lines were replaced. i normally change the oil 5-6k. i just dont like all the heat that sits in the turbo not being removed when the engine is off.
Old Jun 25, 2011 | 11:19 AM
MotorMouth's Avatar
MotorMouth
do you know there is a cooling system for the turbo after you shutdown?
Old Jun 25, 2011 | 12:27 PM
MCS Fever's Avatar
MCS Fever
yup oil lines were replaced. i normally change the oil 5-6k. ...........
So much for everyone's theory that frequent oil changes help with this issue........
Old Jun 26, 2011 | 03:41 PM
mrrjm's Avatar
mrrjm
Kindly. I know. I sent my oil out for analysis after 5k and everything came back normal. But...I still change it at 5k or less.
Old Jun 26, 2011 | 09:38 PM
bluefox280's Avatar
bluefox280
Correct, but that's the water-jacket being cycled through; that's not the oil being circulated.
leomulhollandiii, did you ever hot-rod the car (applying moderate boost or higher) right before parking it and letting it sit?
Or did you mainly coast to your destination for several minutes before parking?
- Erik
