Drivetrain Drawing for Camshaft Gear Holding tool
Old Sep 28, 2010 | 10:00 AM
Mini SUV's Avatar
Mini SUV
Does anyone have a drawing for the Camshaft Gear Holding tool or dimensions for a similar tool that will work?
Thanks!
Attached Thumbnails Drawing for Camshaft Gear Holding tool-cam-gear-tool.jpg
Old Sep 29, 2010 | 06:18 AM
Mini SUV's Avatar
Mini SUV
Hi Mini SUV!
Well no one seems to have tool dimensions for the tool, but we did find some useful information on similar threads. We'll probably order the RMW street CAM when the wife isn't looking.
Old Sep 29, 2010 | 08:07 AM
CRoth's Avatar
CRoth
The tool isn't needed. I changed my cam with keeping the transmission in 6th gear. There was plenty of hold to remove and reinstall to the proper torque setting. If you need additional locking strength, just have someone sit in the car and push the brakes while you apply torque.
I had my own version of the cam locking tool made and realized I didn't need it at all. I figured I'd give it a try with the transmission in 6th first. It worked.
Old Sep 29, 2010 | 08:35 AM
Mini SUV's Avatar
Mini SUV
Thanks CRoth, I'll probably use the high gear method with a tie-wrap to keep the chain on the correct gear teeth. I was a little worried about keeping the cam gear in place during the swap procedure.
Old Sep 29, 2010 | 12:00 PM
JumpingJackFlash's Avatar
JumpingJackFlash
If you are worried about keeping the gears and/or chain lined up, you can always mark it with a paint marker. I keep a yellow one in my toolbox for that kind of stuff (especially when you want to maintain the timing with a distributor against the intake manifold of a small-block V8).
h0micide
Aug 27, 2015 09:17 PM
h0micide
Aug 25, 2015 12:19 PM
minipopkart
Aug 13, 2015 05:22 AM
Aug 12, 2015 01:24 PM
