Drivetrain Port and Polish
Old Aug 30, 2010 | 09:55 PM
slapshot591's Avatar
slapshot591
Port and Polish
Has anyone ever fitted a port/polished set of intake horns and/or a ported supercharger? I'm looking into getting such supercharger and couldn't find anything on NAM about it. Any personal users of a ported supercharger?
Old Aug 31, 2010 | 09:30 AM
2mD's Avatar
2mD
i did the intake horns and the intake manifold... you dont gain much ( if any ) :(
( but i knew that beforehand )
Old Aug 31, 2010 | 09:25 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We've been making and selling our Ported and Polished Manifolds for awhile. They showed a huge improvement the flow bench, but we haven't seen huge gains on the dyno.
Old Aug 31, 2010 | 10:07 PM
Dr Obnxs's Avatar
Dr Obnxs
I'm running them all
P/P SC horns, intake, SC and head. Like Way said, they flow great on the bench but appearantly aren't that much of a bottle neck for the intake path so you don't see a lot at the wheels.
I have no clue if the SC benefits are real or not. Since all the parts went on at once, I can't back out the adds from each one.
there was a ton of interest on the subject years ago (2003 or so?), but it's died down. There are a couple ways it's done. I think Endyn welds the sound ports closed, whereas Steigemeier doesn't I don't know that it's worth the money, but if you're having your SC rebuilt (they only last so long), it's not a big cost adder to get your case worked over while your at it.
Matt
Old Sep 2, 2010 | 07:41 AM
slapshot591
I figured they wouldn't do much. I do like the idea of more flow however. Seems like it'd be easier to get more fresh air, which means lower IATs?
Nothing I'm interested in yet. I need to get some other basics done before I start spending money on port and polish haha.
Old Sep 2, 2010 | 08:58 AM
astrochex's Avatar
astrochex
ENDYN has been porting intake manifolds and intake horns for many years:
Old Sep 3, 2010 | 07:51 AM
hunter99's Avatar
hunter99
Waylan,
Just curious, what have been the dyne results? 1 to 3hp? More or less? Just curious. Also wonder if this shows more or less improvement with or without a head , cam, header, catback exhaust, or intake. A lot of work to test for all of that but variations could be the key.
Old Sep 3, 2010 | 08:00 AM
Helix13mini's Avatar
Helix13mini
We installed a modified supercharger: one where the triangular vents in the outlet of the charger had been eliminated. With great anticipation, we put it on our dyno, and saw no measurable change. We've also knife edged the driver's side bullhorn, but I don't think we've ever tried to isolate that mod on the dyno.
Old Sep 4, 2010 | 01:05 AM
KC Jr 54's Avatar
KC Jr 54
The triangular ports in the S/C are the "silencer ports" and filling them in supposedly, will increase IATs, increase S/C whine (noise) levels, and have no real effect on HP output. This is gathered from a S/C rebuilding companies site that i cant think of atm.
Old Sep 4, 2010 | 09:15 AM
Dr Obnxs's Avatar
Dr Obnxs
I don't understand the theory...
they lower the sound by letting the air mix more as the rotors turn. It allows higher pressure air to bleed into the SC rotors before they get to the exit port where it's all forced out. This has got to increast turbulence and friction in the air. I think the higher IATs are from building more boost!
Because the M45 is being pushed so close (past) it's thermal sweet spot, any time you make it work to higher boost results in a larger degree of heating.
That said, I don't know of anyone who cared to do a compare and contrast with the two different approaches on the MINI. But whatever happens, no one who's used a P/P SC on an R53 has had any good information about it building more power or not!
Matt
ps, I'm also guessing that those that don't fill the ports have an explanation as to why that's the better way to go, just like those that do fill them are sure that it's the right way to go!
Old Sep 4, 2010 | 10:47 AM
KC Jr 54's Avatar
KC Jr 54
I agree with you. From a "logical" view on things, filling them in could nothing but help overall performance. But simply, those holes are there on every Eaton unit made, regardless of platform.
Stiegemister:
We can and do epoxy the silencer holes.
There is a slight noise increase.
Boost and IAT's not effected.
The Cobra's have not noticed a difference (in sound) with the silencer holes plugged but have noted increased temps.
Entertaining thread concerning this matter: http://www.redlineforums.com/forums/...cer-holes.html
Old Sep 5, 2010 | 04:45 PM
slapshot591
yeah I'd have to say capping the silencer holes could be a bad idea; could mess up the flow inside the housing, but I'm no engineer. Don't get me wrong, I'm all up for more whine if doing so is safe to do.
Old Sep 5, 2010 | 10:31 PM
fishead # 1's Avatar
fishead # 1
s/c
Have the rotor blades re-coated and new roller bearings installed~~~~~You DON'T want any more than 20lbs anyway so efficiency is really the "key " OBEY
Old Sep 5, 2010 | 10:33 PM
fishead # 1
s/c
Have the rotor blades re-coated and new bearings installed~~~~~You DON'T want any more than 20lbs (ecu / pistons) anyway so efficiency is really the "key " OBEY
OutMotoring
Mar 3, 2017 06:29 AM
bahman
Aug 6, 2016 07:19 AM
flpat73
Nov 2, 2015 06:38 PM
micromini234
Sep 30, 2015 07:36 PM
Sep 2, 2015 11:15 AM
