Drivetrain WL: R53 RMW transplant
Old Nov 7, 2010 | 07:05 AM
  #76
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Well when you are working outside any progress is good progress in the winter. What clutch are you using, I couldnt tell from the pic?
Do you think you could make it to MITM6 this year, it is going to be at Winter park CO. again on Aug 4-7(acording to MINI5280's website)?
Old Nov 7, 2010 | 09:17 AM
  #77
R35P3CT DA M1N1's Avatar
R35P3CT DA M1N1
The clutch is Clutchmasters FX400 clutch and flywheel package.
And I will put MITM on my calendar, I have wanted to go ever since Ive bought my MINI, but scheduling just never works out. After this build is over, I think I will be trying ALOT harder to go on motoring trips because I am going to be having so much fun driving the MINI again.
Old Nov 7, 2010 | 10:58 AM
  #78
Revolution Mini Works's Avatar
don't mess with the supercharger..........
Old Nov 7, 2010 | 12:13 PM
  #79
JPMM's Avatar
JPMM
why not?, seemed like a good idea
Old Nov 7, 2010 | 04:08 PM
  #80
R35P3CT DA M1N1
Those two little ports are just the silencing ports I thought. Does it really affect the efficiency? Im just going off what is common practice with the Cobra and lightning eatons ....
Old Nov 8, 2010 | 05:23 AM
  #81
DICKS GARAGE R53
The noise ports on the M45 can be sealed but, you will loose power due to more heat coming out of the S/C, on top of a insufficent I/C system.
Old Nov 8, 2010 | 07:15 AM
  #82
DICKS GARAGE R53
I started typing earlyer in my last post, but had to cut it short because my internet time was up, but...
Sealing the sound ports causes extra heat, but you might be able to get around some of that by porting the discharge port further back than just the little triangle in the stock case. M7 had a ported S/C listed for a while but discontinued it about the time they canned production of their larger throttle bodies. They where pretty expensive and not mutch gain in power at all, but they left the sound ports open who knows what would of happened if they welded them closed.
There are people who claim that any welding on that area of the case will warp the housing. If that where true you would be SOL and need a new S/C.
In my opinion a good tig welder and an operator that knows what they are doing can pull it off.
There are also better options if you could send your S/C away for a couple weeks. WAY at WMW can have your charger rebuilt, and in the process have it coated with better ceramic than the JCW/2005+ cars came with.
If you are still hell bent on sealing the ports, I would highly recomend running a water meth setup. Maby even a dual nozel setup with (Many people will argue this for some legitamate reasons) a 1GPH nozel pre S/C to help cool the S/C's inards.
Old Nov 8, 2010 | 07:18 AM
  #83
or you could just wait for what's coming................
Old Nov 8, 2010 | 10:32 AM
  #84
AK.JCW's Avatar
AK.JCW
Hurry, my popcorn is running out...
Old Nov 8, 2010 | 10:35 AM
  #85
R35P3CT DA M1N1
Deal.
Btw: I will be calling sometime today. Hopefully. :D
Old Nov 8, 2010 | 10:49 AM
  #86
as Ali once said.......... I shocked the world
Old Nov 8, 2010 | 04:32 PM
  #87
minimarks's Avatar
minimarks
"Float like a butterfly, sting like a bee...."
Old Nov 8, 2010 | 05:48 PM
  #88
davisflyer's Avatar
davisflyer
Damn, and I just started my kitchen remodel!!!!
Spring can't come soon enough!!
Old Nov 8, 2010 | 09:23 PM
  #89
newbs49's Avatar
newbs49
Old Nov 8, 2010 | 11:36 PM
  #90
scolburn79's Avatar
scolburn79
Damn it, I hate it when he does that!!!!
Old Nov 9, 2010 | 03:07 AM
  #91
JPMM's Avatar
JPMM
how much more wait and how much more ?
Old Nov 9, 2010 | 03:39 AM
  #92
Dex05S's Avatar
Dex05S
Old Nov 9, 2010 | 04:54 AM
  #93
It's felt like this getting stuff done lately with SEMA etc but things are now underway. Knowing who is involved I would say it will be worth the power wait
Old Nov 9, 2010 | 05:16 AM
  #94
minimarks's Avatar
minimarks
These guys don't play, it'll be well worth the wait!
Old Nov 9, 2010 | 11:40 AM
  #95
Hooptie64's Avatar
Hooptie64
Hints???
Old Nov 9, 2010 | 01:55 PM
  #96
MiniMacPR's Avatar
MiniMacPR
Suggestion: let's not hijack this thread.
Past history suggests that threads were Jan hints at a new upcoming, secret, yet to be defined except to his innermost circle, uber performance increasing invention, usually get derailed eventually.
I'm waiting for Mr. R35P3CT to install and fire up the monster to see how she breathes!
Old Nov 9, 2010 | 08:31 PM
  #97
R35P3CT DA M1N1
not to break up the excitement from Jan's news, but i did get the limited slip installed tonight and the transmission is back on the block. Still waiting for some gaskets from MINI Mania, and then I should be able to finish everything.
Old Nov 10, 2010 | 05:23 AM
  #98
can't wait to see it go
Old Nov 10, 2010 | 07:15 AM
  #99
DICKS GARAGE R53
Mini Mania likes to take their time, but they do have just about everything. If you ever need something in a rush give WAY (WAY MOTOR WORKS), or Chad (Detroit Tuned) a call.
I want an LSD, and a lower gear set, but I will need to peg leg it around until I can aford it.
Old Nov 10, 2010 | 10:32 AM
  #100
R35P3CT DA M1N1
I have been getting parts from Way a lot because they can arrive in 1-2 days. I had to go through mini mania because these were special order stuff that just make me feel better while putting everything together.
Everything has been getting a good cleaning. Having this super clean block, I hate the idea of having all these dirty parts on it.
