Drivetrain WL: R53 RMW transplant
Old Mar 3, 2011 | 07:52 AM
  #151
tcscb1963's Avatar
tcscb1963
Glad to see your back . I have enjoyed following your build.
Old Mar 3, 2011 | 12:24 PM
  #152
s00perc00per's Avatar
s00perc00per
did you run into any difficulties putting the motor back in? Im in the same boat as you and im still waiting on my motor to get back. Not looking forward to doing to the work, but definitely looking forward to a built motor
Old Mar 3, 2011 | 12:59 PM
  #153
Rainman768's Avatar
Rainman768
+1
Old Mar 4, 2011 | 12:49 PM
  #154
SteveS's Avatar
SteveS
I have a 2003 with new engine supplied by RMW. The engine is great. However the installer experienced problems with the engine wiring harness and had to replace it. You might want to do that or speak with Jan about it so it can be replaced, if need be, at the stage of reassembly when it is easiest to do that. YMMV.
Old Mar 4, 2011 | 08:41 PM
  #155
R35P3CT DA M1N1's Avatar
R35P3CT DA M1N1
there were two things i felt were difficult getting the block back in: 1) attaching my lift to the block in order to lower it in. When I took it out, I had the upper mounts still attached. Since I had the powder coated I didnt want to scratch them, so I had to find another way to get it in. 2) was the bottom motor mount. I had to wiggle the motor a little bit for it to line up.
I guess getting my ball joints off to put my axles back in has been a real PITA!
Luckily I labeled every wire/connector with its location and put every bolt into ziplock baggies with where they came from on the bag. That was probably one of the smarter things Ive done.
Basically just go slow while putting it in, that way you dont accidently pinch something important in between the motor and the car.
Old Mar 5, 2011 | 12:37 PM
  #156
howsoonisnow1985's Avatar
howsoonisnow1985
Originally Posted by R35P3CT DA M1N1
i have a buddy that just recently moved to Alameda, so if i ever visit him to go skiing/snowboarding with him somewhere out there, that would pretty much be the extent of my nor cal travels. So depending on your location, i could possibly take you up on that.
Yep close to alameda too. Nice driving roads towards snow as well.
Old Mar 5, 2011 | 01:59 PM
  #157
CrazyIvan's Avatar
CrazyIvan
This makes the reinstall about 10 times easier.
Old Mar 6, 2011 | 09:10 AM
  #158
DneprDave's Avatar
DneprDave
I helped a friend do a restoration of a Morris Mini Minor, he wanted to take it apart himself and have me help him put it together. I told him to label all the parts as he took it apart.
When I got there, there was a jumble of parts in the corner of his garage with a sign on it saying, "Morris parts"!
I guess it helped him tell them from. "Bicycle parts" and "Lawn mower parts"!
Dave
Old Mar 28, 2011 | 01:26 AM
  #159
R35P3CT DA M1N1
worked a little bit on it tonight after work.
got my cabrio braces on and then just some more electrical plugs back together.
I was thinking at work, Im pretty sure I can almost put my modular front end back on.... guess we'll see
Old Mar 28, 2011 | 06:54 AM
  #160
Revolution Mini Works's Avatar
Husker Red!!!!!!!!!!!
git er done!
Old Mar 28, 2011 | 07:49 AM
  #161
s00perc00per
im catching up! i think ill be up and running tomorrow.
Old Mar 30, 2011 | 05:15 AM
  #162
newbs49's Avatar
newbs49
Looks like your getting there. Get that puppy running!!!!!!!!!!!!!
Old Mar 30, 2011 | 08:47 AM
  #163
Thr-apy's Avatar
Thr-apy
ground wire placement
If anyone ever does a swap or motor work which requires disconnecting the main wire harness there is a mystery Ground coming off the main Harness ( this goes on the starter). examples are not noted in the Bentley Manuel and almost impossible to find a post of the same anywhere.
basically when your done you should have two wires going to the larger bolt on the starter. the only way we found this was to use my mini as a refresher after trying to find information on it elsewhere with no success.
hope this post will help someone down the line.
J I'll be over after my wife gets home to help out.
Old Apr 6, 2011 | 01:35 AM
  #164
R35P3CT DA M1N1
did some work tonight.
I was working on my oil pressure gauge the other day, and accidently kinked the nylon hose that is supplied by autometer. So i ordered a stainless line to fix that problem. no more kinks
Had to put my CAI back on to make sure the line wouldn't get in the way as i ran it through the firewall
and then finally got my header bolted up.
now i have to get some homework done before a round of golf tomorrow morning so i have free time tomorrow night to get more work done. I finally found some paint that matches the powder coat really good, so the valve cover is getting some color. As soon as the valve cover is on, i am ready for intercooler, and then modular front end.
Then off to a buddies shop for new ball joints and alignment. He is also going to be welding my v-band clamp onto my mid pipe. then back to my place for for some finishing touches, get a flash tune from jan and then start it. cant wait.
Old Apr 6, 2011 | 05:03 AM
  #165
minimarks's Avatar
minimarks
Woot, bought time to put some fire in tune holes!!!
Old Apr 6, 2011 | 09:19 AM
  #166
k-huevo's Avatar
k-huevo
The over all length of the coupler and oil sensor/sending unit makes it susceptible to cracking at the housing due to vibration. I recommend rethinking that arrangement.
Old Apr 6, 2011 | 10:11 AM
  #167
mini_racer's Avatar
mini_racer
+1
That is quite the lever arm you have there.
Old Apr 7, 2011 | 09:32 PM
  #168
R35P3CT DA M1N1
came in for supper, now headed back out to finish up the front bumper.
it was raining all day so I couldnt paint my valve cover yet, hopefully I have time to do it tomorrow.
Its going out on Monday for an alignment and getting my v-band welded on.
Old Apr 8, 2011 | 10:16 AM
  #169
R35P3CT DA M1N1
gap still needs adjusted.
Old Apr 8, 2011 | 11:57 AM
  #170
Rainman768's Avatar
Rainman768
Looking good!
Old Apr 8, 2011 | 07:12 PM
  #171
R35P3CT DA M1N1
hooked the battery back up. then read the ecu so i can send the file to Jan. Now when it gets back from the shop, i can flash the ecu with the new file from him and be ready to start.
Old Apr 11, 2011 | 12:22 PM
  #172
R35P3CT DA M1N1
Should be back friday.
Old Apr 15, 2011 | 11:36 AM
  #173
R35P3CT DA M1N1
havent called the shop yet to see if the MINI is done yet, but I've been playing with the idea of powder coating my rims a "candy gold" color.
All last night i was looking for pictures of chili red with bronzish rims, and i kinda really want to change it up.
I guess i have some time to think, I was told mid next week for them to be blasted, then going to take them TMCO powdercoat. One of them had a little ding on the inside lip that i am going to take to a rim repair shop before pc.
The color ive been eying looks like this:
Old Apr 15, 2011 | 11:38 AM
  #174
R35P3CT DA M1N1
maybe something like this
Old Apr 15, 2011 | 01:08 PM
  #175
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
I love bronze! Think it would look *****.
