Drivetrain Oil Cooler
Old Apr 14, 2011 | 04:45 AM
Minionymous's Avatar
Minionymous
Oil Cooler
Does the mini have a built in oil cooler? If it does not could turbo and oil bennifit from having an aftermarket one installed?
Old Apr 15, 2011 | 03:12 AM
slinger688's Avatar
slinger688
No it does not have one and Sneed speed shop does sell one.
Old Apr 15, 2011 | 04:04 AM
Minionymous
Do you think it could help?
Old Apr 15, 2011 | 04:18 AM
slinger688's Avatar
slinger688
I have not used one so I do not have any first hand experience with the one in the Mini.
I do have one in my 997 and did have a couple in my "retired" Lotus and it seems to bring down the oil temps. But I never had any engine troubles with either of those cars.
Old Apr 15, 2011 | 05:45 AM
Big Jim Swade's Avatar
Big Jim Swade
What woud you need one for? If the factory thought the MINI needed one to would have come with it. It already has engine coolant cooling the turbo.
Old Apr 15, 2011 | 06:21 AM
slinger688's Avatar
slinger688
It might help if you were towing and/or have heavy track use. Not sure what the op had in mind.
Old Jan 11, 2012 | 06:47 PM
SneedSpeed's Avatar
SneedSpeed
If your not tracking and towing with your MINI the only real benefit is lowering the oil temp to reduce coking of the turbo bearings. Coking is when the oil in the turbo turns to carbon from overheating and gums up the shaft until it wont spin. When the engine is turned off and the oil stop flowing and sits in the turbo and over heats. The oil cooler helps reduce this by lowering overall oil temp. You can also reduce coking by letting the car idle for 15 to 30 sec or longer for hard runs to let the turbo "spool down" and cool before oil flow stops
Old Jan 12, 2012 | 04:33 AM
countryboyshane's Avatar
countryboyshane
The N14 MCS engine DOES have an oil cooler!
It is very small and located right under the oil filter housing. The German translation often translates to "lube oil heat exchanger". It uses engine coolant to cool the oil.
http://www.realoem.com/bmw/showparts...30&hg=11&fg=30
The only aftermarket oil cooler I've seen was from M7. It's a tube & fin style cooler that mounts on the radiator. Be prepared to pay $~550.
Old Jan 12, 2012 | 06:05 AM
SneedSpeed's Avatar
SneedSpeed
That is correct. you can check our oil cooler out at http://www.sneed4speed.com/sneed-spe...6-2007-and-up/
Old Jan 12, 2012 | 06:12 AM
Mymojomini's Avatar
Mymojomini
I am going to be installing an oil catch can on my Mini to keep all the blowby out of my intake and turbo.
http://www.ebay.com/itm/MINI-COOPER-...item3a5a238d21
Old Jan 14, 2012 | 09:12 AM
countryboyshane
I have no idea what this has to do with an oil cooler, but thanks for telling us
Old Jan 14, 2012 | 09:51 AM
countryboyshane
Is there enough room on the upper section of the radiator to allow for this oil cooler? It looks like where it's placed in your pictures would interfere with a larger stepped style intercooler.
Old Jan 14, 2012 | 01:43 PM
SneedSpeed's Avatar
SneedSpeed
With the big intercoolers it moves up and mounts more behind the bumper support. It still gets good airflow there just not as much as the lower mounting position.
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
zip251
Aug 30, 2015 07:15 PM
shark715
Aug 30, 2015 07:01 PM
Aug 11, 2015 09:01 AM
