Drivetrain New R53 A2A Intercooler from DoS
Old Sep 6, 2010 | 10:00 AM
  #26
miniconcarne's Avatar
miniconcarne
Originally Posted by DICKS GARAGE R53
So why not a small grille mounted front mount?
...maybe for the same reasons already explained
Originally Posted by Mini'mon
This is a great question that comes up for us a lot at MINI festivals and events and from customer Q&A.
Direct Flow Intercoolers are interesting, and we looked to see if this type of design could be of benefit. However, you always need to take into account 2 factors:
1) The second half of any intercooler core does only 1/4 of the the work. Air gets warmer as it gets deeper into the core. The front half of the core does a great job, but the back half of the core suffers due to progressively increasing air temps.
2) Even though the airflow is 'direct', because this is a very thick core, there's a great amount of drag on the cooling air passing through. The drag on the incoming air actually increases the deeper that you go into the core.
When an exit scoop is involved, the first factor can likely be somewhat minimized, but that involves some substantial cutting to bonnet sheet metal.
-Clint
Old Sep 6, 2010 | 10:13 AM
  #27
MINI33342's Avatar
MINI33342
Personaly I would like to see the same design cues you used (copper fins, brass tubes, and the airfoils) on a flow through design like M7's DFIC, That would be one that I would spend a grand on.
Nothing against your I/C, just dont care much for the 90 degree turn method of airflow.
But it is a proven design, the "flow-thru" ones don't perform as well.
Old Sep 6, 2010 | 11:54 AM
  #28
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
MINICONCARNE, A front mount I/C and a flow through are 2 totaly different things. A flow through like the DFIC is about 7 inches thick but only 5 rows deep. A front mount I/C is designde the same as the one featured in this thread but, located in the front bumper or grille area positioned up and down (NOT flat like pancake).
MINI33342, Front mounts have prooven to out perform ANY top mount system, as far as cooling goes. There is nothing to heatsoak an I/C that is away from all the heat to start with,plus it grabs a whole lot more air over more surface area with no post I/C blockages to restrict airflow. Another good side effect would be that it would get rid of all those sharp almost 180 degree turns that the stock bullhorn setup makes.
Old Sep 6, 2010 | 01:19 PM
  #29
Mini'mon's Avatar
Mini'mon
Upgraded front mount IC's are great if the car was originally designed as a front mount. However it's not a plug and play mod for the R53. The front mount units that have been designed up to this point do some or all of the following:
1) require removal of the AC condenser
2) require cutting & drilling.
3) add additional plumbing and volume to the charge air path
3) are part of aftermarket R53 turbocharging or supercharger systems that already necessitate the mods mentioned in item #2 (due to their redesigned charge air tubing designs).
I've liked the concept of a front mount ever since it was first introduced to the MINI community and I'm glad that you brought it up. I also think that they're great for cars that see mostly track time. However, it's just a more complicated mod than DoS wanted to get into.
-Clint
Old Sep 6, 2010 | 02:08 PM
  #30
miniconcarne
Clint, sounds like you did your homework. I know front mounts have been attempted before. Besides, this isn't about them, and hopefully we can see more updates on what you do sell.
Old Sep 7, 2010 | 09:13 AM
  #31
HAVNPHUN's Avatar
HAVNPHUN
-Clint
And if these changes were made with our little M45 blower in place, the pressure drop would make the whole exercise moot.
Old Sep 7, 2010 | 04:48 PM
  #32
MINI33342's Avatar
MINI33342
-Clint
Thanks for the concise response. Some folks just need a bit of edumacating !
Old Sep 7, 2010 | 09:36 PM
  #33
jimz68's Avatar
jimz68
Hmmmmm........Might have to dump the ol' GRS.
Jim
Old Nov 9, 2010 | 10:59 AM
  #34
4wheels's Avatar
4wheels
Any more progress or updates?
Old Nov 9, 2010 | 11:44 AM
  #35
Mini'mon's Avatar
Mini'mon
Our IC core manufacturer assures us that the production cores will ship this week. After then, we can do our last pressure drop tests/comparions on the refined production cores and endtanks -vs.- the stock and GP IC.
We don't want to base our final product performance claims on prototypes, so things have been stalled a tad. Many thanks for your patience. We're chomping at the bit to release these.
-Clint
Old Nov 10, 2010 | 04:37 PM
  #36
R53Warrior's Avatar
R53Warrior
Sounds good. Looking forward to testing results!
Old Nov 11, 2010 | 05:35 PM
  #37
newbs49's Avatar
newbs49
Keep us informed on your tests.
Old Nov 14, 2010 | 01:01 PM
  #38
slapshot591's Avatar
slapshot591
Definitely keep the updates coming. I can't wait to see a final product!
Old Nov 17, 2010 | 11:17 AM
  #39
4wheels's Avatar
4wheels
When you have an extra one, send it overr to Jan to test so I'll know if it's worth putting on a stroker!
Old Nov 17, 2010 | 12:53 PM
  #40
JumpingJackFlash's Avatar
JumpingJackFlash
This new design looks promising. There is alot more mass to the intercooler, as well as the heat disippation coating. In addition, it would also be nice to have a specially-designed deflector bolted on the top. The stock one does work in catching air to force it across the stock intercooler. Here's one of my favorite links to a DIY integrated deflector: https://www.northamericanmotoring.co...6-post125.html.
In reviving an old thread on intercooler tests: https://www.northamericanmotoring.co...ing-tests.html. They tested five intercooler designs at the time, including the stock one. Unless you bought the GP intercooler, there was no real gain above the stock one. The stock intercooler has one of the best heat soak recovery periods out there.
To me, it's only worth getting an aftermarket intercooler if you do serious mods, such as a head and/or cam. Otherwise, you're better off just getting the stock intercooler coated. Here are some pictures of mine: https://www.northamericanmotoring.co...05-post27.html. Here's a post with some links explaining the thermal coating: https://www.northamericanmotoring.co...32-post43.html. I have that combined with the M7 Extreme Scoop.
Now, having said all this, I am planning on getting an upgraded head and cam next year. Once I do, and this new intercooler proves to make a difference, I will give it serious consideration.
Last edited by JumpingJackFlash; Nov 17, 2010 at 12:54 PM. Reason: Added notation about M7 Extreme Scoop
Old Nov 17, 2010 | 12:57 PM
  #41
Mini'mon's Avatar
Mini'mon
We will make a believer out of you over the next few weeks.
Old Nov 17, 2010 | 01:30 PM
  #42
newbs49's Avatar
newbs49
Will you have any independant testing done by anyone. Hope the next few weeks get here soon. Looking forward to tests against the GP intercooler. Please keep us informed.
Old Jan 21, 2011 | 09:37 AM
  #43
davisflyer's Avatar
davisflyer
Any updates??
Old Jan 21, 2011 | 10:49 AM
  #44
Mini'mon's Avatar
Mini'mon
Our core manufacturer packed our order poorly and 50% of our first production run arrived damaged. We contacted them and they sent replacements for the damaged cores. This order was packed slightly better but ALL of the replacement cores arrived damaged.
Long story short, we've taken these guys behind the woodshed and told them that they need to adhere to DoS's shipping and packaging spec or we'll find another manufacturer. The parts that arrived un-damaged are fantastic! However, we don't want to have a bunch of folks with parts on backorder. This will only pass our frustration on to the customer.
Sit tight. I know that these are being released way : later than planned, but we're still excited about our end result.
-Clint
Old Jan 30, 2011 | 07:35 PM
  #45
JumpingJackFlash
Thanks for the update. Things happen. Hoping you get them ironed out.
Old Jan 31, 2011 | 12:51 AM
  #46
unxpectederror's Avatar
unxpectederror
cant wait to see the end results
Old Feb 2, 2011 | 11:22 PM
  #47
rastablaze11's Avatar
rastablaze11
the agony its killing me... jk i can wait for the best intercooler out. r53 is the reall MINI cooper
Old Feb 2, 2011 | 11:34 PM
  #48
Mini'mon's Avatar
Mini'mon
It's killing us too . . .
The replacement order of production cores are arriving next week.
We need to get them on our pressure drop testing setup, post the results, get these on the site and get these into the wanting public's hands as quickly as we can assemble them.
Patience is good, but this current experience in getting production parts to market is definitely killing us inside a little every day we're made to wait.
Old Feb 3, 2011 | 06:59 PM
  #49
unxpectederror
i really hope good things come from this
Old Feb 4, 2011 | 12:27 AM
  #50
Mini'mon's Avatar
Mini'mon
Thanks. We know good things will result, but we want to document our testing well and make sure that our quality remains top notch. It's a tall order every time we design and build parts, but SO worth it.
