Drivetrain Powerflex gear box and lower engine bushing inserts
Old Jun 14, 2011 | 01:51 PM
ggcadc's Avatar
ggcadc
Just installed them today. Easy enough install, pretty straight forward stuff.
I hear they take a few hundred miles to break in, so I'm hoping at least some of the vibration in the steering wheel goes away, that's the only vibration that developed, it's is much more noticeable with the AC on. But overall, considering it's really keeping the motor from moving, it's worth it.
The advantage so far is the gears are very predictably engaging, especially first, much less feathering to get moving. and the shifts (driving easy) are very smooth. I'm not sure how it responds to a heavier foot as I wont be beating the car for a couple weeks (autox coming up the 26th). But I expect an even more noticeable change there, as sometimes before them I could feel the gearbox trying to dodge my shift to third.
Old Jun 14, 2011 | 02:39 PM
Flyingfrenchman's Avatar
Flyingfrenchman
Glad you like them. I just bought mine from Way and will be installing them this weekend!
Old Jun 14, 2011 | 02:51 PM
Longboard110's Avatar
Longboard110
I love mine, they are a great addition. I actually love the nvh.
Old Jun 14, 2011 | 03:26 PM
jimz68's Avatar
jimz68
I don't even notice the NVH any more. Just the more positive feeling when shifting at higher revs.
Jim
Old Jun 14, 2011 | 07:30 PM
ggcadc's Avatar
ggcadc
They also give me a great excuse for the existing creeks and interior noises that bothered me before. I'm sure I can convince myself the cause is really the poly.
Old Jun 14, 2011 | 07:33 PM
Flyingfrenchman
Are you saying they got worse or better?
Old Jun 14, 2011 | 08:16 PM
ggcadc's Avatar
ggcadc
I'm saying they're the same, but I'll convince myself and others they're from the poly bushings, so now I have an excuse for my rattlebox
Old Jun 14, 2011 | 08:18 PM
ggcadc's Avatar
ggcadc
And honestly, I don't have huge rattle problems, and the mounts definitely didn't make them worse or cause more so far
Old Jun 15, 2011 | 05:55 AM
MiniCooperS43's Avatar
MiniCooperS43
If you don't have them already you should get the powerflex rear Trailing arm bushings. They really stiffen up the rear end and make it more predictable and I haven't noticed any additional NVH from them.
Old Jun 15, 2011 | 07:39 AM
ggcadc's Avatar
ggcadc
Is the install anything as bad as the front lca bushings?
Old Jun 15, 2011 | 08:03 AM
rjtrout2000's Avatar
rjtrout2000
Are you talking about the rear trailing arm bushing inserts? I thought about adding them to my car when I get my shocks installed.
Old Jun 15, 2011 | 10:50 AM
MiniCooperS43
Yeah, thats what i meant. I edited it now.
The install is very easy, the first side took about 45 min the other side about 25. Just remove the plastic wheel liner, remove the trailing arm bolt and clean everything up a bit and insert the bushings and put the bolt back in and presto change'o. The torque for the bolt is around 130ft/lbs so be sure to use a torque wrench. Here is a how-to...https://www.northamericanmotoring.co...t-install.html
silence2-38554
Nov 12, 2015 09:39 AM
minipopkart
Aug 13, 2015 05:22 AM
O4mcs
Aug 10, 2015 10:22 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
