Drivetrain HELP!!- 06s running WAY to lean!!
Old Jun 23, 2010 | 09:10 AM
  #26
stevecars60's Avatar
stevecars60
Originally Posted by Helix13mini
The fuel pump and filter are rarely the problem. It can happen, but it's rare.
Some posts have questioned whether your testing methods are giving you true results (if you car is actually running lean). White plugs and lean conditions at the tailpipe is irrefutable evidence that you have a problem. The AFRs from a tailpipe sensor will be no more than .5 ratio difference from the upstream O2 sensor: it will not 'show lean' because it's been through the cats.
I like the suggestion to go to some factory injectors and see if that solves your problem. Except for extreme tuning projects, 550cc injectors are very big: you could be running into scaling issues.
I like this - could be scaling @ 50%....... or less.... maybe???
Just out of curiousity where does the OE get the data to adjust the AF if not from the upstream O2?? On my car it's in front of the pre-cat - stock header.
Old Jun 26, 2010 | 06:30 AM
  #27
bebop86's Avatar
bebop86
Here is a pic of the o2 sensor on the mynes header- could my problem be that the sensor is not at the 10-12 oclock position-??
Old Jun 26, 2010 | 08:43 AM
  #28
onasled's Avatar
onasled
Originally Posted by bebop86
Attachment 48240
Doesn't have to be at 12. Just not below 7 and 4 or else it pics up moisture.
Anyway, that's the post cat O2 so it should have nothing to do with AFRs. (I may be wrong of course).
Thought you were bringing it down to Helix?
Old Jun 26, 2010 | 08:52 AM
  #29
stevecars60
^^ I believe you're 100% right. It has always been the pre cat for AF & EGT...
Old Jun 28, 2010 | 08:57 PM
  #30
J Propane's Avatar
J Propane
We had been chasing a similar issue (on one of the race car so use it for what it's worth on a street car). The Fuel pressure was within specs but at the low end of the scale. 2 things fixed the problem. A) Bad ground on the pump (we obviously have modified factory wiring) and B) Replaced the fuel pump.
Suggestions only, use it for what it's worth.
Kimolaoha
Dec 5, 2020 09:32 PM
imanexcellentdriver
Aug 31, 2015 08:08 PM
LDB
Aug 31, 2015 05:21 AM
Minii cooper bean
Aug 11, 2015 02:10 PM
