Drivetrain HELP! Idle is WAY too rough.
Old Sep 13, 2010 | 04:58 PM
jollyroger927's Avatar
jollyroger927
I don't want to go over how this happened, but basically I had to take cylinder head off my car to get part of a compression tester out. I also had 2 bent valves replaced.
I put everything back together and the timing was off. The car would also rev really high continuously. I had it towed to a shop and the timming fixed. But they can't fix the idle problem. It literally revs to 3,000RPM or more.
Any Ideas? Thanks.
Mods:
S/c pully
intake
rmw header
alta catback
rmw cam
rmw tune
Old Sep 13, 2010 | 06:29 PM
HRM's Avatar
HRM
Man that sounds like a sad story. I feel for you. I can't think of anything you probably have not tried already (Like disconnecting battery and/or scan for codes, check all wires/hoses) Really you have to list just about everything you have tried so folks won't suggest them again.
How about visually checking throttle butterfly to make sure it is closing properly?
Best I can come up with.
If it looks OK, maybe disconnect throttle position sensor to it and generate a code, then clear it. I am fishing here, but who knows?
PS, promise once this is over you tell your sad tale so we all feel better when we are in your shoes.
Old Sep 13, 2010 | 09:23 PM
2mD's Avatar
2mD
sounds like a leak somewhere between throttlebody and engine... ( youve got an air/fuel gauge ? is it showing way lean ? )
like faulty supercharger duckts, or fuel injection o ring ( happend to me once )...
try spraying start pilot ( or something like that ) on to these parts while engine is running -> if it revs even higher that instand you found the leak.
Old Sep 13, 2010 | 11:09 PM
jollyroger927
They said there weren't codes. Ill check again. The intake duct in between the s/c and the throttle body isn't bolted up, but it was broken for awhile and was just held in by the pressure of everything else on it.
They said they reset the throttle body. Could a messed up PCV do this?
2md can you tell me about your injector o ring story? thanks.
And what do you mean start pilot? Thanks for the help guys, keep the ideas coming. Its been the worse week of my life =/
Old Sep 14, 2010 | 05:23 AM
soccerbummer1104's Avatar
soccerbummer1104
start pilot is starter fluid (its an aerosol) if you spray it near a leak in the intake it will get sucked up and used as fuel in the engine causing it to rev higher momentarily as it burns.
Old Sep 14, 2010 | 06:20 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
I would go back and check your work again. Sounds to me like the ECU is seaching to compensate for correct idle due to something not hooked back up.
There are two rather large lines which are tied into that lower intake duct as well. One is for the manifold air pressure sensor.
Old Sep 14, 2010 | 07:01 AM
jollyroger927
the hard lines? i never actually removed the plastic duct thats the thing.
Old Sep 14, 2010 | 09:02 AM
2mD's Avatar
2mD
i had a slightly rough idle, a faint whistle ( under load ), boost was lacking slightly and even on idle the vacuum wasn't as great as before
turned out the o ring of one of the injectors was bad / had a cut
wasn't visible at first, only after i stretched it it became visible.
Old Sep 14, 2010 | 09:06 AM
jollyroger927
https://www.northamericanmotoring.co...242-p0300.html
The same thing on mine is broken, and it seems he had the same problem. I didn't think I broke it, but I guess I might have. Im going to try and buy one today.
Old Sep 14, 2010 | 12:38 PM
jollyroger927
What I mean by "I didnt think i broke it.." is that i saw that the mount for it was broke, but i thought the car was running like that, didn't think I broke it
Old Sep 14, 2010 | 10:46 PM
jollyroger927
I replaced that intake duct and the car is basically back to normal now besides the EML light being on, and having no power. But the car idles okay and the timing seems to be perfect.
No Idea why the light is on, i'm thinking a vacuum leak somewhere but i'm not sure where. I also don't know what the EML light means. I'm going to do some research.
One more weird thing was this VERY odd vacuum noise i heard at idle for about 5 minutes but so far is hasn't come back.
Old Sep 15, 2010 | 04:57 AM
BlwnAway's Avatar
BlwnAway
I would think that if it idles smooth it's not a vacuum leak. Have you tried doing a basic ECU reset since you did your fix?
Maybe there is an adaptation from your earlier problem that has not reset. (at least you'd be starting ftom scratch as far as that goes.)
Old Sep 15, 2010 | 09:47 AM
jollyroger927
Yea i reset the ecu already, and it did behave better after that but still is in limp mode with a EML light.
Old Sep 17, 2010 | 11:46 AM
jollyroger927
Bump. Any ideas?
Old Sep 17, 2010 | 12:50 PM
-=gRaY rAvEn=-
Moderator
post #4 - "The intake duct in between the s/c and the throttle body isn't bolted up".
Thought it was.
Old Sep 17, 2010 | 11:06 PM
jollyroger927
it was in place, but the mount was broken. then when i put it back together the first time, it got misaligned and that was the idle problem.
But now its a new duct and is in place, i even took it apart and double checked today to see if the gasket was on right. It is.
Old Sep 17, 2010 | 11:36 PM
BruceWarne's Avatar
BruceWarne
How did you reset the ECU?
Old Sep 17, 2010 | 11:58 PM
jollyroger927
through the speedometer/clock. The way its supposed to be done ive heard.
Old Sep 19, 2010 | 12:13 AM
jollyroger927
Im still really confused as to what this could be. Im going to check fuses tomorrow and triple check my throttle body connection.
If anyone else as ever had the EML light after doing something, please let me know what it was. Thanks.
11psi sucks when your use to 18 =[
Old Sep 23, 2010 | 08:44 PM
jollyroger927
Okay so i was driving tonight, got on it and then the rpm's dropped to 2,000 rpm's and wont go over that. I can turn off the car and it'll act normal untill i try to boost, when i do that there is no boost at all. EML light is on, SES light is on and DSC light turns on.
Its 12 am and im to tired to tear it apart right now. Any one experience anything like this?
Old Sep 24, 2010 | 04:01 AM
-=gRaY rAvEn=-
Moderator
No CEL's ? Did you scan for codes ?
Old Sep 24, 2010 | 07:00 AM
BlwnAway's Avatar
BlwnAway
Sounds exactly the same as when my throttle body went bad. Would run completely normal as long as you didn't try to open it up, would be back to normal after restart.
Also, I just reviewed the thread, no codes mentioned, they would be very helpful.
If you don't have one the cheap acutron obdII from autozone works just fine for reading and clearing.
Old Sep 24, 2010 | 09:29 AM
jollyroger927
I had one on my old laptop but i forgot the name and dont have the computer anymore. Ill try getting another one.
Now it seems that the limp home mode doesnt happen anymore, but im still only making 8psi max.
Old Sep 27, 2010 | 06:59 AM
jollyroger927
Swapped the bypass valve, and reset the ecu and everything went back to normal.
Might have lost a couple psi from the valve change/head removal and all that, or it could be because i took my resonator off and freed up the exhaust more, either way 17 psi feels a HELL of a lot better then 8psi or none.
Thanks for the help.
Old Sep 28, 2010 | 06:42 AM
JumpingJackFlash's Avatar
JumpingJackFlash
I hate when one problem blows up into several in the sense you fix one problem only to discover another, then another.... Glad you're through that.
scfiveo
Sep 27, 2019 02:27 PM
navybsn
Oct 4, 2015 03:27 PM
micromini234
Sep 30, 2015 07:36 PM
Miniwaukee
Sep 29, 2015 09:22 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
