Drivetrain should I be running brisk plugs?
Old May 11, 2011 | 04:24 AM
C-Lop's Avatar
C-Lop
I have a CAI, 15% pulley & exhaust. Last night I put brisk plugs in and while taking off from a light my car fell on its face and the SES light came on. Expecting a misfire code I went to the autoparts store and scanned it. Came up the p0130 or whatever the o2 sensor is. I cleared it and have been driving normal and it hasn't come back. my question is, should I have switch back to the regular plugs or keep running the brisk?
Old May 11, 2011 | 12:25 PM
quikmni's Avatar
quikmni
What part number Brisk plugs did you install?
Old May 11, 2011 | 04:13 PM
C-Lop's Avatar
C-Lop
dr14s silver the code came back today so I switched back to my factory plugs. the code cleared and the car is running right.
Old May 11, 2011 | 04:47 PM
quikmni's Avatar
quikmni
I used the DR12S gapped at 0.028 and they were great but they do not last long. The 12 is one range colder than the 14. The DR14S should have worked fine. What gap did you use? Maybe a wire did not fit on quite right. I have read of people having problems with the Brisk plugs right out of the box, maybe the quality control is not great.
Old May 11, 2011 | 05:22 PM
MINI33342's Avatar
MINI33342
Stick with the NGK plugs or even go for the NGK JCW plugs.
Old May 11, 2011 | 07:27 PM
C-Lop's Avatar
C-Lop
What gap should the brisk be? I have not messed with a plug that wasn't pre-gapped in at least 15 years. I guess I should have not just trusted they would be. What part number is the NGK
Old May 12, 2011 | 03:12 AM
Professor's Avatar
Professor
I have to agree. I attempted to run the Brisk and had not so stellar results. Even some Misfires. They were gapped correctly.
Old May 12, 2011 | 05:30 AM
NH_MCS's Avatar
NH_MCS
The JCW spec NGK's are great plugs.
Old May 12, 2011 | 05:56 AM
C-Lop's Avatar
C-Lop
Part number please?!?
Old May 12, 2011 | 06:26 AM
BlwnAway's Avatar
BlwnAway
Ngk Bkr7equp
Old May 12, 2011 | 06:33 AM
quikmni's Avatar
quikmni
Even though the Brisk plugs worked great in my MCS, I now use the NGK plugs because the Brisk wore out quick.
Old May 12, 2011 | 12:08 PM
JumpingJackFlash's Avatar
JumpingJackFlash
https://www.northamericanmotoring.co...ark-plugs.html
The only advantage to Platinum and Iridium plugs is they last 100K miles. In terms of material, they are among the worst conductors. Silver is #1; Copper is #2. Only disadvantage is they have to be replaced every 30K miles.
I'm running Brisk DOR14LGS plugs, and they work great.
I highly doubt the P0130 code is related. My '06 MCS threw that code once last Spring. Was a fluke and never came back after I cleared the computer, and that was when I was still running the NGK BKR7EQUP plugs. However, if the plugs were not properly torqued, a small amount of air could be getting by, which will change your air-to-fuel ratio (AFR).
Are you still running OEM O2 sensors? If you have Bosch, read this thread: https://www.northamericanmotoring.co...-obd-code.html.
Old May 12, 2011 | 01:33 PM
Crashton's Avatar
Crashton
Originally Posted by BlwnAway
Ngk Bkr7equp
Nothing magic about this plug. It is nothing more than the stock NGK except it is 1 heat range colder. Stock is BKR6.
I've been running stock plugs in mine with a CAI, 15% pulley & JCW exhaust. Been great so far.
Old May 12, 2011 | 05:23 PM
littleone231's Avatar
littleone231
I had the exact same issues with the brisk plugs. I switched back to the stock plugs and my car runs awesome. The only upgrade is 15% pulley. NGK all the way.
maniacalmorgan
Jan 1, 2020 11:20 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
Super Coop
Aug 17, 2015 05:09 PM
Getrieben
Aug 15, 2015 09:09 PM
yashmack
Aug 15, 2015 10:16 AM
