Drivetrain 2003 Mini R50 Hood Cowl vents
Old Aug 12, 2010 | 01:38 PM
Michaeldavitt's Avatar
Michaeldavitt
The foam is about gone in my cowl vents, is there replacement foam for these? Has any one tried using dark plastic screen door mesh instead, any other ideas.
thanks
Michaeldavit
Old Aug 12, 2010 | 03:08 PM
Capt_bj's Avatar
Capt_bj
I used stainless gutter screen material. Any decent tin snip or a good garden trimmer scissor cuts it. I've used the same materiel to replace the plastic inserts in the back bumper with a 'steel mesh'. If you have cutters this mod is about $4
Old Aug 12, 2010 | 03:19 PM
ernesto's Avatar
ernesto
Coordinator :: Chicago MINI Motoring Club
I used window screen mesh for mine.. Not too hard to do. I used metal because that is what I had laying around, but I think the fiberglass mesh would have been easier to work with.
Picture Here
Old Aug 12, 2010 | 03:31 PM
Michaeldavitt
Excellent I will try this tonight, after a visit to the helpful hardware place!
Old Aug 14, 2010 | 05:16 PM
Dibz's Avatar
Dibz
What exactly does the screen mesh do? Is it necessary for it to be replaced?
Regards
Dibz
Old Aug 14, 2010 | 06:15 PM
broadwayline's Avatar
broadwayline
Get the 2005-2006 OEM facelift vents, they do away with that foamy mesh that comes with the 2002-2004 which breaks apart and looks awful.
They are also much nicer looking
Old Aug 16, 2010 | 08:02 AM
Michaeldavitt
Right below the windshield wipers are two cowl vents - the foam in mine has rotted away. Over the weekend I purchased some Stainless Screen, cut it to size and inserted in the vent looks great. If this does not hold up I will purchase the new version, thanks Broadwayline.
Old Aug 16, 2010 | 08:09 AM
Michaeldavitt
Ok new question, I had the wheels off to clean all the brake dust off the back. When I had the front driver's wheel out I noticed I have a cracked
fender liner right next to my driving light connections. How hard is it to replace that part?
Old May 11, 2013 | 10:53 PM
AutoCoarsen's Avatar
AutoCoarsen
Bumping an old thread with a related question. Is the foam the only thing under these vents? I just got an R50 and it looks like rain/water can just drip right onto the ABS unit. Am I missing something under there to shield that?
Old May 12, 2013 | 06:32 AM
Capt_bj's Avatar
Capt_bj
that's all .... the newer vents are even more open.
SosoMINI
Nov 22, 2015 03:17 PM
wkp1219
Nov 13, 2015 07:52 AM
joelcseymour
Aug 7, 2015 12:43 PM
Aug 7, 2015 05:56 AM
