Drivetrain losing boost again
Old Dec 15, 2010 | 08:10 AM
CaMiniMe's Avatar
CaMiniMe
losing boost again
i did a search on losing boost but didnt see anything that fit my problem. but right now when i drive the car hard i am losing boost when going into 3rd gear. 1st and 2nd gears are fine but the second i shift into 3rd my bost is gone BUT as fast as i can lift off the throttle and back on it the boost comes back and the car pulls hard again. im thinking if i had some kind of leak this wouldnt be the case, maybe im wrong. but has anyone else experienced this and know what might be causing it? BTW the only things i have changed are a CAI and alta inlet tube.
Old Dec 15, 2010 | 10:45 AM
countryboyshane's Avatar
countryboyshane
What are the boost pressures you're seeing?
Old Dec 15, 2010 | 12:37 PM
gkp's Avatar
gkp
I think it's a leak. By modulating the power you are kind of temporarily "fooling" the car. Go in and tighten up all the hoses and I bet it goes away.
Old Dec 15, 2010 | 12:38 PM
gkp's Avatar
gkp
Also check that there is not a leak in your Alta tube. I've heard they can have problems.
Old Dec 15, 2010 | 12:45 PM
rstrahs's Avatar
rstrahs
i had the same problem after i installed alta inter-cooler and boost tubes... it almost like the car is going into lag mode.. so all you need to do is find the boost leak and that should solve your problem
Old Dec 15, 2010 | 12:53 PM
CaMiniMe's Avatar
CaMiniMe
thanks for the input. ill check all the hoses tonight. i dont know what my bost is right now because i dont have a guage or anything else i can use to check boost. and where should i look on the alta tube for the leak?
Old Dec 15, 2010 | 04:10 PM
countryboyshane
Check at the ends making sure the connections are pretty snug. Don't overtighten the screw-clamp bands or else the edges of the clamp will start to dig into the silicone.
Old Dec 16, 2010 | 05:53 AM
BostonR56S's Avatar
BostonR56S
Check the tubing itself too. Some alta tubes are known to scrape against the engine bay/bolts/screws/nuts etc and can rip through the silicone plys.
Also, on the inlet tube, right where it connects to the turbo, the tubes are designed a bit short, so make sure the lip is covered properly and the clamp has enough grip on the turbo inlet itself.
buggyeye401
Oct 1, 2015 01:22 PM
Oct 1, 2015 12:13 PM
eliseo1981
Sep 30, 2015 07:57 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
