Drivetrain 2% Crank Pulley
Old May 12, 2011 | 03:34 AM
Villa8525's Avatar
Villa8525
2% Crank Pulley
Im looking to ad a 19% supercharge pulley with 2% crank pulley. Is it a good combination????
Old May 12, 2011 | 04:13 AM
Luys's Avatar
Luys
No. Belt problem and more heat....
Old May 12, 2011 | 05:27 AM
NH_MCS's Avatar
NH_MCS
Ditto. A 19% S/C pulley coupled with a 2% crank pulley is going to be way too much of a reduction. In the case of these M45 superchargers, more is less. Because the more you raise the boost, the more heat you generate which defeats the purpose of running more boost in the first place. And as stated you'll have issues keeping belts together as well.
Old May 12, 2011 | 05:33 AM
Villa8525's Avatar
Villa8525
What about 15% pulley with 2% crank pulley??
Old May 12, 2011 | 05:41 AM
NH_MCS's Avatar
NH_MCS
That would be a much better combination that a lot of folks run with success.
Old May 15, 2011 | 12:02 AM
MrCooperS's Avatar
MrCooperS
Moderator
What belt should be used with a 15% pulley and a 2% crank?
Old May 15, 2011 | 09:03 AM
nascar mini's Avatar
nascar mini
I have had my 15% Craven and 2% Alta for 3 years now without any problems what so ever. I personally think the 19% and 2% combo is a bad idea,heat is your worst enemy in Supercharging.Just my 0.2 cents worth.
B.
Old May 15, 2011 | 07:45 PM
CZ Mate's Avatar
CZ Mate
Nascar- I was wondering if you had have your mini dyno. Just wondering what HP you are at with the 15% & +2. That what I am going be installing soon. also what u reading for boost?
Old May 16, 2011 | 04:25 AM
NH_MCS's Avatar
NH_MCS
A 15% + 2% will yield very similar results to those running a 17% and 0% such as myself. Probably somewhere in the ballpark of 15-17psi depending on how healthy your supercharger is. I know in my case I can get just a hair over 16psi under certain conditions. I do think the 15/2 combo is easier on the belt than a 17/0 setup because the belt will not be forced to bend as tightly around the pulleys.
Old May 16, 2011 | 05:42 AM
ZippyNH's Avatar
ZippyNH
No....
too much boost...heat....not enough fuel.
22% reduction or the equivelent of....
with 93 octane and a 17% you run lean at higher rpms....but not dangerously ....with a 19 some do ok...some don't....
Even with a custom tune at install, all the heat you will make with the sc will be couterproductive....you will make LESS POWER THAN A SMALLER REDUCTION.
Old May 16, 2011 | 05:45 AM
ZippyNH's Avatar
ZippyNH
Just go stright to a 17%....
if you want a 2% ....br sure to get a dampened one....the cheap ones are not...
If you live in a warm area....a 15% may be a better option....if the charge air is too warm, the timing will be retarted..same with octane...not enough...(like with. 91) 93+ is great, you will make less hp..(with lower octane)..if you cannot get 93...91 is kinda iffy imo with a 17
Old May 16, 2011 | 07:15 AM
PoonRacing's Avatar
PoonRacing
+1 same here for 4+ years no problems
Old May 16, 2011 | 07:28 AM
ZippyNH's Avatar
ZippyNH
One thing yo consider....when running a 2% underdrive, the alternator and ac are both getting ovrrspun a bit...causing a bit of extra parasitic loss, and shorting their lives a bit....you can get a different alternator pulley.....
The lighter crank damper can improve throttle response a bit, but a 17% is a simpler swap....if you need anew crank damper, than a 15% and a 2 is ideal for many...if you want to run a 17 and are willing to take a tiny risk with the above items..on a dampened pulley.....running an undampend pulley starts a whole new discussion....
The above chart is not 100% correct, but pretty close.....a few different sizes are preceded, but the 535 fits a 15 or 17% reduction, whith an overdrive crank damper...not sure...
Old May 16, 2011 | 04:40 PM
nascar mini
CZ, seeing a tad over 15lbs boost. Had a tune early on but have since done more mods and need to retune/dyno.Now with this head,cam and injectors,i hope i've bumped her up a tad.Stay tuned!
B.
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
Debi's Coop S
Oct 3, 2015 08:19 AM
VanisleRyan
Sep 30, 2015 08:35 PM
daviday
Sep 25, 2015 01:31 AM
