Drivetrain BOV Blew Off!!
Old Apr 16, 2011 | 10:33 AM
iporkgoats's Avatar
iporkgoats
BOV Blew Off!!
My second run autocrossing and my bov blew out of the pipe. I heard it pop out so I doubt a loose clamp is the problem. Do I need to tighten or loosen the internal spring or just adjust the external part. It's an Alta bov.
Old Apr 16, 2011 | 10:37 AM
STi2Mini's Avatar
STi2Mini
Get rid of it and put the stock BPV back on, there's no reason to use a BOV on these cars.
Old Apr 16, 2011 | 11:11 AM
ThumperMCS's Avatar
ThumperMCS
Old Apr 16, 2011 | 11:24 AM
countryboyshane's Avatar
countryboyshane
Haaaaaaaaaaaaaaaaa ha ha ha ha I'd sell it if I were you, but there isn't much market for them on eBay. You'd probably have great success getting rid of it on the NAM marketplace. I'd block off the pipe and upgrade from the stock diverter valve.
Old Apr 16, 2011 | 11:30 AM
DneprDave's Avatar
DneprDave
Isn't the blow off valve supposed to blow off?
Alta does make a heavier spring for the stock recirc valve.
http://www.altaperformance.com/produ...Spring-Upgrade
I asked an Alta tech. If it did any good on MINIs with automatic transmissions, he said, No it didn't. The automatics shift fast enough that the boost pressure doesn't drop significantly during a shift.
Dave
drrigg
May 27, 2022 03:31 AM
unxpectederror
Oct 22, 2015 12:16 PM
martinb
Oct 7, 2015 05:00 PM
GAT
Oct 4, 2015 07:27 PM
TifosinDel
Sep 28, 2015 10:45 AM
